6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Jul 15, 2019 at 8:30 AM
    #391
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    Perfect, thanks!
  2. Jul 15, 2019 at 12:35 PM
    #392
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    Awesome! Love how it sits. I'm looking to go the same direction.
    Do the Toytec shackles require you to replace the leaf spring bushings like the coachbuilder?
  3. Jul 15, 2019 at 1:03 PM
    #393
    wwinslett
    wwinslett New Member
    Will
    Birmingham AL
    2016 Tundra CM Magnetic Grey
    6112's Toytec Shackles Method NV on Ridge Grapplers 295/70/18
    Thanks! Toytec usually does recommend changing them but my truck only had 7k miles on it when I installed the kit so I didn't have to.
  4. Jul 19, 2019 at 4:46 PM
    #394
    JDHolliday27
    JDHolliday27 New Member
    2018 CM
    6112's @ 1.9" setting with 1 CB shim on driver side and 5160's with CB +2 shackles in the rear. Stock wheels and tires for now...
  5. Jul 21, 2019 at 12:08 PM
    #395
    Jmmtjoy
    Jmmtjoy Livin the dream
    Bristow, Virginia
    2016 Crewmax SR5 Super White
    Did you do the plus two on the rear to maintain factory rack? Wheels and tires coming, if so what combo. Looking good!
    power80 likes this.
  6. Jul 21, 2019 at 4:10 PM
    #396
    JDHolliday27
    2018 CM
    Yes it was to keep the factory rake and I personally like that look. I had seen other pics of trucks with the +1 and could barely tell they had any lift in the rear. Plus the price difference is $10 and honestly couldn't justify spending that kind of money for only .625" of lift.
    Waiting to do wheels and tires until the stock Michelin's wear out. But pretty dead set on SCS SR8's with 275/70/18 tires.
  7. Jul 21, 2019 at 4:57 PM
    #397
    Jmmtjoy
    Bristow, Virginia
    Can't argue with that! Looks great.
  8. Jul 22, 2019 at 6:32 PM
    #398
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    If I did 1.9 with no rear lift what kind of offset would I need to run 33x12.50r18? I'm on stock suspension and TRD OR wheels running 275/70r18 which a 33.19 and 10.98 and no issues with rub. Or would I need to go to the 2.5 setting? If so I'd probably need an inch in the rear to make it look better.
  9. Jul 22, 2019 at 8:34 PM
    #399
    Texas Bandit
    Texas Bandit New Member
    Amí
    Edinburg Texas
    2007 White 5.7 Tundra DC Limited 4x4
    295/70R18 Nitto Ridge Grappler Method Race Wheel NV Bronze Rigid Industries Radiance Pods Morimoto Xtorch 36” Light Bar SDHQ Pillar Light Mounts
    Nice truck!!! What setting do you have it on?
  10. Jul 22, 2019 at 8:34 PM
    #400
    Texas Bandit
    Amí
    Edinburg Texas
    Whoops just saw it
    wwinslett likes this.
  11. Jul 23, 2019 at 10:24 AM
    #401
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    I might have done some funny math here fellas. Looks like Boss is atleast 1k for this combo. I didn't realize I had only counted one rear shock.
  12. Jul 23, 2019 at 10:45 AM
    #402
    Jmmtjoy
    Bristow, Virginia
    Yea i just placed the order from Boss 4x4 for the 6112/5160 pre assembled and one drivers side shim and it was a hair under $1,200.
  13. Jul 23, 2019 at 6:22 PM
    #403
    toyoboyo
    toyoboyo New Member
    When you guys are saying "drives so much better than stock". What do you mean? Does this setup add more flex like a Fox setup from a TRD PRO? Is it as smooth or as good as a TRD PRO setup?
  14. Jul 24, 2019 at 6:42 AM
    #404
    Jmmtjoy
    Bristow, Virginia
    Wanting the Black Rhino Roku in 17x9.5 with a +12 Offset. In bronze because that color looks sweet with white. Also just ordered the 6112/5160 @ 1.9" Setting. Everything I have read leads me to believe a 285/75r17 Nitto Ridge Grappler will look friggin sweet. Also consider a little smaller or maybe a 295/70. Just havent seen this wheel/tire combo much on here. Curious if I will have any serious rub with the tire and offset, also if the 9.5" wheel is too wide. Any help is much appreciated!
  15. Jul 24, 2019 at 9:25 AM
    #405
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    It’s a better riding suspension. More compliant. More controlled. More dampening. Potholes don’t rattle your teeth out. Daily driving is much more comfortable.
    Spitfire, equin and JDHolliday27 like this.
  16. Jul 25, 2019 at 9:41 AM
    #406
    Jmmtjoy
    Bristow, Virginia
    Im considering this same size wheel/tire combo with a 18" +12 wheel and the 6112 set at 1.9 with one drivers side shim. Im sure ill have some trimming. Did you have any contact with the mid flap ??
  17. Jul 27, 2019 at 6:03 PM
    #407
    00PS
    00PS New Member
    2016 Barcelona Red Limited Crewmax TRD 4x4
    I can’t find any information that the AT3 XLT was available in that size. Are you sure they are not 275/70r18 or 285/75r18?
    406Michael and Rica25 like this.
  18. Jul 27, 2019 at 6:26 PM
    #408
    Biff_Elwood
    Biff_Elwood New Member
    Denver
    2014 Platinum
    Im working on it!
    Sorry for the typo they are 295/70 18.
  19. Jul 27, 2019 at 6:57 PM
    #409
    00PS
    00PS New Member
    Roger that; thanks! Your truck looks great.
    Biff_Elwood[QUOTED] likes this.
  20. Aug 5, 2019 at 9:43 AM
    #410
    canadianguy
    Kevin
    Everyone running bump stop extensions?, or are they not needed with the 6112?
    georgiey22 and Rica25 like this.
  21. Aug 7, 2019 at 12:12 PM
    #411
    Jmmtjoy
    Bristow, Virginia
    Also curious about bump stops. Mines set at 1.9"
    Rica25 likes this.
  22. Aug 7, 2019 at 12:21 PM
    #412
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Bilstein supplys 2 thick washers [1 per side) foe the rear [?] Bumpstop to be used with the top setting, other than that good to go.
    Rica25, equin and Jmmtjoy[QUOTED] like this.
  23. Aug 7, 2019 at 12:22 PM
    #413
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Bam 8 exhaust 285/70 18 ridges 4:88 gears, auburn lsd 6112s SPC UCA
    The 6112s come with washers you install on your original bump stops
    Rica25 and equin like this.
  24. Aug 7, 2019 at 12:25 PM
    #414
    Jmmtjoy
    Bristow, Virginia
    Thanks Fellas!
  25. Aug 7, 2019 at 12:30 PM
    #415
    canadianguy
    Kevin
    Perfect. Thanks!
  26. Aug 9, 2019 at 6:15 AM
    #416
    COelkhunter84
    COelkhunter84 New Member
    This looks great!
    Just ordered same tires. I plan on doing 6112s and the 2.5" setting (+1 CB shim on the DS) and 1" shackle on the back.
    Anything you would've done different this build?
    RW-3[QUOTED] likes this.
  27. Aug 10, 2019 at 7:17 AM
    #417
    RW-3
    RW-3 May the Mods be with you
    Rob
    16 Black TRD CM 4x4
    Lights: 2018 OEM Black Chrome LED’s Morimoto XB Fogs Interior LED upgrade - VLED’s LED reverse / cargo - VLED’s Footwell lights, vanity lights, break lights, rear turn signals, 3rd break light - All VLED’s 30” Rough Country light bar hidden in bumper w/ Rago Fab Brackets Matt Gecko LED bed lights (red & white) and hood lights Exterior: Truxedo Lo Pro QT WeatherTech in-channel window deflectors Interior: Husky X-Act Contour front & rear Front, back and rear windows all tinted 10% Ceramic Heat Film on Windshield 70% OCD console organizer OCD console tray TRD 4x4 inserts on Husky mats by Achuop Tacoma TRD Pro shift knob with TRD leather boot AJT Design vent ring trim - chrome delete Center console wireless charger Drivers side grab handle Performance: Dirty Deeds BA Muffler 12” Budget Standard System TRD Rear Sway Bar AFE Pro Dry S Air Filter Bilstein 6112 1.9” clip Bilstein 5100 - rear Coachbuilder +1’s Nitto Ridge Grapplers 285/70/18 Audio: Infinity dash speakers Tech12Volts custom center dash speaker Hertz Uno door speakers JL Audio RD 900/5 amp 2 JL Audio 10w-0 v3 10” subs in custom Tech12Volts box Protection: McGuard Tailgate Anti theft lock OEM tailgate lock w/ Dynamat TRD Pro skid plate SNS ARB sensor guards Misc: TRD key fob case AJT Designs Rear diff breather mod Fortin remote start with Car Link CL6 TRD battery bracket by Coupe TRD valve stem caps TRD interior handle inserts by abomb60 (Adam)
    Nope. I was torn between getting 295/70/18 or 285/70/18. If I had gone with 295’s they recommend wheel spacers and I didn’t want those so I went with the 285’s. Very happy with this setup. It drives great! You won’t be disappointed.
    Rica25 likes this.
  28. Aug 10, 2019 at 7:25 AM
    #418
    Danman34
    Danman34 New Member
    Danny
    295s would have fit. Guys run this size on these wheels all day.
  29. Aug 10, 2019 at 7:53 AM
    #419
    RW-3
    Rob
    16 Black TRD CM 4x4
    They fit, but I was told if your tire pressure gets low it will start rubbing pretty quickly. Either way, I’m happy with the 285’s.
  30. Aug 10, 2019 at 7:54 AM
    #420
    Danman34
    Danman34 New Member
    Danny
    That is true. Can’t air them down any.
