5160 shock install tip
Discussion in 'Suspension' started by Stocky Balboa, Nov 16, 2019.
  1. Nov 16, 2019 at 4:34 PM
    Stocky Balboa
    Stocky Balboa [OP] New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Installed the 5160 setup today. Love it. I figured I’d pass this install tip on. Worked for me.
    The first shock I cut the black assembly band and the shock extend. This made lining up the lower bolt more difficult than it needed to be.
    So,
    On the driver side. I installed the reservoir clamp with band on, removed the band from the top section. Put the top in, lined up and installed the lower bolt and then slightly lossened the reservoir clamp and it all worked perfect. No fuss. Hope this makes sense. Here’s a pic of the band still on.
    831mic, TheBeast, Nahperator and 9 others like this.
  2. Nov 16, 2019 at 6:52 PM
    Soooooo shiny!
    Rica25 likes this.
  3. Nov 26, 2019 at 11:42 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Awesome advise!
    Came in handy when I installed my 5160s this past weekend. The passenger side got me as I didnt tightened down the clamp enough and had to muscle:curls: the shock to get the lower bolt in...but drivers side went in like a breeze.
    :thumbsup::thumbsup:
  4. Nov 26, 2019 at 11:50 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    Are the 5160s designed for a lift or for stock ride height?
    Ive been looking at the 5165s for my readylift, but have been told they wont work... i Just want a damn bilstein that with a reservoir.................
  5. Nov 26, 2019 at 5:32 PM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    5160s support 0-1.5" lift. I use them to support the toytec shackles on the middle setting for leveled look.
  6. Nov 26, 2019 at 5:35 PM
    SullyMoto19
    Tyler
    Houston, Texas
    Ahh. Very good. Thanks!
    Rica25 likes this.
  7. Dec 2, 2019 at 8:14 PM
    Subydude007
    Subydude007 New Member
    Washington
    2017 MGM CM Platinum 4X4
    -Tint -TRD Pro shifter -2018 TRD Pro LED headlights -Morimoto fogs -Remote start -6112s plus shims in front, 5160 plush shackles in rear -Diff drop -CB drop -Icon 6speeds -BFG KM3 315/70-R17
    Did those anodized reservoir clamps come with your shocks?
    Rica25 likes this.
  8. Dec 2, 2019 at 9:26 PM
    Stocky Balboa
    OC , CA
    They didn’t. Picked them up on Amazon. Here’s a pic of the listing. Working great so far. I probably over did it but I put two clamps on each resi.
    Vr0ck likes this.
  9. Dec 2, 2019 at 10:06 PM
    Subydude007
    Washington
    Thanks! They look great. I just ordered a set and was wondering how I was going to keep the reservoirs tied down.
  10. Dec 3, 2019 at 7:46 PM
    GI Joe
    GI Joe New Member
    Joe
    ‘07 CM 4wd TuRD
    Where did you get the shocks? Link?
  11. Dec 3, 2019 at 8:38 PM
    Subydude007
    Washington
  12. Dec 3, 2019 at 9:51 PM
    AZBoatHauler
    So.Arizona
    GI Joe[QUOTED] likes this.
  13. Dec 4, 2019 at 5:30 AM
    Stocky Balboa
    OC , CA
    6112 at 4 wheel parts
    5160’s on Amazon
  14. Dec 28, 2019 at 10:38 PM
    Noodleboy
    Noodleboy New Member
    HP
    SGV
    2015 tundra double cab
    Nice. Im going to get the bracket is black
  15. Feb 11, 2022 at 11:48 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    I know this is an older post but Thanks for sharing. That worked perfectly for my install of the 5160’s today. I did have a question though, I think the upper shock mount bolt is 21ft pounds, I have a crows foot wrench set so I’m able to get my torque wrench in there but every time I go to torque it down the shock starts to turn and there’s not a flat area on the stud to vice grip to. Any tips on getting it torqued?
    GODZILLA likes this.
  16. Dec 3, 2022 at 4:47 PM
    Nahperator
    Nahperator New Member
    2021 Tundra TRD Sport
    Used this trick today and saved myself some time! Thanks for the help!
