6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Jun 24, 2019 at 6:23 PM
    #361
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Have your alignment sheet? You should be around .1 to 0 on camber and .07 on toe. If they set your toe higher than .1 per side that is why you’re getting outer wear on your tires.
  2. Jun 24, 2019 at 6:25 PM
    #362
    kleiker0303
    kleiker0303 New Member
    Kyler
    Kansas City
    ‘16 Platinum
    Bilstein 6112 @ 1.9" Bilstein 5100's in rear Afe drop in filter Afe intake tube Afe throttle body spacer Afe catback with vibrant resonator added Stubby antenna TRD front grill Paint matched door handles Paint match mirror caps RCI skid plate All LED bulbs Undercover flex cover 20% tint all around Husky floor liners ESP under seat storage 2018 headlight mod Baja designs fog light kit 275/60/r20 falken wildpeak at3w 20x9 fuel ripper
    That's good to know. Now I just need to find a shop that actually cares and will properly align it.
  3. Jun 24, 2019 at 6:34 PM
    #363
    Danman34
    Danman34 New Member
    Danny
    I have the same setup and it took twice to get it dialed in from the suspension settling. I brought it to a legit chassis and suspension shop that doesn’t even go off “the spec”. They just know how to do a proper alignment haha. But the toe on these trucks is often set too high and this is why you’ll see a lot of tundras with outer wear issues.
    kleiker0303[QUOTED] likes this.
  4. Jun 25, 2019 at 4:49 AM
    #364
    Jra8
    Jra8 New Member
    Tampa Fl
    2018 Inferno
    6112 highest setting with 2 shims on driver side and one on passenger side. Haven't installed shackles yet. But I will soon.
    One note to those of you with year model 18, there is a recall on the TSS sensor. Toyota won't fix it if the truck is lifted. Get it fix before installing your suspension. 20190623_172910.jpg
    The only rubbing I had with 295/70/18 was on the skid plate. Easy fix. Stock rims
  5. Jun 25, 2019 at 5:55 AM
    #365
    Danman34
    Danman34 New Member
    Danny
    Not true. Depends on the dealership. Mine sells lifted and leveled Tundras and even admitted to me they have Seen quite a bit of issues with the sensors and gave me not a drop of hassle about my truck being lifted
    OR18TRD likes this.
  6. Jun 25, 2019 at 5:56 AM
    #366
    Jmmtjoy
    Jmmtjoy Livin the dream
    Bristow, Virginia
    2016 Crewmax SR5 Super White
    Yea my fronts wear a little more on the outer edge. I chalked the tires to see if that would help. I may take it to a tire shop again to check if I have a bad tire. Alignment supposedly is good.
  7. Jun 25, 2019 at 5:57 AM
    #367
    Danman34
    Danman34 New Member
    Danny
    I’m willing to bet your toe is too high. Have to Bring in toe on these trucks, especially after lifting and with bigger tires.
    Jmmtjoy[QUOTED] likes this.
  8. Jun 25, 2019 at 6:12 AM
    #368
    kleiker0303
    Kyler
    Kansas City
    ‘16 Platinum
    Does anyone have some good #'s to aim for based on past experiences with a leveling kit?
  9. Jun 25, 2019 at 6:25 AM
    #369
    Danman34
    Danman34 New Member
    Danny
    Camber - 0 to .2
    Caster - L 2.0-2.2 R 2.4-2.7
    Toe - +\- .07 per side.
    Savmikey47, reneaux, Mdjamesd and 3 others like this.
  10. Jun 25, 2019 at 6:40 AM
    #370
    Jra8
    Jra8 New Member
    Tampa Fl
    2018 Inferno
    Good point! My dealer wouldn't have. Good to know other dealers will.
    Danman34[QUOTED] likes this.
  11. Jun 25, 2019 at 7:42 AM
    #371
    kleiker0303
    Kyler
    Kansas City
    ‘16 Platinum
    Thank you
  12. Jun 25, 2019 at 7:52 AM
    #372
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    What's your rake after the upgrade?
  13. Jun 25, 2019 at 3:29 PM
    #373
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Basically same as stock, front was raised 1.9" and shackles brought the rear up 1.75".
    dannysmith604 likes this.
  14. Jun 29, 2019 at 6:45 PM
    #374
    Biff_Elwood
    Biff_Elwood New Member
    Denver
    2014 Platinum
    Im working on it!
    6112s top setting
    5160s
    Toytec shackles top setting
    Cooper AT3 XLT 285/70/18
    SPC UCAs
  15. Jun 29, 2019 at 7:05 PM
    #375
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    6112s, 1.9in setting. Nitto Ridge Grapplers 275/70/18
  16. Jul 2, 2019 at 12:22 AM
    #376
    ricd250584
    ricd250584 New Member
    Chateauguay, Qc
    2016 red Tundra TRD
    Stock at moment
    Is that an arb summit bumper ?
  17. Jul 11, 2019 at 11:34 AM
    #377
    G2G
    G2G New Member
    Chicago
    2018 White Platinum Tundra
    What is the going rate for a set of 6112's for the front and a set of 5160's for the rear. Just the hardware not installation.
  18. Jul 11, 2019 at 12:19 PM
    Danman34
    Danman34 New Member
    Danny
    If you get the 6112s preassembled, 6112/5160 typically run $1,000-$1,100.
    Spitfire and G2G[QUOTED] like this.
  19. Jul 11, 2019 at 2:09 PM
    #379
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    You can get them for under $1000 pre assembled
    G2G[QUOTED] likes this.
  20. Jul 12, 2019 at 11:00 AM
    #380
    MistrRoboto
    Virginia Beach, VA
    $911.99 is the best I see for the pair, with the 6112s assembled.
  21. Jul 12, 2019 at 1:18 PM
    #381
    kleiker0303
    Kyler
    Kansas City
    ‘16 Platinum
    On Black Friday I got an unassembled set for like $550. Then paid a local shop about $200 to assemble and install
    OR18TRD likes this.
  22. Jul 12, 2019 at 1:38 PM
    #382
    wwinslett
    wwinslett New Member
    Will
    Birmingham AL
    2016 Tundra CM Magnetic Grey
    6112's Toytec Shackles Method NV on Ridge Grapplers 295/70/18
    $1k = suspension
    $1k = tires
    $1k = wheels
  23. Jul 12, 2019 at 1:44 PM
    #383
    Danman34
    Danman34 New Member
    Danny
    Stop reminding me how much I’ve possibly spent....lol
    wwinslett[QUOTED] likes this.
  24. Jul 12, 2019 at 1:47 PM
    #384
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    What's the specs?
  25. Jul 12, 2019 at 4:24 PM
    #385
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    I think that's a great, safe budget to get quality parts.
    georgiey22 and wwinslett[QUOTED] like this.
  26. Jul 15, 2019 at 5:40 AM
    #386
    wwinslett
    Will
    Birmingham AL
    6112s top setting
    Toytec Boss Rear Shocks
    Toytec Shackles Middle Hole
    18" Method NVs +25 ET
    Nitto Ridge Grappler 295/70/18
    Also went with the differential drop kit in the front for cheap insurance.
    Love the stance and the ride. I have no regrets about the upgrade. Ride is good and smooth.
  27. Jul 15, 2019 at 8:16 AM
    #387
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    I’m sure it’s on here somewhere, but what total lift do your get with the 6112 top setting?
  28. Jul 15, 2019 at 8:21 AM
    #388
    MistrRoboto
    Virginia Beach, VA
    .75
    1.3
    1.9
    2.5
  29. Jul 15, 2019 at 8:23 AM
    #389
    canadianguy
    Kevin
    That’s ground to fender gains or just on coil over?
  30. Jul 15, 2019 at 8:26 AM
    #390
    MistrRoboto
    Virginia Beach, VA
    On the second from top setting I measured 1.9in gain from the top of my tire to wheel well. So I believe for your question - that would be ground to fender gains.
