6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Aug 11, 2019 at 4:08 PM
    #421
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    6112's on the top setting and 5160 in the rear with icon/deaver leaf expansion pack. 275/65r20 General Grabber x3's on the factory 20's. Didnt take any measurements before hand. 20190727_125536.jpg 20190811_120914.jpg 20190801_123341.jpg 20190811_123355.jpg
  2. Aug 11, 2019 at 4:14 PM
    #422
    jordan0317
    Jordan
    Martin, TN
  3. Aug 29, 2019 at 10:06 AM
    #423
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    Has anyone ever soaked Bilsteins in clear coat or wrapped them with clear M3? Cuz these look really nice when there newE0E365E8-F249-4571-8451-25BD27E0FAD9.jpg
  4. Aug 29, 2019 at 2:50 PM
    #424
    Rubberdown
    Better do something with em. They look like crap in no time. Tape the shafts off and have them clear cerakoted.
    Rica25 likes this.
  5. Aug 30, 2019 at 8:19 PM
    #425
    Forkhunter
    Forkhunter New Member
    2018 DC Limited
    6112/5160 combo. 1.9 setting with 1 shim on drivers side and +3 CB shackles. Ended up going with 275/70/18. Had the 285/75/18 on for a day, but too much rub even after trim. I wanted to go 285/70 but I got such a good deal on these I couldn't do it. Still really happy with the look and the ride. Might go aftermarket rims at some point, but not ready yet. IMG_20190830_185943368_HDR.jpg
  6. Sep 1, 2019 at 2:19 PM
    #426
    Jra8
    Jra8 New Member
    Tampa Fl
    2018 Inferno
    So,I just finished reading this entire thread to make sure I didn't ask something that had been covered already. I installed 6112 top setting with 2 shims on driver side and 1 shim on passenger side to get a full 3 inches of lift. Im running 295/70/18. As far as ride goes, I can't tell any difference, maybe I just care about the lift. But what I do notice is sometimes during braking, more so at slow speeds, the truck pulls hard to either side. Has anyone else had this problem?? Alignment was done at Toyota, and it drives straight. Any feedback is appreciated.
  7. Sep 1, 2019 at 3:20 PM
    #427
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    May just be from wider tires hunting in and out of the ruts in asphalt. Try it on concrete paving and see if it does the same thing.
    Ely010606 likes this.
  8. Sep 1, 2019 at 4:29 PM
    #428
    Jra8
    Jra8 New Member
    Tampa Fl
    2018 Inferno
    That's exactly what I was thinking. I'm new to driving with this type of tires. Thanks for the comment.
  9. Sep 1, 2019 at 7:45 PM
    #429
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Yeah mine does the same, steering is straight no vibration, i have 285/70/18 tires. Once i see wear on my tires im getting another alignment done.
    Jra8[QUOTED] likes this.
  10. Sep 6, 2019 at 11:14 AM
    #430
    GHOSTTUNDRA
    GHOSTTUNDRA New Member
    Jonathan
    2012 Tundra Crewmax 4x4
    Bilstein 5160/6112 Toytec Shackles VTX Off road Nitto trail grapplers Front Runner Slimline roof rack and bed rack. GFSR Rooftop tent
    6112 shocks set at highest setting. My next set of tires I will be getting something as close to 35s.
  11. Sep 6, 2019 at 2:52 PM
    #431
    jordan0317
    Jordan
    Martin, TN
    What rear setup are you running to keep from sagging loaded down?
  12. Sep 6, 2019 at 3:28 PM
    #432
    GHOSTTUNDRA
    Jonathan
    only running 5160 with toytec shackle set at 1.5 inch. stock leafs
    jordan0317[QUOTED] likes this.
  13. Sep 6, 2019 at 4:34 PM
    #433
    jordan0317
    Jordan
    Martin, TN
    Sweet, I've got the 5160 in the rear as well, and the icon/deaver progressive 3 leaf pack and have a little sag with my setup. Gonna throw a toytec aal in for now to level it back out since itll stay loaded most of the time until I can shell out for a full custom pack
  14. Sep 8, 2019 at 9:36 PM
    #434
    GHOSTTUNDRA
    Jonathan
    Let me know how it works out for you. I'm still thinking of a way to keep a level look with new leafs or do add a leaf.
  15. Sep 9, 2019 at 4:38 AM
    #435
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Yeah your rear sags a little I would try the +3 and I bet you will get the slight rake back
  16. Sep 9, 2019 at 6:50 AM
    #436
    canadianguy
    Kevin
    6112 top setting with .5” shims for 3.5 total lift. 5160 with toytec add-a-leaf in rear with 1.5” lift and 315/70-17 bfg’s. I’ll get a pic today
    justfortun likes this.
  17. Sep 9, 2019 at 11:57 AM
    #437
    canadianguy
    Kevin
    Also sprayed them in clear coat and wrapped the faces with m3 that will be taking the abuse.
  18. Sep 9, 2019 at 1:01 PM
    #438
    canadianguy
    Kevin
    Sits pretty level with 3.5” up front and 1.5” in the rear 0171EC05-4BBB-4114-BFC4-BEA0C6B31ABA.jpg 62473018-3F93-4755-AABB-057C1B4FA862.jpg
  19. Sep 9, 2019 at 2:40 PM
    #439
    Texas Bandit
    Texas Bandit New Member
    Amí
    Edinburg Texas
    2007 White 5.7 Tundra DC Limited 4x4
    295/70R18 Nitto Ridge Grappler Method Race Wheel NV Bronze Rigid Industries Radiance Pods Morimoto Xtorch 36” Light Bar SDHQ Pillar Light Mounts
    Nice!!!!
    Rica25 likes this.
  20. Sep 9, 2019 at 3:43 PM
    #440
    bossgobbler32
    bossgobbler32 New Member
    That’s a nice set up! Truck looks tough!
    Rica25 likes this.
  21. Sep 10, 2019 at 7:19 AM
    #441
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    Did you have to get new UCA's or diff drop?
    Rica25 likes this.
  22. Sep 10, 2019 at 7:29 AM
    #442
    canadianguy
    Kevin
    I had diff drop from leveling blocks. Still on stock uppers. Need to go for alignment yet, and go from there.
  23. Sep 10, 2019 at 7:39 AM
    #443
    Bakelite
    Bakelite New Member
    Sam
    Very awesome looking truck.
    If I am doing a shackle in the rear, is a diff drop required? Going to be doing a similar set up with 6112's up front and 5160's in the rear.
    Rica25 likes this.
  24. Sep 10, 2019 at 7:50 AM
    #444
    jordan0317
    Jordan
    Martin, TN
    That's the nfab rear bumper? I like it
    Rica25 likes this.
  25. Sep 10, 2019 at 8:15 AM
    #445
    canadianguy
    Kevin
    Diff drop is only required for over 2-2.5” I believe, but I’m sure someone on here can confirm.
  26. Sep 10, 2019 at 8:16 AM
    #446
    canadianguy
    Kevin
    Yes it is. I powder coated the rear skid plate textured black to match. Was gonna colour match it to truck but the shop didn’t have the colour in stock
  27. Sep 10, 2019 at 6:49 PM
    #447
    Jra8
    Jra8 New Member
    Tampa Fl
    2018 Inferno
    When referring to the shackles in the rear, you need is a carrier bearing drop kit. That's to drop the driveshaft.
    Lift the front, then you need diff drop kit.
    Bakelite[QUOTED] likes this.
  28. Sep 10, 2019 at 7:49 PM
    #448
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    Bakelite and Rica25 like this.
  29. Sep 12, 2019 at 9:09 PM
    #449
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    My 6112’s just arrived, assembled at 1.9”. I’m not going to add any shims and the rear will remain stock. I’ll be using the stock 19 limited 20’s. 275/65r20’s will need a trim of the skid plate from what I’m reading? Truck will also be hauling an 8’ snowplow on the front which was the reason for the level.
    Rica25 likes this.
  30. Sep 13, 2019 at 5:00 AM
    #450
    Bakelite
    Bakelite New Member
    Sam
    Thanks for the info! Just talked to @Coachbuilder1 and he squared me away with the carrier bearing drop kit.
    Coachbuilder1 likes this.
