6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Sep 30, 2019 at 6:41 AM
    #511
    Jra8
    Jra8 New Member
    Tampa Fl
    2018 Inferno
    Tire placement is key. Got hung up once. And it was my fault. Didn't wait for my spotter. Step bar took the hit.
    I have nothing else to compare this suspension to. But to do a red trail in Moab with the wife, and her not getting sick, I say this set up is doing good.
  2. Sep 30, 2019 at 7:52 AM
    #512
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Right on man! Sounds like a lot of fun, looking forward to getting mine of the beaten path soon.
    Rica25, Jra8[QUOTED] and Bakelite like this.
  3. Sep 30, 2019 at 6:37 PM
    #513
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    So I got all my parts installed and I gotta say it looks so beast. I didn't have time to get proper photos and I fly out in the morning to get married on Friday so I will take some when I return. Until then here is a decent rear end shot I was able to get before I lost light. And again this is my mod list.....
    6112 Top Setting
    5160
    Camburg UCA
    CoachBuilder +3 Shackles
    CoachBuilder Shims 2 driver side 1 passenger
    Revtek Diff Drop
    CoachBuilder Carrier Bearing Drop
    Wheels 17x8.5 ET 0
    Tires 35x12.5x17
    BEFORE
    AFTER
  4. Oct 1, 2019 at 8:11 AM
    #514
    kevine0001
    kevine0001 New Member
    Kevin
    is anyone running a diff drop bracket with their 6112's? to help with the CV angle and to prevent premature wear on the CV boot?
    Tundyfundy, Rica25 and Bakelite like this.
  5. Oct 1, 2019 at 8:35 AM
    #515
    cmiller219
    Nashville, TN
    I am. I did it because it’s like $30 and now i don’t have to worry. Too cheap to pass over
  6. Oct 1, 2019 at 8:38 AM
    #516
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    Which Camburg UCA's did you go with exactly? Have a link anyone?
    Rica25 likes this.
  7. Oct 1, 2019 at 8:42 AM
    #517
    Bakelite
    Bakelite New Member
    Sam
    I'm seeing the uniball 1.50" ones and the balljoint upper. Whats the difference? My build is almost the same as yours minus the diff drop (Haven't gotten one).
  8. Oct 1, 2019 at 8:52 AM
    #518
    cmiller219
    Nashville, TN
    I did Uniball.
    Uni balls are way stronger and generally allow for more range of motion with misalignment spacers....
    The downside of uni balls is that they are much more susceptible to corrosion and dirt since they are not sealed. There are covers for the top.. but you will still get significant exposure on the bottom and the cover may make things worse overall. Someone else can add to this or correct me if I am wrong but this is what I found when researching to buy mine
  9. Oct 1, 2019 at 11:07 PM
    #519
    Hol Milk
    Hol Milk New Member
    2018 SW Crewmax SR5 TRD 4WD
    Boss 8’ Super Duty
    Had the 6112/5160 complete Bossed out kit installed and while driving home, I fish tailed a couple times on turns.:notsure: Roads were wet from light rain and I’m on 20” wheels with KO2s. Will definitely need some significant weight back there during the winter. :benchpress:
    Rica25 likes this.
  10. Oct 2, 2019 at 4:37 AM
    #520
    cmiller219
    Nashville, TN
    ^^^285/70/20s????
  11. Oct 2, 2019 at 7:35 PM
    #521
    Hol Milk
    Hol Milk New Member
    Boss 8’ Super Duty
    No. Just 285/55/20
    Those were on it when I bought it from a fellow member and still have plenty of tread left.
    Rica25 likes this.
  12. Oct 2, 2019 at 7:49 PM
    #522
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Wanna borrow my mother in law? :rofl:
  13. Oct 2, 2019 at 9:18 PM
    #523
    Rica25
    Ricardo
    Tulare
    I'm ordering the Camburg Ball joint
    motoxscott and Bakelite like this.
  14. Oct 3, 2019 at 12:33 AM
    #524
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I also am
    kevine0001[QUOTED] and Rica25 like this.
  15. Oct 3, 2019 at 2:10 AM
    #525
    CementTurdOffRoad
    CementTurdOffRoad New Member
    Andrew
    Maryland
    '19 Cement Limited Off Road
    Looks great from the rear, excited to see some more shots. Looking at a somewhat similar setup on my ‘19 cement CM.
  16. Oct 3, 2019 at 9:06 AM
    #526
    motoxscott
    motoxscott New Member
    Scott
    Hurricane, UT
    2017 Tundra
    Camburg - FOX - Method - General Tire - Deaver - Rigid
    Don't waste your money and time on a small diff drop spacer kit. It is 100% NOT needed. If you needed the small cheap spacers and bolts, Bilstein, FOX, King & Icon would all supply them with their coilovers since they are already supplying needed mounting hardware, etc. We have never ran them on any Tundra we've owned or raced and have CV's with over a 100k miles on them with no issues. Save the $30-40 and put it towards your next trip.
    The real reason a diff spacer came about years ago was because some shops were installing coilovers with 2-3" of lift and also running a 2-3" spacer so everything was pinned at max height and they wanted to relax the CV boot angles. The axles weren't the problem the fact that they were trying to lift the front end way too high by stacking kits was. Plus since it's cheap no one questions if and why they need it.
    - Scott @ Camburg
  17. Oct 3, 2019 at 9:21 AM
    #527
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    I’m running 6112 top setting with .5” coachbuilder shim on top with 3.5” “total” lift. I do have diff drop in. So with that much lift I do not need diff drop? Is this correct? I will take it out if I do not need it.
    Rica25 likes this.
  18. Oct 3, 2019 at 9:28 AM
    #528
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Leave it in since you added .5" CB spacer. For 2" lift or below, diff drop is not required. I still recommend diff drop for 6112 top setting cause it will lift the front by about 2.5". Mine is the same top setting as yours but with 1/4" CB spacer for 3" total front lift, and I do run diff drop.
    Rica25 likes this.
  19. Oct 3, 2019 at 9:33 AM
    #529
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    It's been said many times before that the diff drop really just pivots the diff and starves your front pinion bearing of oil. It does very little to relieve CV axle angles.
    Rica25, r1-superstar and equin like this.
  20. Oct 3, 2019 at 9:33 AM
    #530
    Big J
    Big J New Member
    2020 4x4 crewmax
    Hey Scott I have heard this before as well. How much lift can you go in the front and be in the safe range? 3.5"? 4? Curious since I saw icon sells coilovers that go up too 3.5" of lift?
    dannysmith604, Rica25 and Bakelite like this.
  21. Oct 3, 2019 at 9:37 AM
    #531
    Bakelite
    Bakelite New Member
    Sam
    Interested in this too. I should be around 3" total with CB shims, shackles and Bilsteins once said and done.
    Rica25 likes this.
  22. Oct 3, 2019 at 10:17 AM
    #532
    motoxscott
    Scott
    Hurricane, UT
    2017 Tundra
    In the 12 years that the Tundra has been out not once have we ever installed a diff drop on any install we do, trucks we've owned and daily drive or the Tundra we raced the Baja 1000 and many other races with. That race truck is still being used today. All with NO diff drops and NO driveline issues. We've installed Bilstein, FOX, King, ICON, etc. Non-long-travel, long-travel, etc etc etc.....
    If it's already installed I guess leave it, but since we've never done one, I don't know what issues you could have with having it installed. All my experience is based on NOT having it.
    The "diff drop" discussion for Tundra's and Tacoma's has been one of those that just comes up year after year ... and year after year we NEVER install them and NEVER have problems lol.
    :cheers:
    - Scott @ Camburg
  23. Oct 3, 2019 at 10:40 AM
    #533
    Big J
    Big J New Member
    2020 4x4 crewmax
    Good to know. Because I always wondered if a diff drop would cause any problems with fluids since it tilts the differential forward.
    What is the typical amount of lift you guys use and haven't seen problems?
    Rica25 likes this.
  24. Oct 3, 2019 at 11:05 AM
    #534
    canadianguy
    Kevin
    Thanks. I put diff drop in and now will be removing it if there’s no need for it.
    Rica25 likes this.
  25. Oct 3, 2019 at 11:34 AM
    #535
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    As faras the diff drop... the differentials are splashlubed, no forced piling system, the ring gear throws oil everywhere in there, a diff dropwon’t matter at all.
    JM2C
    Rica25 and Big J like this.
  26. Oct 3, 2019 at 11:42 AM
    #536
    cmiller219
    Nashville, TN
    It’s there just leave it it isn’t causing any harm. Just like everything else it’s someones opinion. You can ask 10 people and half are for and half are against.
    Rica25, Midnite72 and Bakelite like this.
  27. Oct 3, 2019 at 2:30 PM
    #537
    kevine0001
    Kevin
    FWIW, I came from having a built Land Cruiser. 2000 100 series. First of the IFS LC's. Anything more than about 2-2.5" lift in front, and the diff drop bracket was needed, otherwise, you'd go thru CV boots every 3-6 months depending on your driving. Thus, the reason for the question here. Thanks for all the info. Since I'm not planning on going more than 2-2.5", I'll probably skip it. If I end up with CV issues too early, I'll install it then...along with new CV boots....
    Rica25 likes this.
  28. Oct 3, 2019 at 4:38 PM
    #538
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Keep it simple...2019 TRD Sport. Suspension below and I really like the setup as a daily driver.
    -6112 at 1.9” in the front
    -5160 no lift in the rear
    -CB front bumper spacer shim
  29. Oct 3, 2019 at 4:40 PM
    #539
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Yep, that looks about as good as it possibly could.
  30. Oct 3, 2019 at 5:10 PM
    #540
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Lookin sweet! Did a damn good job!
