6112 and 5160’s on their way
Discussion in 'Suspension' started by Bjhughe2, Aug 6, 2018.
  1. Aug 6, 2018 at 4:13 PM
    Bjhughe2
    Bjhughe2 [OP] New Member
    Brandon
    Illinois
    2018 tundra limited
    Shocks are on the way! Can’t decide what setting? Second or 3rd? Thinking 2nd because I have a 2018 with safety sense and not wanting to run into any problems with the sensing. Any pics out there with second and 3rd setting might help.
    Tsoot, jtwags, 15whtrd and 2 others like this.
  2. Aug 6, 2018 at 4:54 PM
    Blueknights75
    Ron
    Clayton, NC
  3. Aug 6, 2018 at 6:48 PM
    Borgs
    Borgs New Member
    PA
    Same setup. 1.9 up front.
  4. Aug 6, 2018 at 6:51 PM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    When I do this I will probably go with the 2nd setting.. I have a cap on and usually carry a bit of weight in the bed.. I hate the look of the reverse rake that some have upon acceleration when truck is dead level.. friend has it on his dead level and it looks reversed at times
    Bjhughe2[OP] likes this.
  5. Aug 6, 2018 at 7:09 PM
    ARES
    ARES ARES Fabrications
    God Bless America
    2018 Tundra TRD Cement
    I did 3rd setting on my 6112 up front 1.9. And 5160 rear. You will be amazed at how much better the truck rides. Its definitely better then stock.
  6. Aug 6, 2018 at 7:59 PM
    GreatAvalon
    GreatAvalon New Member
    2016 Tundra Limited DC
    I'd do 2nd setting because I like a little forward rake. Like the other guy said, dead level ends up being front higher than rear too often for my tastes. But just my preference.
    Spitfire and Bjhughe2[OP] like this.
  7. Aug 7, 2018 at 8:59 AM
    phonyteachr
    phonyteachr New Member
    2018 SR5 TRD off-road CM
    I have 6112s coming set on 3rd setting...hoping for level. Shouldn't be a sensing problem..keep all posted.
  8. Aug 7, 2018 at 9:15 AM
    TheTripleLindy
    TheTripleLindy New Member
    I have it at 3rd setting. 2.5 inches. Truck is still about 1/2 inch lower on front.
    equin likes this.
  9. Aug 7, 2018 at 10:33 AM
    phonyteachr
    Looks good! What year, any safety sense issues?
  10. Aug 7, 2018 at 10:36 AM
    TheTripleLindy
    2018; no safety sense issues so far. just took it on a 600 mile round trip, not a problem so far.
    phonyteachr likes this.
  11. Aug 7, 2018 at 11:13 AM
    Borgs
    Borgs New Member
    PA
    I do have a slight bro lean when the back is loaded down. I assume pulling a trailer or boat it will be even worse.
  12. Aug 9, 2018 at 2:34 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Interesting how your 3rd setting is providing 2.5” of lift. I understand the top setting is supposed to net 2.5” of lift while the 3rd setting is supposed to net 1.9” of lift. Did you measure after they had settled down? Also, is yours 2wd or 4x4?
  13. Aug 9, 2018 at 2:49 PM
    TheTripleLindy
    top setting, 4 wheel drive, no on settled measure
    equin likes this.
  14. Aug 9, 2018 at 3:31 PM
    Blueknights75
    Ron
    Clayton, NC
    Where did you purchase these? Did you do a diff drop?
  15. Aug 9, 2018 at 4:06 PM
    Borgs
    Borgs New Member
    PA
    Same setup for me. No diff drop. Got them from 4wheelpArts
    Blueknights75[QUOTED] likes this.
  16. Aug 9, 2018 at 4:06 PM
    phonyteachr
    Top setting or 3rd setting? Thought top did 2.5 and 3rd did 1.9? Also stock or upgraded UCA's? Any trouble with alignment?? Thanks.
  17. Aug 9, 2018 at 4:08 PM
    phonyteachr
    Top setting or 3rd setting? Stocks UCA's? Any alignment troubles?
  18. Aug 9, 2018 at 5:29 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
  19. Aug 9, 2018 at 5:31 PM
    equin
    Ed
    DFW, TX
    Ok, thanks for the reply.
  20. Aug 9, 2018 at 5:50 PM
    Blueknights75
    Ron
    Clayton, NC
    What size tires you running? Any rubbing? Looks good!!
    ARES[QUOTED] likes this.
  21. Aug 10, 2018 at 3:13 AM
    ARES
    God Bless America
    I am running the 20" TSS rims that are offered in the texas region. Tires are 285x55x20 bfg k02. Suspension is just leveled on 3rd setting. My truck is perfectly level if I would have done the top setting I woud had to do a shackle in the rear
  22. Aug 10, 2018 at 5:48 AM
    phonyteachr
    A
    Any issues with alignment....did u change UCA'S? Differential drop kit??
  23. Aug 10, 2018 at 6:13 AM
    Razorwyre
    Razorwyre New Member
    2018 Tundra Platinum
    How would you describe the change in ride? I have the same wheels with 295/55r20, and I find the ride with a stock 2018 platinum to be a bit harsh when I go over uneven pavement and expansion joints.
  24. Aug 10, 2018 at 7:18 AM
    ARES
    God Bless America
    Stock ucas. Anything under 3in lift I would say stock ucas are fine. And diff drop would not be neccessary. No issues with alignment. I will advise having a reputable 4x4 shop do the alignment because I did not have luck having the dealership doing it they screwed it up
    phonyteachr[QUOTED] likes this.
  25. Aug 10, 2018 at 7:19 AM
    ARES
    God Bless America
    What tire pressure are you running? I will say after the bilstein 6112 and 5160 install the truck rides and handles x1000 better then stock. Now the 5100s front and rear I cannot comment on but I have heard they also make the ride better then stock.
    I went with the 6112 and 5160s because I do go offroad a bit. Especially during hunting seasons
    Bjhughe2[OP] and Spitfire like this.
  26. Aug 10, 2018 at 7:48 AM
    Spitfire
    Spitfire New Member
    Long Island
    I have to do this.. debating whether to color match first
  27. Aug 16, 2018 at 2:31 PM
    Bjhughe2
    Brandon
    Illinois
    2018 tundra limited
    Got the bilsteins installed today! Went with 2nd setting 1.3 front lift. As it sits now it looks perfectly level. Hoping the shocks we’ll settle a little in the front. Love the way it looks but wanting a little rake when I tow
    jtwags and equin like this.
