6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Oct 3, 2019 at 7:42 PM
    #541
    Big J
    Big J New Member
    2020 4x4 crewmax
    Very nice! Was that the more aggressive side wall facing out? Any trimming at all?
    Bakelite and Rica25 like this.
  2. Oct 3, 2019 at 9:24 PM
    #542
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    No trimming. I would consider this side wall a bit more gnarly than the other side.
  3. Oct 4, 2019 at 5:28 AM
    #543
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    Is the CB bumper spacer shim to correct the driver side lean?
    Rica25 likes this.
  4. Oct 4, 2019 at 5:32 AM
    #544
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    C136DFF9-BF1B-49B7-A566-97A1ECACD024.jpg E102B380-EBCF-4A62-B3E6-48A98ED51C67.jpg
    The front bumper spacers are the two plates you see in picture 1. They are 1/2” each- 2 on each side that brings the bumper out 1” to help clear bigger tires.
  5. Oct 4, 2019 at 2:23 PM
    #545
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    I've removed the front bumper before to powder coat the ends, so I'm aware of the process. Question though, did you remove the plastic liner and any wiring connections when you put the shims in or were you able to do it by simply removing the bolts that hold the bumper on?
  6. Oct 4, 2019 at 2:52 PM
    #546
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Got both sides loose then did 1 at a time. Was able to hold the bumper and slide the plates on and reattach. Just need to drop the tow hooks to get a good bite on the bumper bolts.
    Rica25 likes this.
  7. Oct 4, 2019 at 3:01 PM
    #547
    AZBoatHauler
    So.Arizona
    Finally got it clean after the install and subsequent off-roading last month.
    1.9", 1 CB shim on driver's side, CB +2 shackles and 5160's in the back. Tires are 275/70 18 Nitto RG's. I did have to trim about an inch off each side of the stock "skid" plate for tire clearance.
  8. Oct 4, 2019 at 3:02 PM
    #548
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    MGM looking good!
  9. Oct 5, 2019 at 11:57 AM
    #549
    dlowry81
    dlowry81 New Member
    Doug
    Thanks. Guess that’s next on my list as I just installed 285/75/17’s with the 6112’s at 1.9 and a 1 CB shim on each side and I’m rubbing the front plastic even with the mud flap removed.
    equin and Rica25 like this.
  10. Oct 5, 2019 at 12:52 PM
    #550
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Get this. I’m running a 18x9 +20 offset
    And a 295/70/18. Even with the front bumper spacer and little front flaps removed, I was still rubbing! Didn’t want to get too crazy so I took the dremil and took out the sections that were in the way. A437C5C1-4EAC-43EE-980D-49013B3E3E97.jpgE642F8E7-ED44-43D2-BB38-ED09872C5DD8.jpg
  11. Oct 5, 2019 at 1:17 PM
    #551
    dlowry81
    dlowry81 New Member
    Doug
    I’m not sure I can dremmel it. I think it’s hitting the lower edge of the bumper end. Super frustrating. I did a lot of research. Lots of guys running the 18” version of my tire size with the same lift and no issues.
  12. Oct 5, 2019 at 1:32 PM
    #552
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Yea kinda sucks but I was lucky it was minimal, I’m sure without the spacers I’d be real screwed. Funny thing was no rubbing at the tire shop then at home sounds like a machine gun getting into the drive way. Those icons look really good, sometimes we gotta pay to play.
  13. Oct 5, 2019 at 2:05 PM
    #553
    Rica25
    Ricardo
    Tulare
    Nooooooo.....all you had to do was remold it
    CTPlatinum likes this.
  14. Oct 5, 2019 at 2:08 PM
    #554
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Agreed. #hackjob
  15. Oct 5, 2019 at 6:46 PM
    #555
    georgiey22
    Question for all...I have the Bilstein 6112 setup on my tundra and want to do the same to my 2016 4Runner. Where are you purchasing your 6112's and is there a recommendation for a shop that will ship and pre-assemble the coil-overs with top hats. It was a hassle assembling them on my tundra and want to avoid it this time. I'm seeing a price of $650 with no pre-assembly on Amazon.
  16. Oct 5, 2019 at 6:50 PM
    #556
    alwzdfiant
    alwzdfiant New Member
    2013 Tundra Crew Max
    Just installed my 6112’s in the front, 5160’s in the rear.
  17. Oct 5, 2019 at 6:56 PM
    #557
    316KS_Runner
    316KS_Runner There's no place like...
    Along the CT River
    2019 MGM CM Ltd
    Front 6112 @ 1.9 Rear 5160 | Falken Wildpeak AT3W 295/70R18 | TRD Off Road wheels | Compustar Pro R3 remote start | Baja Designs SAE fog lights | VLEDS V6 Triton Extreme (amber) front turn signals | Hot Tails Option A | 6” stubby antenna | Window tint 15% rear / 35% front | WeatherTech side window deflectors | RCI Front Skid | Talons Garage front and rear CAT Protection
    Darren from Boss 4x4’s.
    Hol Milk and georgiey22[QUOTED] like this.
  18. Oct 5, 2019 at 8:57 PM
    #558
    georgiey22
    Does he have a handle here on the site?
  19. Oct 5, 2019 at 10:47 PM
    #559
    AZBoatHauler
    So.Arizona
    @dirtydeeds ?
  20. Oct 5, 2019 at 11:53 PM
    #560
    Hol Milk
    Hol Milk New Member
    2018 SW Crewmax SR5 TRD 4WD
    Boss 8’ Super Duty
    r1-superstar and 316KS_Runner like this.
  21. Oct 7, 2019 at 11:30 AM
    #561
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    It was so much. I would trim and it would rub, so on and so on. Thought about the heat gun but heard guys say it melted to fast. Thought about going to junk yard and finding one and try to shape w heat.
  22. Oct 8, 2019 at 1:22 PM
    #562
    Buckmark1
    Buckmark1 New Member
    TX
    2019 Cement SR5 CM - TSS Off Road 4x4
    Looks pretty much perfect. Well done. Any issues at all with TSS system after install? Everything works good as it did before lift?
    georgiey22[QUOTED] and Rica25 like this.
  23. Oct 8, 2019 at 10:43 PM
    #563
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
  24. Oct 9, 2019 at 5:30 AM
    #564
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    That looks freaking wicked! Holy shit I'm in love.
    matictundra[QUOTED] and Rica25 like this.
  25. Oct 9, 2019 at 5:39 AM
    #565
    Trikerider
    Trikerider New Member
    2015 Limited CM
    Been watching this thread for a while, just scheduled to have my 6112s installed on October 22nd, was just planning to go with the 1.3" setting as I travel a lot of highway and haul a lot of stuff in the bed of the truck and don't want to be nose high all the time. From all the pictures on here the 1.9" setting almost looks nose high unloaded. So planning 1.3", already have the 5100s installed in the rear already which were a huge improvement over the black stock shocks, sticking with stock 20" limited rims and will install 275/60r20 after the 6112s settle in. Hoping to keep it close to stock but better ride and slightly bigger tires. Will post pics early November when its all done.
    Rica25, MAGDADDY and Bakelite like this.
  26. Oct 9, 2019 at 5:44 AM
    #566
    Bakelite
    Bakelite New Member
    Sam
    Look forward to pics! I am hoping to have things ironed out for my build towards the end of November. The wheels and tires are the parts that are killing me. :mad:
    Rica25 likes this.
  27. Oct 9, 2019 at 7:43 AM
    #567
    Bakelite
    Bakelite New Member
    Sam
    Also, what offset are those wheels?
  28. Oct 9, 2019 at 7:52 AM
    #568
    matictundra
    Franco
    AZ
    I’m running 20x9 +20mm wrapped in 37x12.5.
  29. Oct 9, 2019 at 11:36 PM
    #569
    JackoRama
    JackoRama New Member
    Socal
    2013 tundra 4x4
    none so far
    Hello all,
    Recently just installed bilstein 6112 at 1.9 in the front and 5160 in the back. Local tire shop says the shocks is all I need to be installed. I noticed at the boss website there's other parts that are sold with the leveling kit. Should I be concern that I didnt install those other parts? 2013 tundra crewmax 4x4.
    TIA
    Rica25 and Bakelite like this.
  30. Oct 10, 2019 at 4:02 AM
    #570
    trailrnr
    trailrnr New Member
    2013 Rock Warrior CM
    That kit has a front diff drop which you don't need at your lift height. It has a carrier bearing drop for the rear which you don't need because the rear gained no height.
    It also has bump stop extensions which might be nice but you probably do not need those either at 1.9
    A couple bump stop threads:
    https://www.tundras.com/threads/bumpstop-extensions-needed-or-not.30042/
    https://www.tundras.com/threads/bumpstop-extensions.28345/
