5100 top setting w/driver shim
Discussion in 'Suspension' started by Iowa12tundra, Dec 6, 2019.
  1. Dec 6, 2019 at 8:38 PM
    Iowa12tundra
    Iowa12tundra [OP] New Member
    2012 tundra crew
    I have been looking through different builds and searching around for people with 5100's set at the top setting with 1 driver shim. My questions are...
    1. Is it a headache to get good alignment with stock uca?
    2. I want to fit 295/ 70 18's cooper stt pros with 3rd gen trd rims with 1.25 wheel spacers. If there is a good chance of issues with alignment can I go middle setting with driver shim and fit the tires?
    -I know there could some trimming involved but don't want to get to crazy.
    GATORthaBEAST likes this.
  2. Dec 6, 2019 at 8:48 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    I have 305/65/18 with TRD Rims, 5100s front top setting, and 1" Bora Wheel Spacers. No issues with stock UCAs or alignment. I have the Coach Builder Shims but have not yet installed them. I plan on using two (1/4") for the driver's side and one for passenger side and 1.75" Shackles on the rear.
  3. Dec 6, 2019 at 8:50 PM
    619Tundra
    Btw, I just noticed when I turn the wheel all the way on reverse the front tired rubs slightly. I have BFG KO2s.
  4. Dec 6, 2019 at 9:03 PM
    Iowa12tundra
    2012 tundra crew
    Thanks for the reply. So you still have stock uca? I'm kinda thinking the widder the tire it's going to have more rub potential.
  5. Dec 6, 2019 at 9:07 PM
    Iowa12tundra
    2012 tundra crew
    Never mind I see u have stock uca. :)
    619Tundra likes this.
  6. Dec 6, 2019 at 9:07 PM
    619Tundra
  7. Dec 6, 2019 at 9:09 PM
    619Tundra
    I don't know how that happened ^
  8. Dec 6, 2019 at 9:42 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    You cut out the ] at the end of his quoted post.
    It says [/QUOTE instead of [/QUOTE]
  9. Dec 7, 2019 at 5:54 AM
    Iowa12tundra
    2012 tundra crew
    Goodmorning bump!
  10. Dec 7, 2019 at 11:54 AM
    Iowa12tundra
    2012 tundra crew
    Looks like morning bump didn't help:help:
    Basically I have used cooper STT pro's on 3rd gen rims and 1.25 spacers that I will put on after the installation of the 5100's. Didn't want to be spending more $$$ on uca's if I went with top setting with driver shim. If there's a good chance of alignment issues I will just go with middle setting with driver side shim. Of course there will be some fitment tinkering but hopefully not much.
    Anyone with this set up of top or middle setting with driver shim fitting 295 70 18's?
    Eventually I will be going with 285 75's Geolandar /a/t g015. Tire comes out 34.7 and 11 wide so I can do away with spacers. Any feedback would be appreciated :)
  11. Dec 10, 2019 at 2:33 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Good tire choice. I think I will be trying those for my next set.
