5x139.7 to 5x150 Adapters
Discussion in 'Wheels & Tires' started by Nate20105, May 13, 2019.
  1. May 13, 2019 at 8:20 PM
    Nate20105
    Nate20105 [OP] New Member
    Nathan
    2014 Silver Tundra SR5 CrewMax
    So I came across a steal for a set of 20x10 Fuel Assault wheels for only $400. I'm wondering if anyone has ran adapters for a different bolt pattern and if there would be any issues. Thanks
  2. May 13, 2019 at 8:36 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    I personally have not, but I know people that have. Seems like the ones that have no troubles are diligent in their maintenance. Those that have trouble, don't take the time to rotate their own tires or check the torques routinely. Those quicky lube type guys can mess things up pretty easily with an impact.
    Nate20105[OP] likes this.
  3. May 13, 2019 at 8:46 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I run adapters on my overland trailer and I've run Spidertrax spacers on my truck. I'd call BORA or Spidertrax and have them made if I were gonna run adapters on my truck, no e-bay budget stuff, too much at stake to buy something unknown.
    Hammerdog and Nate20105[OP] like this.
  4. May 14, 2019 at 4:45 AM
    Nate20105
    Nathan
    I looked up Spidertrax and looks like they only have Jeep adapters. I could only find spacers for Tundras
  5. May 14, 2019 at 6:18 AM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    The issue I have with adapters and spacers, is that a lot of tire shops won't touch it. If you're out, get a flat and go to a tire shop, they may not want to work on your truck. I knew a couple of tire techs at Discount and America's Tire and they said it was company policy to not work on stuff with spacers or adapters.
  6. May 14, 2019 at 7:03 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    You need to call them. I'm pretty sure they do custom work, either Bora or Spidertracks. It's not cheep either and it's true that some shops won't touch your wheels if you have spacers, I never had that issue though.
    Nate20105[QUOTED][OP] likes this.
  7. May 14, 2019 at 3:59 PM
    Nate20105
    Nathan
    I'm wondering if I'll have any clearance issues... My truck has a lift and I'm using the same setup
  8. Apr 18, 2021 at 8:54 AM
    8balltundra
    8balltundra IronHorseShawn
    Shawn
    Mont Belvieu, Texas
    2019 Tundra Platinum 4x4
    Fabtech 4" coilovers F / 2" blocks R. 35" Ridge Grapplers.
    Down in the greater Houston area, discount has now changed their policy. They do work on vehicles with spacers. I'm guessing since so many people run them now, they figured they were losing business. I run 2 inch Spider Trax on my 19 platinum. Getting ready to take it in for my 5th tire rotation. I notice they always torque the spacers b4 mounting the tires even though the spacers were never broke loose.
    831Tun likes this.
  9. Apr 18, 2021 at 10:11 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I didn't know Spidertrax made 2" spacers in the 5x150 flavor. I thought they only had 1.25"
  10. Apr 18, 2021 at 10:19 AM
    8balltundra
    Shawn
    Mont Belvieu, Texas
    My bad. Mine r Bora.
    831Tun likes this.
  11. Apr 18, 2021 at 10:20 AM
    8balltundra
    Shawn
    Mont Belvieu, Texas
  12. Apr 18, 2021 at 10:21 AM
    8balltundra
    Shawn
    Mont Belvieu, Texas
    1 upgrade at a time. She's coming right along.6DEAD3F2-2106-4078-82EC-9EAADED2ADDA.jpg
  13. Jan 20, 2023 at 11:29 AM
    _steezysr5
    _steezysr5 New Member
    Instagram _steezyse Eibach pro lift stage 1 3.5/1.5 Rough country shims/block Methods nv305 double black 18x9 +25 Bfg ko2 35 12.5 Alpharex pro series headlights/taillights Lasfit ls plus series led Armordillo Hood Grille Insert with Led Lights Bakflip mx4 tri fold tonneau cover 5 inch iboard running board Pedal commander RCI Transmission and catalytic converter shield Nameplate overlays 5% tint all around Titan wheel spacer 1 inch Weather mats by 3dmatsusa Rydonair 7 inch Gplus third brake light Paint-matched hood bulge, grille surround, front and rear bumper overlays from Ecoological (midnight black metallic) Mbrp dual rear exit exhaust (mimics trd exhaust sound) yet to install, currently just a muffler delete
    what brand 5x139.7 to 5x150 adapter did you go with and hows is it holding up? did you have to rotate your tires more often due to faster wear from adapters or is everything normal? looking at fuel hurricane 22x12 the closest bolt pattern they make for the 22s is 139.7. I could go with 20x10 but l like the 22s better.
