6 inch lift...... 5 inch blocks anybody?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cement1, Feb 9, 2019.
  1. Feb 10, 2019 at 6:51 AM
    15whtrd
    15whtrd Mr. Blonde
    I wonder how much wheel hop you get with a 5 inch lift block. Because I get wheel hop with no block.
    TXRailRoadBandit73 likes this.
  2. Feb 10, 2019 at 9:48 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Remember a +3 shackle only gives about 1.6 inches of lift. You are moving half of the spring down.
    1BadTundra[QUOTED] likes this.
  3. Feb 10, 2019 at 9:51 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    This.
  4. Feb 10, 2019 at 9:58 AM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    @Cement1 i do have a set of blocks they are 4.75 tall came off a F-350. They are about .5 longer than what lift blocks we used for our lift. If you like I will give them to you if you go that route.
  5. Feb 10, 2019 at 10:08 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    You should just add a 3” block on top of the 4” block for good measure. Incase the blocks settle a little
    15Yota, cantle and Cement1[OP] like this.
  6. Feb 10, 2019 at 12:10 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    E8E520B3-EEA7-469E-84A5-A1DF947188FD.jpg 3BA41632-C339-4142-9B0F-711DBADCA556.jpg D4E8FD52-6D16-4BF3-A3C2-4597ADD4B7F1.jpg
    3BA41632-C339-4142-9B0F-711DBADCA556.jpg 3BA41632-C339-4142-9B0F-711DBADCA556.jpg D4E8FD52-6D16-4BF3-A3C2-4597ADD4B7F1.jpg the first photo is before the springs settled but once it settled everything evened out! Also with the new leaf springs, the truck will NEVER bottom out with heavy weight, before it would bottom out with like 400 pounds! Now with 2000 it still won’t bottom out, but that’s thanks to the kings as well!
  7. Feb 10, 2019 at 1:58 PM
    Cement1
    Cement1 [OP] New Member
    2019 Tundra Limited
    So are you dead level now or do you have a slight rake?
  8. Feb 10, 2019 at 1:58 PM
    Cement1
    2019 Tundra Limited
    You think they will work on our trucks?
  9. Feb 10, 2019 at 2:00 PM
    Cement1
    2019 Tundra Limited
    So I’m not really familiar with shackles or how they work. I’m gonna google them...lol. But your saying I can use 1 inch shackles with my 4 inch blocks and gain a half an inch correct?
  10. Feb 10, 2019 at 2:06 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I think you might be focusing to much on the actual size of the shackle...Just go find a shackle that will increase you 1 inch...And then your done..Have it installed or do it yourself and you will increase 1 inch...
  11. Feb 10, 2019 at 2:09 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    1BadTundra likes this.
  12. Feb 10, 2019 at 2:28 PM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    jeremyd[QUOTED] likes this.
  13. Feb 10, 2019 at 2:28 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    And if you wanna see them on a 2014 Tundra, They are set on the 1 inch holes..
    Prostar 190 and 1BadTundra like this.
  14. Feb 10, 2019 at 2:29 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    lol, it's also what I've had on mine for 5 years.
  15. Feb 10, 2019 at 4:49 PM
    Cement1
    2019 Tundra Limited
    Got it, I see now. They connect the end of the leaf springs to the frame and going with longer ones gives you more lift. Thanks for the pics man!
    jeremyd likes this.
