6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Oct 10, 2019 at 5:10 AM
    #571
    JackoRama
    JackoRama New Member
    Socal
    2013 tundra 4x4
    none so far
    Thank you.
    Rica25 likes this.
  2. Oct 14, 2019 at 1:02 PM
    #572
    CementTurdOffRoad
    CementTurdOffRoad New Member
    Andrew
    Maryland
    '19 Cement Limited Off Road
    Question for all: I’ll be installing 6112 @ 1.9 and 5160 at stock height on my ‘19 CM in the next few weeks. Is the driver side shim necessary at that height? It seems much more common when the 6112’s are at top setting, but will I experience lean at 1.9”?
    Rica25 and MAGDADDY like this.
  3. Oct 14, 2019 at 1:34 PM
    #573
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Have you called David at Ekstrom design? He’s an awesome source of lift knowledge.
    Coachbuilder1 and Rica25 like this.
  4. Oct 14, 2019 at 2:26 PM
    #574
    CementTurdOffRoad
    Andrew
    Maryland
    No, but thanks for the tip! I’ll reach out to him.
  5. Oct 15, 2019 at 8:44 AM
    #575
    Youth is overrated
    Youth is overrated New Member
    2017 Silver Tundra CM TRD
    6112/5160 2.5 +2 driver 1 pass CB shims, CB+3 shackles,
    Well, the time is near!
    On the way is a set of 6112/5160's plan to set 6112 at top setting, unless I chicken out! Really don't want to have to explain to the wife I need UCA's.
    Will be putting 2 CB shims on the drive side and 1 on the pass side, +3 CB shackles. Plan to run my current TRD 18in wheels wrapped in stock Michelin 275 65 18, but go to 285 75 18 in a few months. I hope it all works out as planned and Mr. Murphy keeps his little arse at bay! Will post before, during and after pics along the way.
  6. Oct 15, 2019 at 12:10 PM
    #576
    Youth is overrated
    Anyone know of a better price for the below? It seems like a good deal.
  7. Oct 19, 2019 at 4:27 AM
    #577
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    That’s probably as good as it’ll get!
    Rica25 likes this.
  8. Oct 19, 2019 at 11:06 AM
    #578
    JackoRama
    Socal
    2013 tundra 4x4
    none so far
    Finally pulled the trigger on 6112 (2nd to the top setting) front and 5160 rear. Noticed that there's a 1 inch tundra lean on the driver side. Looking for advise that will not damage anything. Not planning on doing any heavy duty off roading. TIA
    Coachbuilder1 likes this.
  9. Oct 19, 2019 at 11:27 AM
    #579
    Icematt
    Icematt Toyota4life
    Black 1794 TRD
    Fuel wheels
    Mine is at 1.3, the is great!
  10. Oct 19, 2019 at 12:50 PM
    #580
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Check out Coachbuilder, they have shims that fix the lean, I’ve got 2 on my drivers side and 1 on my passenger side. I was only leaning 0.5”. The shims are 1/2” each.
    JackoRama[QUOTED] likes this.
  11. Oct 19, 2019 at 1:48 PM
    #581
    JackoRama
    Socal
    2013 tundra 4x4
    none so far
    So the shims just go on the front? If so then what goes on the rear. Also, i noticed since leveling whenever I turn the wheel all the way there's a creaking sound. Is that something I should be worried about?
  12. Oct 19, 2019 at 1:57 PM
    #582
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    The rear you can do blocks, shackles or add a leaf spring. I’m using Coachbuilder +3 shackles which gives me around 1.75” for the back. As far as the noise, I’ve heard guys say it’s been the skid plate or the lower control arm need to be tightened, also obviously re torque all other parts, hopefully you’ll find the culprit, although my 15 tundra made lots of noise up front after lifting but my 18 has been quiet.
    dannysmith604 likes this.
  13. Oct 19, 2019 at 2:06 PM
    #583
    JackoRama
    Socal
    2013 tundra 4x4
    none so far
    Thanks for responding
    MAGDADDY likes this.
  14. Oct 19, 2019 at 6:10 PM
    #584
    unclebeejo808
    unclebeejo808 New Member
    Oahu
    Wow!! That looks perfect
    georgiey22[QUOTED] likes this.
  15. Oct 19, 2019 at 7:50 PM
    #585
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Thank you.
  16. Oct 19, 2019 at 9:40 PM
    #586
    Rica25
    Ricardo
    Tulare
    Big J and equin like this.
  17. Oct 19, 2019 at 9:41 PM
    #587
    unclebeejo808
    Oahu
    Stats on lift and tires? Nice truck
    Rica25[QUOTED] likes this.
  18. Oct 20, 2019 at 7:49 AM
    #588
    Rica25
    Ricardo
    Tulare
    That's the set up I did on my uncles truck last month ......I did the same as mine 6112s in front with 2 CB shims and one on passenger. 5160 on the rear with CB +3. Just this week I installed for him the 8 inch BA muffler. Powder coated the wheels. Tires are 285 65 18 Nitto Terra grappler G2
    dannysmith604 and MAGDADDY like this.
  19. Oct 20, 2019 at 7:59 AM
    #589
    19TundraPlatinum
    19TundraPlatinum New Member
    Maryland
    2019 Tundra Platinum Magnetic Gray Metallic
    5% Window tint Ceramic coating Weather tech mats Color matched mirror caps and door handles Oem black exhaust tip Blacked out 4x4 badge and added black tundra tailgate insert
    What all did you have to do fit those 35s, Bmc?
    Rica25 likes this.
  20. Oct 20, 2019 at 6:54 PM
    #590
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    I removed front and rear front fender well mud flaps and did a BMC. Sorry I haven’t posted photos. Got the truck done a few days later I went out of town to get married then a few days later had an unexpected death in the family. I will get the before and after measurements and photos up by the weekend
    Rica25 likes this.
  21. Oct 20, 2019 at 8:24 PM
    #591
    unclebeejo808
    Oahu
    Just ordered my 6112/5100 setup through boss 4x4. Hopefully they come in by next week.
  22. Oct 20, 2019 at 10:01 PM
    #592
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Welcome to the 6112 club, put up
    Some pics when you get done!
    unclebeejo808[QUOTED] and Rica25 like this.
  23. Oct 21, 2019 at 4:39 AM
    #593
    19TundraPlatinum
    Maryland
    sorry to hear about the death. Congrats on the wedding though no rush on pics as I’ve pulled the trigger on my sweet up and I went with 285/65/20 34”
    cmiller219[QUOTED] and Rica25 like this.
  24. Oct 21, 2019 at 2:54 PM
    #594
    phonyteachr
    phonyteachr New Member
    2018 SR5 TRD off-road CM
    What offset are the rims? You mentioned trimming just plastics/flaps? Any body mount trim or anything crazy? Looking at +25 offset with 285/70/18..I don't mind trimming plastics but not interested in cutting mounts and such. Thanks..
  25. Oct 21, 2019 at 4:35 PM
    #595
    motoxscott
    motoxscott New Member
    Scott
    Hurricane, UT
    2017 Tundra
    Camburg - FOX - Method - General Tire - Deaver - Rigid
    @phonyteachr Those are 18x9 +25 offset (6" B/S) wheels.
    phonyteachr and Rica25 like this.
  26. Oct 22, 2019 at 7:26 AM
    #596
    COTundra23
    COTundra23 New Member
    Just ordered my 6112 / 5160 from Toytec! Great service and provide a forum discount. For those of you who have put some mileage on this setup, how much has the front settled over time? I am starting with 1.9 up front an stock height in the rear.
    Rica25 likes this.
  27. Oct 22, 2019 at 8:08 AM
    #597
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I had mine for over 16 months (over 20K miles), and no measurable settling here.
    COTundra23[QUOTED] likes this.
  28. Oct 22, 2019 at 12:56 PM
    #598
    ndbwhunter
    ndbwhunter New Member
    Ryan
    I was planning on doing the 6112 @ 2.5" with 5160 in the rear and a toytec shackle @1.5", but now I see that coachbuilder recommends 2 shims on the driver side and one on the passenger? Why not just one on the passenger? Will I need to replace the UCAs if I do 2 shims on the driver side wit the 6112 at 2.5", or should I just order the 6112 @ 1.9" and follow coachbuilders recommendations?
    Rica25 likes this.
  29. Oct 22, 2019 at 1:23 PM
    #599
    Rica25
    Ricardo
    Tulare
    If I was to do it again I would set mine at 1.9 and do the shims I did mine at 2.5 with shim and +2 CB shackles but dont like the minor lean
  30. Oct 22, 2019 at 2:51 PM
    #600
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    You mean 1 on just the driver side? I have mine set to 2.5” with one shim on driver side none on the passenger. I still had a 1/2” lean. I was going the 2 driver 1 passenger but decided to upgraded my UCAs to Icon delta joint and the lean is down to 1/8”. CB +3 (1.75” lift) in the rear. I still have a 1” rake.
    Rica25 likes this.
