5100 Install Issue Corrected
Discussion in 'Suspension' started by n8saki, Sep 18, 2018.
  1. Sep 18, 2018 at 6:37 PM
    n8saki
    n8saki [OP] New Member
    Nate
    8361 / 01H5
    Just installed my 5100s, tech took all the precautions and did not bend or remove the snap ring/c clip. Is it normal for the opening to look like this? The back side is completely flush. Test drive went well which included some minor speed bumps.
    Normal?
    Rica25 likes this.
  2. Sep 18, 2018 at 6:50 PM
    crochetjohn
    crochetjohn New Member
    2015 Inferno TRD Pro
    The coil seat is installed wrong. Needs to be flipped.
  3. Sep 18, 2018 at 6:55 PM
    tacomawv
    tacomawv New Member
    Richard
    I would have it towed back. It is going to go very bad if you keep driving it.
    BTBAKER likes this.
  4. Sep 18, 2018 at 6:57 PM
    crochetjohn
    This is the correct orientation.
    n8saki[OP] likes this.
  5. Sep 18, 2018 at 6:58 PM
    crochetjohn
    Also, whoever the Tech was. I wouldn't let them touch the truck again. These come with detailed instructions with images. He apparently ignored that. I installed a set of 5100 on my buddies tacoma. Piece of cake if you read.
  6. Sep 18, 2018 at 7:08 PM
    n8saki
    Nate
    8361 / 01H5
    I agree. They have it now. Didn’t leave.
    BTBAKER and crochetjohn like this.
  7. Sep 18, 2018 at 7:11 PM
    n8saki
    Nate
    8361 / 01H5
    Should they be replaced or ok to just flip and reinstall?
  8. Sep 18, 2018 at 7:12 PM
    crochetjohn
    As long as the ring seats back I don't see an issue. The coil seat holds in the ring tight to the shock tube and in place.
  9. Sep 18, 2018 at 7:13 PM
    crochetjohn
    If it's bent beyond sitting right I'd say get another set of rings.
    Watt maker and n8saki[OP] like this.
  10. Sep 18, 2018 at 7:21 PM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    I’ve heard that shock releasing off its ring position can get really ugly.
    Good thing you caught that!
  11. Sep 18, 2018 at 7:25 PM
    n8saki
    Nate
    8361 / 01H5
    Thanks for the help here guys. Thought something was wrong when it looked lifted 3 inches and a major bro squat.
  12. Sep 18, 2018 at 7:25 PM
    crochetjohn
    That would of been asking for coil bind. Or the ring failing and your suspension failing apart on the road.
    n8saki[QUOTED][OP] and BTBAKER like this.
  13. Sep 18, 2018 at 7:26 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    Damn. Brutal! What’s it look like now?
    n8saki[QUOTED][OP] likes this.
  14. Sep 18, 2018 at 7:28 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    Agreed on this 100%. You should not go back to that place. That is some serious hack work.
  15. Sep 18, 2018 at 7:33 PM
    n8saki
    Nate
    8361 / 01H5
    Left it at the shop. Got a car to drive and will pick up tomorrow. To be continued.
    BTBAKER[QUOTED] likes this.
  16. Sep 18, 2018 at 7:40 PM
    tacomawv
    tacomawv New Member
    Richard
    I would give a very good look to the ring and the groove. The ring has a ton of pressure on it. If it goes south bad damage will happen. Nice looking truck.
  17. Sep 18, 2018 at 7:57 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    I’m sure they will get it done right. Especially with the fact that they know you are on top of it.
    Post up some pics when that thing is dialed in!
  18. Sep 18, 2018 at 7:57 PM
    taterm6x
    taterm6x New Member
    Wow! That could’ve been very bad if that ring had failed (which has happened) because of the flipped seat...while cruising down the interstate. If it wasn’t driven on I would think the rings should be fine.
  19. Sep 18, 2018 at 7:59 PM
    taterm6x
    taterm6x New Member
    That little ring kills me anyway... when I first had mine done I would cringe every time I would hit a speed bump thinking how the heck is this thing gonna hold all this weight and pressure!
  20. Sep 18, 2018 at 8:28 PM
    n8saki
    Nate
    8361 / 01H5
    I believe it was driven on for a short test drive. Guess will find out tomorrow....wonder where I can get new c clips or snap rings. 4 wheel parts etc?
  21. Sep 18, 2018 at 8:45 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Probably direct from bilstein. I'd have the shop but you a new set....then go get them installed elsewhere. The clip ring is bent and they put the spring perch inside down. What a bunch of hacks
    Darkness and RLHULK like this.
  22. Sep 19, 2018 at 3:55 AM
    Sunnier
    Sunny
    San Diego, CA
    So... I waited 'til OP got his answer before derailing but... am I the only one that read "snap ring" and thought immediately of nipples and mailboxes?!! :rolleyes::D:eek:
  23. Sep 19, 2018 at 4:24 AM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    Yes. Yes you are.:confused::D
  24. Sep 19, 2018 at 10:14 AM
    n8saki
    Nate
    8361 / 01H5
    Update, rings & shock housing are fine installing back in. They are doing the alignment. Any base line that I should use to check them.
    Thank you guys for the look out. One of the main reasons I joined this forum. I’m grateful.
    Sunnier, Watt maker and parker44 like this.
  25. Sep 19, 2018 at 10:16 AM
    Pudge
    CT
    I'm just worried that the ring is damaged and now that the perches are installed correct you cant see the rings
    BTBAKER likes this.
  26. Sep 19, 2018 at 10:24 AM
    n8saki
    Nate
    8361 / 01H5
    They were inspected prior by a different tech and were completely apologetic.
    Here are the alignment numbers.
    Pudge likes this.
  27. Sep 19, 2018 at 10:49 AM
    TheBeast The Beach
    caster above 3 is preferred.
  28. Sep 19, 2018 at 10:54 AM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    After I put on the Coachbuilder steering kit Dave Ekstrom sent me what he thought was perfect alignment specs for a 2 inch level and the caster was 2.5.
  29. Sep 19, 2018 at 12:30 PM
    n8saki
    Nate
    8361 / 01H5
    How it sits now. Alignment waiting to be redone per specs listed here. They’ve been pleasant once they figure out they f* up. Pretty close to level, easy to tell it was f*d
    equin, Newm, BTBAKER and 6 others like this.
  30. Sep 19, 2018 at 12:33 PM
    crochetjohn
    Looks good.
    Rica25 and n8saki[QUOTED][OP] like this.
