6 Inch Lift Kit Response only - Need Help!
Discussion in 'Suspension' started by Les7311, Feb 24, 2017.
  1. Feb 24, 2017 at 12:58 PM
    Les7311
    Les7311 [OP] Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Help!
    6-inch Lift kit installed on OEM front Struts, yet truck front bounce with a wobble between 40 - 45 mph, then smooth out at 50 and higher....
    Rough Country says the OEM front Struts will cause the bounce, and need to replace due to the lift.
    Did you, if you installed the 6 inch lift, had to replace the front OEM struts? Did you experience this same bouncy-issues?
  2. Feb 24, 2017 at 1:29 PM
    My truck came already with RC 6" lift has stock struts no issues... Balance rotate tires front end alignment???
  3. Feb 24, 2017 at 3:54 PM
    Les7311
    Wearing 20 x 35 tires. Alignment is dead on x 2 checks. Shop says pull to left is more so due to aggressive thread. Switching front tires left to right is next option.
    Looking for the fix
  4. Feb 24, 2017 at 4:32 PM
    I have 35*12.50*20s hope u get fixed soon
  5. Feb 24, 2017 at 4:42 PM
    Les7311
    Well all suggestions are pointing to the front OEM shocks. I may just order the rough Country but want some more feedback what else am missing.
  6. Feb 24, 2017 at 5:11 PM
    Sure someone else will chime in
