5100's on first gen
Discussion in 'Suspension' started by yotaman90, Nov 17, 2018.
  1. Nov 17, 2018 at 1:57 PM
    yotaman90
    yotaman90 [OP] New Member
    2005 double cab sr5 sand mica
    Hi all! I know this subject has been gone over many times but I have new bilstien 5100 shocks I'm putting on the front to replace the factory shocks on my 02 4wd tundra and need a little advice. I had a 2.5" spacer installed that gave me a 1/2" higher then level front and would like to keep this same stance using the new shocks without the spacers of course. Everything I have read says the 3rd setting should give me a level stance but I dont see how this can be since there saying that should be a little over an inch lift. Seems like I should go with the 4th or 5th setting to be comparable to what the spacers gave me?? I'm going off a diagram I found online that was showing the average ride heights per settings.
    justamessenger likes this.
  2. Nov 17, 2018 at 3:19 PM
    Professional Hand Model
    Hand Protectors
    I think the highest Billy setting on our years is the third up from bottom. Gives an inch?
    My Billy fronts at the second up from stock. Maybe a half inch lift. For whatever reason, my Billy 5100 rear shocks (non adjustable) gave about a half inch rise as well. This lift stuff is inexact science.
    Let us know how it goes for you.
  3. Dec 9, 2018 at 7:07 AM
    yotaman90
    4th setting did put my truck about 1/2" higher in the front. Bought a set of the icon AAL and put the bilstens on 5th setting in the front to get this much lift out of it. 2.5 front and 1.25 rear is where it sits now.20181202_094844.jpg
  4. Dec 9, 2018 at 7:15 AM
    Hand Protectors
    Looking good. I like your clear (not orange front side marker/blinker). Looks clean. I think there was a factory recall on those (sold only in the south east) due to the color needing to be orange. I may be wrong. I might try to get these clear ones in the future due to my orange ones taking on water.
    How you liking the ride with the Billys?
  5. Dec 9, 2018 at 7:23 AM
    yotaman90
    I love it. Firmer and better cornering with the new shocks. Now I am thinking about upgrading the wheels to ether the TRD beadlock or just the silver 6 spoke like these.4733922725_2b8e3d83ea.jpg 003.jpg
  6. May 8, 2019 at 6:26 PM
    JustGotDuals
    JustGotDuals New Member
    @yotaman90 what size tire were you running in this picture?
  7. May 8, 2019 at 6:45 PM
    yotaman90
    I was and still am running 265 75 16s.
    JustGotDuals likes this.
  8. May 8, 2019 at 8:14 PM
    JustGotDuals
    Sweet! Your tires look pretty proportional. Im thinking of going to the 4th clip location on mine and just wanted to make sure that my tires (same size as yours) wont seem to small. Do you think your tires are a little small for that height? Pictures can be different from real life sometimes.
  9. May 8, 2019 at 9:13 PM
    yotaman90
    I think they match up pretty well. Thought about going with 285s but didnt want my mpg dropping anymore then what it already is. Was also worried about rubbing. I have new rims and new pirelli scorpion mts now and I think I like the look pretty well.
  10. May 8, 2019 at 9:27 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Love the Rock Warrior wheels, but I wasn’t clear they would clear my calipers.
  11. Aug 29, 2019 at 4:31 AM
    Kauaitundra1
    Kauaitundra1 New Member
    2000 TRD Tundra limited 4x4
    Any problems going to the highest setting? I read the access cab shouldn't go above the third?
  12. Aug 29, 2019 at 4:50 AM
    yotaman90
    Not any issues so far other then my ball joints wore out a few weeks ago. Replaced with Freedom Offroad upper control arms. 5100s are working out nice!
  13. Aug 29, 2019 at 9:34 AM
    JustGotDuals
    How are those Freedom Offroad uppers? Ive heard mixed reviews about them. Plus, Im about to pull the trigger on some Pirelli MTRs pretty soon in the same size as yours.
  14. Aug 29, 2019 at 9:57 AM
    Kauaitundra1
    Yea I read that can happen from adding much a lift. Really don’t want to open a can of worms but i already ordered the Billys and some 1/2” shims. Hope I don’t end up forking up more $$ to fix problems created by a 2-2.5” lift
  15. Aug 29, 2019 at 10:50 AM
    yotaman90
    I do not have any bad things to say about the freedom uppers. I do think it is necessary to put uppers on that are built for a lift though if your going all out on the Billy's. I love the look of the Pirelli MTRs. No sign of wear yet but I only have around 5,000 miles on them.
  16. Aug 29, 2019 at 10:56 AM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Top setting with the diff drop kit 265/75/16 Goodyear Ultraterrains
    Racingjohndeere55 likes this.
  17. Aug 29, 2019 at 11:06 AM
    yotaman90
    Wish my paint still had some shine left in it like that!
    MS22 likes this.
  18. Sep 23, 2019 at 9:22 AM
    Kauaitundra1
    So I put on the 5100's at the third setting since that what was listed as the max setting for the Access cab TRD. I added a 1/2" shim on the driver side for lean and now have about a 2" level going on. I am not opposed to a little bumper trimming so I can get the max wide and tall tires. I am looking for new rims too, any suggestions? Mostly drive sand here, zero highway as my roads top out at 50mph. Lots of potholes too so I am thinking 16" as I hear 15" rims can't clear the brake calipers or something like that. Just want to know how big I can go, offset, ect..
    revtune likes this.
  19. Sep 23, 2019 at 10:04 AM
    Outbound
    Aaron
    Northern Alberta
    I run 17" TRD Pro SEMA wheels and 265/70/R17 Cooper ST Max tires on my '05 with Bilstein shocks levelling my truck out.
  20. Sep 23, 2019 at 10:40 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  21. Sep 27, 2019 at 3:32 PM
    Kauaitundra1
  22. Feb 17, 2020 at 4:14 PM
    TurtleWrench
    TurtleWrench New Member
    Dom
    2000 Tundra 4Dr 4x4 SR5 300K+
    Where did you get the 1/2" shim from? I am putting on some 5100's on
