6" lift, what do I need to know?
Discussion in 'Suspension' started by Gatorbisquit, Dec 9, 2018.
  1. Dec 9, 2018 at 11:47 AM
    Gatorbisquit
    Gatorbisquit [OP] New Member
    WNY
    2007 black SR5 Tundra
    None yet, just got it. Working in customizing it
    I'm looking to put a 6" lift on my 07 double-cab, is there anything i need to know other than I can't use the factory 18" rims lol
    thanks for any help!
  2. Dec 9, 2018 at 12:14 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    you’ll have to get the crossmember cut
    Your turning radius will be affected
    Don’t get the spacer lift, get the coilovers. You’ll be better off.
  3. Dec 9, 2018 at 12:15 PM
    Ditto ^
    Law323 and Les7311 like this.
  4. Dec 9, 2018 at 1:17 PM
    Gatorbisquit
    WNY
    I was gonna do the RBP suspension lift. And replace the factory rims with 20x9 (or 10) tires with either the 0 or -12 offset with at least 4 1/2" backspace. Would that be ok in your opinion? Or would I be better off with a 3" - 4 1/2" lift?
  5. Dec 9, 2018 at 2:16 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I’m honestly more comfortable with a 3-4.5” lift either way. Less things to cut/replace and less things are affected.
    Do what you really want to do. There are plenty of guys running their 6” and up lifts that are happy with them
    0 and -12 offsets will require some chipping though.
    Les7311 likes this.
  6. Dec 9, 2018 at 3:04 PM
    Gatorbisquit
    WNY
    When your say "chipping" what do you mean?
  7. Dec 9, 2018 at 3:07 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Once you "cut"....not easy to change your mind...
    Law323 likes this.
  8. Dec 9, 2018 at 3:14 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I
    meant chopping. Gotta love autocorrect.
  9. Dec 9, 2018 at 3:15 PM
    Gatorbisquit
    WNY
    So what tire size would y'all recommend with 4 1/2" lift?
  10. Dec 9, 2018 at 4:15 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    35. No smaller.
  11. Dec 9, 2018 at 5:58 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    35-37’s, I’d lean more towards 37’s if it were me.
    Law323 likes this.
  12. Dec 9, 2018 at 6:52 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    You 4x4 ?
  13. Dec 10, 2018 at 8:42 AM
    Gatorbisquit
    WNY
    JSena .yes 4x4
    Jsena likes this.
  14. Dec 10, 2018 at 8:44 AM
    Gatorbisquit
    WNY
    So would I better off going with a 3" lift and run 35" tires? From what I'm reading anything from 4 1/2" ⬆️ there's cutting of the cross member involved either way, is that right?
    Tundra_361 and zcarpenter92 like this.
  15. Dec 10, 2018 at 8:47 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I'm on 3/1.5" lift with 37x12.5 tires on 20x9 +20mm offset wheels. Same ground clearance as 6" lift.
  16. Dec 10, 2018 at 8:48 AM
    Gatorbisquit
    WNY
    Matictundra, any rubbing? And did you cut cross member?
  17. Dec 10, 2018 at 8:50 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    You will be 100% better off with a coilover lift. It will handle better, ride better, and you will have much better use of your 4X4 if that's important to you.
  18. Dec 10, 2018 at 8:55 AM
    matictundra
    Franco
    AZ
    Nope, just coilover and shackle swap. I used Bilstein 6112 at top setting and a CB shim for the front and Toytec shackles and Bilstein 5160 for the rear. No rubbing after some minor trimming, circled in green. This was my 1st time cutting metal.
    Rica25, aperezsh and careyrob like this.
  19. Dec 10, 2018 at 8:57 AM
    Gatorbisquit
    WNY
    It doesn't look like you cut that much out lol
  20. Dec 10, 2018 at 9:46 AM
    Mwray8909
    Chino Valley
    All this 37 s talk is really pushing me towards that direction
  21. Dec 10, 2018 at 9:53 AM
    matictundra
    Franco
    AZ
    Do it....
    Rica25 likes this.
  22. Dec 10, 2018 at 9:55 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Go woth the 6 inch lift.. when you get that done, you won’t be thinking of changing it. It will look Bad ass!!! Do it!!! 37’s bro. 35’s are everywhere . Be a little different
  23. Dec 10, 2018 at 9:57 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  24. Dec 10, 2018 at 11:06 AM
    Ostrich
    Ostrich One bit me once.
    Nikki
    Marion, Texas
    2014 MGM Crewmax SR5 4x4
    3/1 level, black leather, raptor style grille
    Rica25 likes this.
  25. Dec 10, 2018 at 12:02 PM
    Believe Fabtec has a 4" kit no cutting of RCM
  26. Dec 10, 2018 at 12:08 PM
    I bought my Tundra used, and it has a 6" lift, on 35's with 20x10 wheels, lift is from RC, spoke with techs, appartenly version I have is an older kit, cause my RCM is not cut as per the instructions, yeah it looks cool, but ride quality sucks, turning radius decreases, technically I can take this kit off n go with something smaller, but I need most OEM parts back, I'd stick with something smaller IMHO, good luck on your search
  27. Dec 10, 2018 at 8:09 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    :mad: I've enjoyed 35's with a 3/2 leveling kit for a couple years now and for a few weeks I've been wondering what it would take to fit 37's. I had resigned myself to just accepting that anything more than 35's was too involved.
    @matictundra
    You may have just cost me a bunch of money that I've got no business spending right now.
    :smash:
    Are you using the CB spacer on top of the 6112's? If so that sounds like a bit much for the rest of the stock geometry and CVs to live up to. Can you clarify what front CB spacer you're using?
  28. Dec 11, 2018 at 8:02 AM
    matictundra
    Franco
    AZ
    Bilstein 6112 will only get you to 2.5". I added a coachbuilder (CB) spacer to get me to 3.0" lift, you can also use Toytec spacer (both are 1/4" thick aluminum). 3.0" lift would be the limit for CV's but I also added differential drop to help out with the drive line geometry.
  29. Dec 11, 2018 at 10:35 AM
    careyrob
    Carey
    Massachusetts
    So aside from having reduced shock travel, my Low Range Off Road 3/1 leveling kit should have the same suspension geometry as your setup.
    I'll need to regear and finish my DIY truckvault first, but then it's time for 37's!
  30. Dec 11, 2018 at 10:39 AM
    matictundra
    Franco
    AZ
    Pretty close. I was originally on 3/1 budget spacer lift until I completely converted to 3/1.5" last summer. I haven't regear yet but already on 37's, tow mode makes up 85% loss of power. I do plan on regearing next spring.
