6112 and 5100 on rear
Discussion in 'Suspension' started by brybasack, Feb 20, 2020.
  1. Feb 20, 2020 at 5:28 PM
    brybasack
    brybasack [OP] New Member
    brian
    2007 crewmax
    Ok. I read pretty much every thread and I think I’m making the right choice. I ordered 6112’s on highest setting and want to put toyotec 1-1.5” shackles Also. Can I use 5100 shocks on rear with the shackles? Or should I bite the bullet and get the 5160’s? I will be towing a boat (9000) lbs and enclosed Mx trailer. Thanks
  2. Feb 20, 2020 at 5:32 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I’d get a rear shock that will accommodate that lift 5100s I think are good up to an inch but I could be wrong. Are you off roading and flexing a bunch? If not you will be ok with either one honestly. You are just limiting the travel. So I guess buy once and do it right if you are particular about that.
    Tundyfundy likes this.
  3. Feb 20, 2020 at 6:33 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I'm running 6112/5100.
  4. Feb 21, 2020 at 2:37 AM
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    Just purchased same combo
    r1-superstar[QUOTED] likes this.
  5. Feb 21, 2020 at 3:10 AM
    brybasack
    brian
    2007 crewmax
    R1 do you have shackles?I just wanna make sure that they’re going to sit. I don’t do too much off roading where I’m gonna be flying down fire roads but I want to make sure they fit and smooth out the ride nice. From reading Sounds like they are better than stock
  6. Feb 21, 2020 at 6:11 AM
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    Well from what I'm reading the 5100's only allow 1" of lift. The 5160's allow for 1.5" lift. Top setting on the 6112 is 2.5". IDK what the rake of the truck is, as I haven't measured it yet, but if you go with highest setting 6112 and the 5100 at 1", you'll be offsetting 1.5" towards the front. I'm also not sure what rake you are required to have for TSS to still work, someone with some more knowledge on this point will chime in, but with how much you'll be towing, I'd want to get the rear up higher. Go for the 5160's
  7. Feb 21, 2020 at 8:51 AM
    brybasack
    brian
    2007 crewmax
    What is TSS? I have an 07. Im reading its a safety package.
  8. Feb 21, 2020 at 8:58 AM
    Tundyfundy
    Southern California
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    5160 has 1 inch more travel than stock. With that being said a shackle would give you the most out of your suspension. Also you need it if youre going to raise the front 3 inches unless you like the prerunner look.
  9. Feb 21, 2020 at 9:00 AM
    mech_engineer09
    Ohio/Pennsylvania
    2020 MGM Platinum
    My bad I didn't read you have an 07. so you don't have to worry about the safety sense not working without a rake.
  10. Feb 24, 2020 at 9:47 PM
    r1-superstar
    DB
    UTAH
    Yes, @BOSS4x4s shackles on the top setting (2").
  11. Feb 24, 2020 at 9:49 PM
    r1-superstar
    DB
    UTAH
    They will allow for 2" of lift.
    https://www.readylift.com/toyota/bi...XepcBMTD_YcKMePjtbuk4k1BMj2-dtExoC9P8QAvD_BwE
  12. Feb 24, 2020 at 9:52 PM
    r1-superstar
    DB
    UTAH
    6112 top setting, shims, and 5100 with shackles at 2"...
    Cpa757va, Rica25 and Dag3 like this.
  13. Feb 25, 2020 at 3:38 AM
    Tundyfundy
    Southern California
    There is no adjustment for rear shocks on 5100 or 5160. It’s the shackles that will give him rear lift and determine ride height. The rear shocks have different travel lengths but as long as you only change the rear shocks ride height will remain the same regardless of which shock he uses. With that being said intow a heavy load often (7000 lbs or so) and I love my 5160 as opposed to 5100. They stay cooler longer and have less fade over long trips due to the reservoir.
    Rica25 likes this.
  14. Feb 25, 2020 at 6:53 AM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    So if you don't tow at all, it's no point in getting the 5160?
    Rica25 likes this.
  15. Feb 25, 2020 at 7:41 AM
    Mdjamesd
    Mdjamesd New Member
    2015 Silver Sky Crewmax
    They look a lot cooler. I splurged for the 5160's when I bought my 6112's, which i have yet to install
    Rica25 and Tundyfundy like this.
  16. Feb 25, 2020 at 11:49 AM
    Tundyfundy
    Southern California
    If you don’t tow and or don’t off-road so much you’ll probably be happy with the 5100. Someone will correct me but I believe the 5160 is just ab5100 with a reservoir.
    Rica25 and paradizecityz[QUOTED] like this.
  17. Feb 25, 2020 at 1:00 PM
    Rica25
    Ricardo
    Tulare
    That correct
  18. Feb 29, 2020 at 9:36 AM
    Mdjamesd
    Mdjamesd New Member
    I will say that when I replaced the factory TRD OR shocks with the 5160's, noticed a night and day difference
