5100 on bottom setting?
Discussion in 'Suspension' started by Stuffs, Jan 11, 2019.
  1. Jan 11, 2019 at 6:47 PM
    Stuffs
    Stuffs [OP] New Member
    Hi guys,
    Finally decided to go with 5100s on all four corners on my 18CM.
    I can find tons of pics with people on the middle setting but can't find a single one with the lowest setting. Has anyone tried it on the lowest? Just trying to decide but hard to without have some form of pic on the lowest to compare I guess.
    Second question, will there be much of a ride feel difference between lowest and middle? I read that users say the ride stiffens up a bit going from middle to top. So would that mean going to lowest will soften it up? Sorry if that sounds retarded. Its my first truck.
    Zum likes this.
  2. Jan 11, 2019 at 6:59 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Haven’t had the pleasure of updating my suspension yet- but interested
    Someone with more knowledge will chime in
    GOOD LUCK!
    :popcorn:
  3. Jan 11, 2019 at 7:21 PM
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    Following as I am all stock to now on suspension as well.
  4. Jan 11, 2019 at 9:22 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    I'm fairly certain the 5100 on the bottom is the same as the 4600, so if you're never planning on raising it to the 2nd or 3rd setting you can save a few bucks with the 4600s. I had 5100s on my old Titan at the middle setting and I would say it was a little stiff, but not bad at all.
    Stuffs[OP] likes this.
  5. Jan 11, 2019 at 9:33 PM
    Stuffs
    Thats what I thought at first but was told that even at the lowest on the 5100, its about .9" lift vs 4600. Thats why I figured a near inch lift is ok, but just not able to find a pic with that setting so I can compare with those who went middle setting.
  6. Jan 11, 2019 at 9:35 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    You could be right on that, I was just basing my comment off my experience with my Titan. At least with the 5100s you can always set it on the 2nd or 3rd and go back down if you think it's too stiff. I didn't want to pay someone to adjust mine again, and I wasn't about to kill myself with a rental spring compressor on my off-road springs!
  7. Jan 12, 2019 at 2:13 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    My 2010 has 5112's on the lowest setting in the front,5100's at stock setting in the rear. I wanted the slight 'rake' for towing, it sits dead level with the boat hooked-up.
    Stuffs[QUOTED][OP] and Y0TA PR0 like this.
  8. Jan 12, 2019 at 4:40 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    5100's on the middle setting. it is stiffer than stock, but stock was really squishy.
    Stuffs[OP] and Y0TA PR0 like this.
  9. Jan 12, 2019 at 6:56 AM
    tacomawv
    tacomawv New Member
    Richard
    I have mine on the lowest setting. I had a little over 3/4 of an inch lift. I wanted some rake. 90% of the time my truck is towing my boat. It is level with the boat hooked up. The ride is a small amount stiffer but I like it better.
    Stuffs[OP] and CMB like this.
  10. Jan 12, 2019 at 3:34 PM
    Stuffs
    Thanks for chiming in on it guys. I too want a slight rake since I don't want the back to squat too exaggerated when towing.
  11. Jan 12, 2019 at 4:23 PM
    Mannishboy
    Mannishboy New Member
    Indianapolis, IN
    2015 DC 4x4 Limited, Blue Ribbon Metallic.
    TRD exhaust, TRD cai, TRD rear sway bar, TRD shift knob, Sequoia front sway bar, bed extender, bed step, Weathertech floor mats and window vents, spray in bed liner, Morimoto fogs, Access tonneau bed cover.
    Middle setting stock wheels and tires 225D65E5-51A2-403B-939D-3EC445D8F38E.jpg
    Thebigginny, Stuffs[OP] and mattyd170 like this.
  12. Jan 12, 2019 at 6:37 PM
    Stuffs
    Middle setting def looks good. Does it go nose up easily when thing are loaded in the box? Nothing crazy, I'm talking about few hundred pounds to 500 or so.
  13. Jan 12, 2019 at 6:51 PM
    Mikekoot
    Mikekoot New Member
    Canadia
    2018 MGM tundra sr5 DC /2014 SSM Toyota Tacoma sr5 DCLB
    Only about 1000lbs plus I get some sag. Looking at a rear 1inch block
    Stuffs[QUOTED][OP] likes this.
  14. Jan 12, 2019 at 8:25 PM
    Mikekoot
    Mikekoot New Member
    Canadia
    Yeah good idea! I forgot about them. Do you need new bushings for them?
  15. Jan 12, 2019 at 8:33 PM
    Mikekoot
    Mikekoot New Member
    Canadia
    Also hard to source in Canada
    OR18TRD[QUOTED] likes this.
  16. Jan 12, 2019 at 9:50 PM
    Stuffs
    Anyone happen to have or seen a 3rd gen on the bottom setting? I never thought trying to find a pic of it @.87 was that hard. Dozens of 1.5 and 2.25 pics out there.
  17. Jan 13, 2019 at 10:29 AM
    Stuffs
    Yea, you might be right. I love the looks of the middle setting honestly, but I do put things in the bed quite often and afraid it would get that squatted look.
  18. Jan 18, 2019 at 3:49 PM
    Tun-D
    Tun-D New Member
    Don
    Sacramento CA
    2019 TRD Sport MGM
    Nice look.
    Did you add anything to the rear or leave it stock? And what size tires?
    Just picked up a new tundra last month and am looking to do something like this.
    Thanks.
    Netmonkey[QUOTED] likes this.
  19. Jan 19, 2019 at 5:05 AM
    Netmonkey
    Georgetown, TX
    the rear is stock. the tires are 295-55-20 ridge grapplers. there was no rubbing with that tire and wheel combination.
  20. Jan 19, 2019 at 7:18 AM
    Cavalry Tundra
    Cavalry Tundra New Member
    I will get you some better pics later today.
    Front Suspension: Bilstein 5100, lowest setting
    Rear Suspension: Bilstein 5100, not adjustable (no lift)
    As you can see, there is still rake... It's what I was going for.
    Hope this helps.
    Tundramoney likes this.
  21. Jan 19, 2019 at 11:05 AM
    Cavalry Tundra
    Here’s a side shot.
    Thebigginny and Tundramoney like this.
  22. Feb 12, 2019 at 10:48 AM
    Tundramoney
    Tundramoney Old school
    Earth
    C2A1A14D-A5C7-4658-8D8E-AA21974FDE39.jpg 5A42E125-0BB0-4BEE-A078-653707C133E2.jpg Here you go 5100’s lowest setting! Front and side views Raised front about 1” now have 1”5/8” of rake A73467D5-76B6-421C-9021-3501699E9BAD.jpg
    Stuffs[OP] and Cavalry Tundra like this.
  23. Feb 18, 2019 at 7:52 AM
    Cavalry Tundra
    Lowest setting.
    NoMoTaco, Stuffs[OP] and Tundramoney like this.
  24. Mar 30, 2019 at 1:26 PM
    NoMoTaco
    NoMoTaco New Member
    Bluffton SC
    2018 Tundra DC TRD OR Silver
    How is the ride on lowest setting compared to the off-road pkg 4600 trd version shock? (Not the same as Bilstein REAL 4600 version)
    Oey12 likes this.
