5100s on middle setting, what tire are you running?
Discussion in '2nd Gen Tundras (2007-2013)' started by H22dx, Feb 12, 2022.
  1. Feb 12, 2022 at 1:30 PM
    H22dx
    H22dx [OP] New Member
    Trevor
    '18 Limited TRD Off Road
    I have searched and have seen multiple sizes that you can run with the 5100 on middle setting. I don’t like the top setting because it looks nose high. I really don’t want to go with a wider tire as I do not want to risk hitting the UCA or swaybar. So I am just wondering what people have experience with it have it on the middle setting. I don’t mind doing a little trimming and removing the front flap but I don’t wanna do anything else. Thanks in advance!
  2. Feb 14, 2022 at 7:22 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I'm running my 5100s on the middle setting. Running Nitto Crosstek2s 275/65/18. I also have Spidertrax WHS023 wheel spacers installed to make the wheels/ tires more flush to the fender flares.
    H22dx[QUOTED][OP] likes this.
  3. Feb 14, 2022 at 7:50 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I ended up with 2.5 of front lift with my 6112s.
    Toytec shackles in the rear on the 1" setting.
    I'm running 275/60/20 tires.
    The truck had stock 285/55/20s on it when new.
    H22dx[OP] likes this.
  4. Feb 16, 2022 at 11:51 AM
    H22dx
    Trevor
    How do you like the ride on the middle setting? I like the ride with my Off Road. I want it the same if not better.
  5. Feb 16, 2022 at 12:10 PM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    On my 2012 Platinum I had 5100's all 4 corners. Middle setting in the front with 2 coachbuilder shims on both sides and it was perfectly level and awesome. I didn't want huge tires, so I went with 275/60R20 Falken Wildpeaks. They are great tires. I could run 90 mph on the freeway easy and the truck rode great. Off road was much more controlled.
    I just got my 2020 and put Bilstein 5160 resi shocks on the back, (got a deal local). I am not sure yet what I am going to do in front, but the guy I bought the rears from has 6112's he is going to take off. Just waiting. I do a lot of in town and highway to the mountains and biking and stuff, so not a ton of off road, and this truck is beautiful.
  6. Feb 16, 2022 at 12:13 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    275/70/18 fills out the look of the truck just enough, yet the tire isn’t so much bigger that it will mess with acceleration/mpg
    ATV25, H22dx[OP] and MadMaxCanon like this.
  7. Feb 16, 2022 at 1:18 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    275/70-18 fit on stock suspension, you can fit up to a 34 without much fuss with the middle setting on 5100s, so 295/70 or 285/75-18
  8. Feb 16, 2022 at 1:27 PM
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
    275/70R18
    rims are a +18 offset
    4039839B-0708-43A0-962D-34E5CB14563D.jpg 4EC0E3DA-B8B1-4B8F-8CA3-D6BC05060234.jpg
  9. Feb 17, 2022 at 7:13 AM
    BlueCrushSC16
    Charleston, SC
    It's more comfortable than OEM, IMO. Don't feel bumps as much.
  10. Feb 17, 2022 at 8:44 PM
    Marshall
    Marshall New Member
    Jon
    285/75/18 Nittos. I had to take the forward mudflaps off. It has a 1” block on the back and a coach builder shim on the drivers side. And extended bump stops.
    Half Assed and H22dx[OP] like this.
  11. Feb 17, 2022 at 8:45 PM
    Cement20
    Cement20 New Member
    Landon
    SL,Ut
    2020 Cement Tundra Crewmax Sr5
    -ThrashedOffroad Send-It Suspension -ThrashedOffroad Billet UCA -ThrashedOffroad 6 switch pod -ICON stage 2 leaf springs -Coachbuilder 1” shackles -TimbrenIndustries Bump stops -RocktrixWheels 18x9 RT111 Teardrop matte black wheels -NittoTire 35x12.50r18 RidgeGrapplers -Ironman4x4 RAID Front bumper -Diodedynamics fog,bumper,ditch,chase and rock lights, interior LED Swap -RCIOffroad engine, transmission and cat skid plates -SbFilters Cold air intake -Victory4x4 bed mount Molle -Katzkin Graphite leather -ESPtruck plastic CrewMax storage compartment -ScreenProtech interior screen guards -Tufskin raised 3D Solar octane lettering -JamHandle door assist in orange -Unfocused Offroad Safety orange lighting bumpers
    I’m running 35x12.50r18 on the 5100 middle setting.
  12. Feb 18, 2022 at 1:38 AM
    H22dx
    Trevor
    Damn! Are they stuffed in there?
  13. Feb 18, 2022 at 3:11 AM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    275/70/18 on 18x9 wheels +25 offset
  14. Feb 19, 2022 at 5:40 PM
    Cement20
    Cement20 New Member
    Landon
    SL,Ut
    No, I have some rubbing on the front bumper cap mounts, but that’s all! Great turning radius still
  15. Feb 21, 2022 at 11:37 AM
    Jorgesworld86
    Jorgesworld86 New Member
    Orange County,CA
    2013 Tundra Limited Rock Warrior
  16. Feb 21, 2022 at 12:03 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Forget about the lift... it's irrelevant... if you don't want it to rub even when turning the wheels and compressing the suspension, then the fore-aft parts of the wheel well are what you need to deal with.
    On stock wheels and UCAs you can run 295/70r18 (~34.4") or 285/75r18 (~34.8") with minor trimming (meaning no BMC). 35x12.5 are ~34.6" in reality, so it's that same ballpark.
    If you want to use your stock rims, get one of those two sizes. Bigger looks better on Tundras. :thumbsup:
    If you get aftermarket rims with lower offset, more trimming will be required.
    EDIT: I see that some people are getting rub on the swaybar at full lock with the stock +60 offset wheels. A 10mm spacer would take care of that though.
  17. Feb 21, 2022 at 3:50 PM
    spotcw
    spotcw New Member
    I’m running terra grappler in 305/60/18 and fit well. Getting new ones and upping it to 305/65/18 so they are little taller. 5100s on middle setting.
    H22dx[OP] and r1-superstar like this.
  18. Feb 21, 2022 at 4:27 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Another person running 305s. NICE!!!
    H22dx[OP] and spotcw[QUOTED] like this.
  19. Feb 21, 2022 at 5:12 PM
    spotcw
    spotcw New Member
    I’ll know tomorrow if the 305/65/18 fit. Fingers crossed but hopeful after seeing the reply’s here.
  20. Feb 21, 2022 at 6:34 PM
    rruff
    rruff New Member
    Rim offset makes a big difference. Those are nominally only 33.6" diameter though, so pretty small.
  21. May 4, 2022 at 7:57 AM
    MER
    MER New Member
    18' Limited CM 4x4 Off Road
    Nice rig. Just purchased front 5100’s and planning on doing the middle setting as well. I’m just a 1/2 an inch lower on the driver side and was wondering if you added any Coachbuilder shims? Any pros and cons to adding a shim? Or is it best to just leave the 5100’s alone at the middle setting? Thanks
  22. May 4, 2022 at 8:02 AM
    r1-superstar
    DB
    UTAH
  23. May 4, 2022 at 8:47 AM
    rruff
    rruff New Member
    Shims are fine IMO, but you should extend your bumpstops a bit, else they won't do anything... you'll bottom out your shock instead, and that isn't good.
    MER[QUOTED] likes this.
  24. May 4, 2022 at 9:54 AM
    Cement20
    Cement20 New Member
    Landon
    SL,Ut
    No shims on mine. I’ve noticed some sag happening in the front. I need to take it in for an alignment and front shock adjustments before summer. I am running rear coachbuilder 1” shackles.
  25. May 4, 2022 at 10:50 AM
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    First off THANKS ! I had a slight "lean" maybe 1/4", did not go with any shims, thought about it but I never noticed it at all before.
