6 week old tundra, serious front end issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by freqsounds, May 4, 2015.
  1. Jun 22, 2015 at 12:10 PM
    #61
    :crapstorm:
  2. Jun 22, 2015 at 7:57 PM
    #62
    freqsounds
    freqsounds [OP] New Member
    Pete
    2015 Tundra SR5 TRD
    3" lift, 20" Moto Metal rims, Pioneer AVIC-8100NEX
    I forgot something!!
    When I dropped off my truck to the "winning dealership", they did a little research on the truck and noticed that a claim had been filed with Toyota's Road Hazard warranty. Sure enough, it was approved, not only for the tire, but the rim too. Already paid out. But my truck has the original tire and rim on it. :notsure: There was serious confusion on what had/hadn't been done. I am just as confused as they were. No rim, no tire. Most importantly, no phone calls. So where are my parts??
    I stopped by the "winning dealership" after work today. I talked with a few people. All seemed to be especially helpful and concerned with the issue. I even played back a couple recordings and showed some pictures. Their responses resembled that of staring at the TV screen, witnessing 9/11. All were in disbelief that the dealership could treat a customer the way they did.
    They've asked me to gather all my information up to see what they can do for me.
    In doing that, I came across this photo:
    Notice the green marks on the eccentric cam...
    The left symbolizes where it's at now. The right resembles where it was before they took it apart.
    So what's the problem??
    The problem is the angle that the cam is positioned. That cam is turned more than 90º from its home position.
    When that control arm slammed into the chassis, the cam would have rotated counter-clockwise, not clockwise. Those markings on the cam should be pointing down, not up. The eccentric tabs would have pushed the cam counter-clockwise.
    What does this tell us?
    This tells us that the truck was taken apart before the markings were made on the cam. There is no plausible way for the cam to be in that position with markings 1/4" apart without being put in that position.
    Black Wolf likes this.
  3. Jun 22, 2015 at 8:02 PM
    #63
    This is getting as good as Matlock or Murder She Wrote. Looks like you are getting closer to a resolution. I'm going to put some popcorn in the micro now.
    tat2ude39 likes this.
  4. Jun 22, 2015 at 8:17 PM
    #64
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Winning
  5. Jun 23, 2015 at 1:06 PM
    #65
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    Tough situation.....I would not think that it is Toyota's issue as the front suspension is not stock. As Toyota does not do aftermarket lifts on new trucks it would be on the dealer who had the suspension work done. My guess would be as was stated a while back, that someone did not tighten things up when the lift was done, and your evasive maneuver allowed things to shift. My bet is that this will be a fight between you, the insurance, and the dealer. Any help on Toyota's part would be simple for customer relations due to the altered suspension. Good luck in your quest.
  6. Jun 23, 2015 at 8:36 PM
    #66
    racervx54
    racervx54 New Member
    2015 trd pro inferno
    FYI that's who does most of the lifts for toyota dealers. I would not take it there.
  7. Jul 20, 2015 at 7:58 AM
    #67
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  8. Aug 11, 2015 at 10:17 PM
    #68
    brian y
    brian y New Member
    Central Oregon
    2019 Smoked Mesquite Tundra 1794 Edition CrewMax TRD
    So what ever happened with this?, Any one?
  9. Aug 12, 2015 at 7:31 AM
    #69
    GQ 66
    GQ 66 (Input clever saying)
    Lake Jackson, TX
    2014 CM Limited
    Tinted Tails, hard wired passport escort, Magnaflow 50 series,
    :popcorn:............
  10. Aug 14, 2015 at 10:01 PM
    #70
    csuviper
    Broomfield, CO
  11. Aug 15, 2015 at 6:21 AM
    #71
    Flobrandx
    Flobrandx New Member
    Brandon
    2015 TRD PRO
    Working on them now...
    Wow this is thread is like a CSI episode. Sorry that you're having to go through all this @freqsounds. Hopefully that dealer gets what they deserve and you get a replacement truck as you should.
    I had an experience with my previous Tundra concerning the leveling kit install and it pulling to the right. First I go pick up the truck and take it home after the leveling kit, tires and wheels were supposed to be installed but since I was in a hurry I didn't look underneath as I assumed all was good... After driving home the tires rubbed (which I specifically said make sure they dont) and I looked underneath and they didn't install the leveling kit. So, I had to go back and have it installed but there was still a slight rub and the truck pulled excessively to the right. I had it re-alligned 3 times but they couldnt fix it and said it was due to the tires. I've never had that issue with any other truck? I decided to buy the Pro and not deal with aftermarket suspension issues this time around.
    Anyway... this doesn't compare to your issue but I can somewhat understand your frustration with whats going on. Good Luck!
  12. Aug 15, 2015 at 6:34 AM
    #72
    dandailey
    Dan D
    Newport News Va.
    He hasn't posted anything here since July 9th.
    We may never find out the outcome...
    rons23 likes this.
  13. Aug 15, 2015 at 6:42 AM
    #73
    Flobrandx
    Brandon
    2015 TRD PRO
    noooooooooooooo! we need closure and to find out that he beat them
  14. Aug 15, 2015 at 8:08 AM
    #74
    Flobrandx likes this.
  15. Aug 15, 2015 at 8:12 AM
    #75
    Mike Tread lightly.
    south carolina
    Maybe no update yet to report. These things take time.
  16. Sep 11, 2015 at 2:18 AM
    #76
    T_dublecab14
    T_dublecab14 New Member
    RC
    2014 doublecab 4x4
    TRD
    so am I to believe that even though you buy the tire n wheel warranty it does not cover road hazard ?
  17. Sep 11, 2015 at 6:55 AM
    #77
    csuviper
    Broomfield, CO
    Definitely want to hear some closure on this case. Maybe do some digging around to see if he is updating on other forums or Facebook.
  18. Sep 11, 2015 at 7:00 AM
    #78
    csuviper
    Broomfield, CO
    No luck with quick search. Maybe deployed?
  19. Oct 19, 2015 at 12:21 AM
    #79
    markjeff880
    markjeff880 New Member
    IMO, Full litigation is happening, OP has been told to stay off the forums. OR I nicer thought, ToyCorp replaced the truck and OP signed an NDA.
    SouthBoundSteve likes this.
  20. Oct 19, 2015 at 5:02 AM
    #80
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    This.
  21. Oct 19, 2015 at 6:11 AM
    #81
    Armyretired
    Armyretired New Member
    2006 TACO
    3in Lift
    WHAT?!?!?! What happen? :annoyed:
  22. Oct 19, 2015 at 3:15 PM
    #82
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
  23. Oct 19, 2015 at 7:36 PM
    #83
    MicahB
    MicahB New Member
    Southeast VA
    2014 Tundra 5.7 4x4
    None...yet
    I have heard nothing but bad things from the Priority Toyota, actually the group in general. Shady company and bad rep for warranty repairs. Also Pungo off-road or Eastern Off-road are 2 major players for the area in lifts. I have not heard anything from Andy Fox yet on wavy 10 so maybe it's resolved. Would have taken it to First Team Toyota. Their great with QC and customer service relations. Hopefully you didn't use Lowell "the hammer" Stanley as your attorney .
  24. Oct 19, 2015 at 8:00 PM
    #84
    csuviper
    Broomfield, CO
    Lol guessing that is a tv attorney
