5100 setting to level truck?
Discussion in 'Suspension' started by Alias7, Jun 29, 2020.
  1. Jun 29, 2020 at 6:34 PM
    Alias7
    Alias7 [OP] New Member
    20 Tundra Crewmax
    Thanks for all the awesome posts re: the 5100s, but I’m still a little confused. I see most are using the middle setting (1.57”), but by my calculations this will not level the truck.
    I have a stock 2020 SR5 TSS Off-road 2x Crewmax with 7k miles. No lift or mods. I only want to level... and not jack the TSS.
    Middle rear fender 39.0”
    Middle front fender 36.0”
    If I go maxed out (2.2”), wouldn’t I still have ~3/4” of rake???? Am I missing something???
  2. Jun 29, 2020 at 6:47 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    Double the change in distance between the clips due to the shocks mounting halfway up the A-arm.
  3. Jun 29, 2020 at 6:50 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    The top setting looks a slightly nose up, the middle retains a little rake. Don't worry about the measurement, use the search bar to look at other members trucks and see what you like the best. There's so many threads full of pictures of these bilsteins on the middle and top setting
    Here's the middle, if that looks like too much rake, use the top setting
    GT87, co2owen, 3xYOTA and 2 others like this.
  4. Jun 29, 2020 at 6:50 PM
    Alias7
    20 Tundra Crewmax
    Thank you. From Bilstein’s instructions it seems those are final ride height adjustment estimates, not measurements on the shocks.
    Boerseun likes this.
  5. Jun 29, 2020 at 6:53 PM
    Pepperonipizzzza
    Pepperonipizzzza New Member
    Curious, how’s the drive quality compared to the stock?
  6. Jun 29, 2020 at 7:26 PM
    Alias7
    20 Tundra Crewmax
    [/QUOTE]
    In fairness, your pic is probably one of the better ones as far as being squared up and being able to see the subtle differences. This said, I want it as close to level as possible with out going noise high. I see some posts say it looks nose high, but it is actually not. Also, seeing the other measurements in the other 5100 threads, I haven't seen a stock 2x4 with 39" at the bottom of the rear fender.... so looking for advice on if I can get away with "2.2inches lift" per Bilstein's install sheet.
    Here is Texas, most come with the port installed 3+1 lift, so I don't have one to compare/view. I garage mine at work and home, so did not want to risk the lift.
    rv740 and Pillslinger like this.
  7. Jun 29, 2020 at 7:41 PM
    owb2gp
    owb2gp New Member
    ID
    I did the top setting and the nose was high. Added a 1 inch block in the back and it looks level to me. Sorry no pics.
  8. Jun 29, 2020 at 7:51 PM
    Alias7
    20 Tundra Crewmax
    Thank you
  9. Jun 30, 2020 at 4:59 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    If you search on this forum there are TONS of threads on this topic. You’ll get responses all over the place. Some say it’s better, some say no real difference, some will say it’s worse. It’s a highly personal experience.
    I put 6112s on my 2019 and the best description I can offer is ride is more planted. It’s not smoother in my opinion but handles bumps, etc. better. I don’t do a lot of off-roading either.
  10. Jun 30, 2020 at 5:42 AM
    ekinnee
    ekinnee New Member
    North Central Texas
    2020 Tundra Quicksand SR5 TSS
    The rake is there so you don't squat when loaded.
    BravoDeltaRomeo likes this.
  11. Jun 30, 2020 at 6:10 AM
    owb2gp
    owb2gp New Member
    ID
    I've also not had any issues with TSS with the level or with the older pro grille I added 2 years ago.
  12. Jun 30, 2020 at 6:51 AM
    glowblue
    VA
    I kept a 1” rake in the truck with +1 shackles... I was hauling about a 1,000 lbs of dirt and the truck was a little nose high (maybe 1/2”-1”).
  13. Jul 6, 2020 at 5:25 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Mine are on the middle setting and the ride is really good. Granted this is coming from worn out stock suspension on an 08 with 110k, but I would imagine a lot of people are as well. I would describe the ride as smooth and capable feeling. It is not jarring or rough at all, but feels planted and responsive. I’ve had Bilstein upgraded shocks on many different cars and this is a common characteristic of them.
  14. Jul 6, 2020 at 5:27 AM
    Charvonia Design
    Keith
    Huntersville, NC
    Should have also mentioned that I think my leaf springs are a bit worn. The previous owner hauled a lot and they don’t have much arch, so the rear might be an inch lower that stock.
  15. Jul 6, 2020 at 6:14 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I'm at mid perch, but I wanted to keep a rake. Ended up at 38 3/8" and 39 3/8" ground to arch. 08 with 116k.
    You can buy the shims to completely level out at top height or compensate for the driver's side lean.
  16. Jul 12, 2020 at 4:40 PM
    Blueknights75
    Ron
    Clayton, NC
    5100s top setting. Leveled perfectly.3EBC3908-7ADE-4F74-817E-78A0E248EB5E.jpg
    GT87 and JimboSlice413 like this.
  17. Jul 18, 2020 at 9:13 PM
    20SilverTundra
    20SilverTundra New Member
    Edinburg, TX
    2020 Silver Tundra TSS 4x4
    did you just add the front 5100 only? Looks nice by the way
  18. Jul 19, 2020 at 5:57 AM
    Blueknights75
    Ron
    Clayton, NC
    5100s front at top setting and 5100s in the back and that’s it. Thank You!
    EricD likes this.
  19. Jul 26, 2020 at 11:07 AM
    Solace_In_My_Tundra
    Solace_In_My_Tundra New Member
    Out there somewhere
    2020 MGM CrewMax
    Tonneau Cover TRD Pro Grille Bumper Shells Color matched Bulge Bilstein 5100 Ceramic Tint Black Tundra Inlay
    Bilstein 5100 mid setting in front with 5100 in rear. Oh, and it didn’t mess with my TSS sensor.
    EricD, rv740, co2owen and 3 others like this.
  20. Jul 26, 2020 at 1:16 PM
    Franco4x4
    Franco4x4 New Member
    2019 tundra CM
    Dam this is how I want my truck to look once I'm done with MODS (and have more money). So the rear you left at regular settings? Is you truck a TSS package?
  21. Jul 26, 2020 at 7:56 PM
    Solace_In_My_Tundra
    Out there somewhere
    2020 MGM CrewMax
    thanks man....yes for the rear I just replaced the shocks with the 5100. No added blocks/leafs/etc. yes it’s a TSS off-road package. I removed the decals, swapped out the tires for 34”s and color matched the bumpers along with adding a 2019+ TRD pro grille.
  22. Jul 26, 2020 at 9:04 PM
    Franco4x4
    2019 tundra CM
    I'm still learning the different tire size but I'm guessing 34"s is somewhere is the 285 70 size? Do they stick out a lot?
  23. Jul 27, 2020 at 6:36 AM
    Solace_In_My_Tundra
    Out there somewhere
    2020 MGM CrewMax
    my stock tires were 275/55r20 and my new tires are 275/65r20, so the width is the same, the diameter is bigger. I got lucky with the new tires-my buddy had these on his new truck and he got 35s and sold me his 34s for $300 total.
    no, they don’t stick out much which is the look I’m going for.
    AZBoatHauler and 20SilverTundra like this.
  24. Jul 27, 2020 at 12:14 PM
    khaywood9
    khaywood9 New Member
    Factory 20's or you have some with a different offset? Stance looks great!
  25. Jul 27, 2020 at 3:46 PM
    Solace_In_My_Tundra
    Out there somewhere
    2020 MGM CrewMax
    thanks man....yep just the factory 20” wheels. The tires also provide an extra inch of lift since they are 2 inches taller than factory tires
  26. Jul 27, 2020 at 5:01 PM
    Any rubbing?
  27. Jul 27, 2020 at 5:56 PM
    Solace_In_My_Tundra
    Out there somewhere
    2020 MGM CrewMax
    I did but I removed the front flaps and no more rubbing!
  28. Jul 27, 2020 at 5:58 PM
    :thumbsup:
  29. Jul 27, 2020 at 6:50 PM
    Skoden
    Skoden New Member
    Jared
    Manitoba Canada
    20 sport premium cm black
    I did top setting with 1” block as well. Slight rake which I wanted. 275/70r18
    Saoc9 and GT87 like this.
  30. Aug 5, 2020 at 10:42 PM
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    King's all around, Magnaflow exhaust, 18x9 Method 305 NV, Falken Wildpeak A/T3W 305/65/18 tires, tinted windows (shhhhh)
    I went with the 5100's up front on the highest setting.
