6112 questions.
Discussion in 'Suspension' started by Rngr188, Nov 21, 2017.
  1. Nov 21, 2017 at 6:29 PM
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I'm thinking of picking my fromt end up just a little and was considering the 6112 at the 1.9 setting with 275/70/r18 on my 2017 TRD OR. Do the Tundras have lean like the Tacos, in other words will I need a shim on one side? As for rears I only realy just hit some gravel back roads that occasionally have some hairy spots here in the Ozark Mountains so I was thinking 5100 over 5160 and no rear lift. Does this sound like a good plan? Also should I get a diff drop to be safe or not? Thanks.
    SouthBoundSteve likes this.
  2. Nov 21, 2017 at 6:35 PM
    TheBeast The Beach
    yes driver side sits a bit lower due to gas tank that side
  3. Nov 21, 2017 at 6:48 PM
    Rngr188
    Chad
    Harrison AR
    So to correct lean I might need a shim on the drivers side? What size 1/4"?
  4. Nov 21, 2017 at 6:50 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    Just measure your truck and see if you have the lean. My 17 did not have a lean.
  5. Nov 21, 2017 at 6:50 PM
    TheBeast The Beach
    depends. I think I'm at slightly less than 1/2" right now. Need to add couple turns to my coil over. Or a shim.
  6. Nov 21, 2017 at 7:07 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    6112's at 1.9 setting here, added 1 cb shim on driver's side
    MotoTundra likes this.
  7. Nov 21, 2017 at 7:49 PM
    BayRunner
    2017 Tundra Platinum
    Installed the 6112 at 1.9" about a month ago on my '17 Plat with no shim. Looks and rides great.
  8. Nov 21, 2017 at 7:54 PM
    Rngr188
    Chad
    Harrison AR
    Guys with the 1.9 setting are you running anything in the rear?
  9. Nov 21, 2017 at 8:04 PM
    BayRunner
    I put the 5160's on the rear to serve as an equalizer to the front 6112s. No shackles on the rear. Just leveled the front at 1.9.
  10. Nov 22, 2017 at 4:28 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    Coachbuilder +3 shackles and ome sport shocks for the rear, but i tow alot and don't mind the rake.
  11. Dec 11, 2017 at 4:49 PM
    Rngr188
    Chad
    Harrison AR
    Now I'm wondering if I should do 5100 all the way around with the front on the middle setting and a driver's side shim. The only offroading I do is occasional gravel roads with some larger chunk rocks. I'm wondering if the 6112 would be overkill for my driving. I still want 275/70r18 on my factory TRD OR wheels and a level stance. The price difference between 5100 all the way around and 6112 with 5100 rear is pretty substanial for what I plan to do. What say you guys? I know the go all out mentality and that' normally my way of thinking but I'm starting to think I don't need the 6112 and the savings can go toward tires. Am I thinking sensable here?
  12. Dec 11, 2017 at 5:10 PM
    nowayout
    nowayout New Member
    NY
    17 CM
  13. Dec 11, 2017 at 5:16 PM
    Rngr188
    Chad
    Harrison AR
    Yea I was looking at those but would still need at least a 5100 or 5160 for the rear. With a pair of 5100 I'd be around $890 and 5160 around $1,100 plus install and alignment (I'll do rears myself). That's what's got me thinking 5100 all the way around for my minimal off road needs.
    http://www.boss4x4s.com/BOSSED-Out-...-Package-with-Diff-Drop-Spacer-Kit_p_464.html
    DaBoro54 likes this.
  14. Dec 11, 2017 at 5:28 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    I was in the same boat but was also considering the boss kit , to me that was overkill for what i needed so went with the 6112's as a happy medium and have not regretted it. Heard a few stories of 5100's leaking and what not so that made up my mind, not to mention 6112's come with new coils, are massive and can be bought preassembled making install a breeze. Imo if you plan on keeping the truck for any amount of time I'd go with the 6112's if not 5100's will do just fine.:thumbsup:
  15. Dec 11, 2017 at 5:28 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    If you think you will be happy with the 5100 go for it. It definitely is a big $$$ difference but I also think the ride will be too. Why not install the whole kit yourself?
    Casper3 likes this.
  16. Dec 11, 2017 at 5:31 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    Purchased mine from them, good guys to deal with.
  17. Dec 11, 2017 at 5:32 PM
    Rngr188
    Chad
    Harrison AR
    Considered insalling a preassemled 6112 kit myself but I don' have the proper tools (impact and big enough compressor for example) so thought having either 5100 or 6112 installed would be about as much as buying the tools
  18. Dec 11, 2017 at 5:43 PM
    Rngr188
    Chad
    Harrison AR
    Maybe i should just wait a little bit to save the extra coin and get the 6112 preassemled at 1.9 with 5100 rears. I'm just kind of anxous to do something soon but probably should wait and do it right. I'm still just wondering if 5100 all the way around would suit my needs, give me the stance I want, and save me some $$.
    Casper3 likes this.
  19. Dec 11, 2017 at 5:49 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    Only thing I used impact for was the lugs, install is pretty straightforward with basic tool's.
  20. Dec 11, 2017 at 5:55 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    i did the same thing and am also happy.
  21. Dec 11, 2017 at 6:31 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Same here. Toughest one to break loose is the lower shock bolt. I believe torque on it is 130.
  22. Dec 11, 2017 at 6:42 PM
    Zero One Actual
    @BOSS4x4s.
    What's your opinion on this sir?
  23. Dec 11, 2017 at 7:07 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    Why not just get the 6112's set at 1.9 and wait on the 5100 rear shocks.That will say some coin
    Casper3 likes this.
  24. Dec 12, 2017 at 5:06 PM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    So....is the 1.9 the middle setting?
  25. Dec 12, 2017 at 5:09 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    3rd setting one from top
    Mr Swervlin likes this.
  26. Dec 12, 2017 at 5:12 PM
    Mr Swervlin
    O H I O
    So the total lift on a 6112 at top setting is 2.5?
  27. Dec 12, 2017 at 5:14 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    Yeah give or take, every truck is different tho but should be close after settling
  28. Dec 12, 2017 at 5:42 PM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    My 6112s arrived. They are beefy as hell, can't wait to get these things on.
    Casper3 likes this.
  29. Dec 12, 2017 at 5:48 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    :headbang:
  30. Dec 12, 2017 at 5:58 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 Gasser
    Sub'd... I'm interested to see what you end up with as I'm eventually going to do something similar. I had 5100s all around on my old Titan on the middle setting up front and the ride wasn't bad at all--I was coming from almost-blown-out shocks before, though...
    I hate to upgrade shocks on my brand new '18 already since I feel like I basically just paid for "new" shocks when I bought the truck.
