6.0L Stroker Discussion
Discussion in 'Performance and Tuning' started by Jowett, Feb 5, 2024.
  1. Dec 10, 2024 at 5:32 AM
    #61
    BRX
    BRX New Member
    Abdulla
    What you will need is a Dodge 8HP70/90/95, an adapter plate for both housing and TC (available at Domiworks), a TCU that is compatible with your ECU (Turbolamik is the most flexible and can do analog sensors if needed), I used the stock Dodge Charger/Challenger transmount with an adapter plate made locally, Engine management doesn't matter as long as it's compatible with the TCU or can control the transmission as well.
    You can get a wiring harness for the Lamik but you will also need to solder in a PCB in the Mechatronics of the transmission. Some other TCUs don't require that like CANTCU but they currently only officially support BMW 8HPs.
    That was my first option as well. However it had a few fallbacks in my case.
    First it only comes in AWD, no easy way to convert it to 2WD as there is no 2WD tail housing.
    Second, there is no aftermarket support however from what I've seen and been told, with only a tune the AE80 can handle 1000HP for awhile before failing. A few guys got it to slip at about 1200HP. My future HP goals are around 1500 so it would have been a gamble.
    Third, until recently there was no way to control the AE80. The AA80, which from looking at the wiring diagrams is basically the same transmission in terms of functionality, was recently able to be controlled using a Haltech Nexus ECU.
  2. Dec 10, 2024 at 1:08 PM
    #62
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Would the 4x4 still be retained with the Dodge the trans unit? I don't see why not?
    What ECU are you running?
  3. Dec 10, 2024 at 2:17 PM
    #63
    BRX
    BRX New Member
    Abdulla
    You can either request Domiworks to make an adapter for the Tundra transfer case and a Dodge AWD transmission or if you don't care about 2WD, keep the Dodge AWD transfercase that bolts right to it.
    I'm using a Haltech Elite 2500 ECU.
    Abell207 and reywcms[QUOTED] like this.
  4. Dec 11, 2024 at 12:25 AM
    #64
    j_supra
    j_supra Dreamin about boooost!
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    Could a 8hp75 out of a ram 1500 be used to maintain 4x4?
  5. Dec 11, 2024 at 6:14 AM
    #65
    BRX
    BRX New Member
    Abdulla
    I don't see why not. Just make sure the housing matches the adapter as Chrysler has a few different variants.
  6. Dec 31, 2024 at 8:02 AM
    #66
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    ZPhilip, Mdl and reywcms like this.
  7. Apr 13, 2025 at 7:56 AM
    #67
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    This is amazing, and I'm wanting to do the same. Did you use the Domiworks adapter with the ZF 8HP90? I'm planning on using the CANTCU integrated with a Haltech 2500 to control it.
    I've been in communication with CANTCU, and they say you can use the Dodge transmissions but the TCM needs to be bench flashed with BMW-based software first.
  8. Apr 13, 2025 at 11:27 PM
    #68
    BRX
    BRX New Member
    Abdulla
    Yes, I worked with Domiworks to develop the adapter. It should work with other 8HP Dodge transmissions with the same housing. CANTCU seems to be the better option for general use, the lamik has more features but lacks the ability to skip gears. You might be able to just swap the mechatronics from a BMW transmission, I have no idea how easy it would be to flash the TCM though.
  9. Apr 14, 2025 at 4:43 AM
    #69
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Thank you for the information, I really appreciated it. If I ship the TCM to CANTCU they will do the bench flash for free.
    HulkSmurf14 and reywcms like this.
