5100s
Discussion in 'Suspension' started by Mikejr, Jul 16, 2018.
  1. Jul 16, 2018 at 7:39 PM
    Mikejr
    Mikejr [OP] New Member
    201 trd offroad crew max
    Iv read that some guys add shins with the Bilstein 5100 on the driver side front? Is this true why and do we have to?
  2. Jul 17, 2018 at 7:49 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    People add a "shim" to the driver side to help compensate for the drive side lean without preloading the spring down more. Its a simple way to keep your truck level from driver to passenger side.
    Checkout out our top plate spacer that we offer, easy install and is competitively priced :thumbsup: Any questions, let me know!
    Thanks
    David
  3. Jul 17, 2018 at 8:04 AM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    I have 5100's all the way around, and used Coach Builder shims up front with his shackles on the rear. Each shim adds a quarter of an inch in lift. I have the Bilsteins at the top setting, and added 1 shim to the passenger side with 2 on the driver side. Since there is more weight on the side of the truck due to battery, & gas tank this will better level it out. Not a necessity, but your personal preference. Some people don't even add the shims, and just use the shocks alone. Depends on what you are looking to accomplish. Park in a level area, and measure how you sit with all 4 wheels. That'll be your start point, and go from there.
    :mudding:
    Coachbuilder1 likes this.
  4. Jul 18, 2018 at 11:40 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Thanks for the Post @Skippy I don't think any vehicle sits perfect with some adjustment, We designed our Coachbuilder shims to fine tune the front suspension allowing you dial in that perfect stance. If I can help anyone please let me know. David 801-635-4872
    the mailman and (deleted member) like this.
  5. Jul 19, 2018 at 9:13 AM
    Mikejr
    This is the answer I wanted! Thanks very helpful wasn’t sure if it needed it or it would slant real bad without it!
  6. Jun 13, 2019 at 5:25 PM
    the mailman
    the mailman New Member
    2014 Tundra Gun Metal Gray
    Just starting
    Just got her back. I did the Bilstein 5100 middle setting with 2 CB shims on driver side and 1 on passenger. Thx to everyone with the recipe to help get me here
    JimboSlice413 likes this.
  7. Mar 10, 2021 at 8:49 PM
    jassanch
    jassanch New Member
    Jason L.
    2015 Tundra 5.7L CM
    @the mailman nice! I’m looking at the exact same set up.
  8. Mar 11, 2021 at 4:34 PM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    Thank you, I have all the parts I need to do this but shims.
    What size tires did you get/go with on the 18" stock rims?
