5100 INSTALL HELP!!!!!
Discussion in 'Suspension' started by lbcdan, Mar 10, 2018.
  1. Mar 10, 2018 at 1:45 PM
    lbcdan
    lbcdan [OP] Zip it up and zip it out
    Daniel
    Long Beach, CA
    2018 Toyota Tundra CrewMax 4x4
    Toytec Boss Coilovers, Total Chaos UCA, Icon 57720P Shocks, Toytec Shackles, TRD Off-Road Wheels, SpiderTrax Spacers, BakFlip MX4, Clazzio Seat Covers, Rough Country Light Bar, BajaDesigns Foglights
    Fellow Tundra Owners,
    I am in the middle of a Bilstein 5100 install. I have removed the pin and loosened the castle nut but I cannot get the stupid tie rod end to break free? Any tips or tricks?
  2. Mar 10, 2018 at 1:55 PM
    lbcdan
    Daniel
    Long Beach, CA
    Correction.. I cant get the driver or the passenger tie rod end to break free. I must be doing something wrong...
  3. Mar 10, 2018 at 1:56 PM
    15whtrd
    15whtrd Mr. Blonde
    BFH! Don’t hit the joint itself if you can help it. Hit the side of it. Loosen but don’t remove the nut. In the past on an old truck I was working on I grabbed two nuts with the same thread as the castle nuts and threaded them on. That way I could hit the top of the joint without damaging the threads. I have not done it on the Tundra yet. Be wary of hitting that part though. Sorry I’m not more help.
    NewImprovedRon and Black Wolf like this.
  4. Mar 10, 2018 at 2:05 PM
    15whtrd
    15whtrd Mr. Blonde
    If it’s giving you a lot of problems you should be able to rent a ball joint separator removal tool at the auto parts store. It’s got two fingers that go underneath the joint and then a screw that pushes down on the top of the ball joint threads
    aperezsh and NewImprovedRon like this.
  5. Mar 10, 2018 at 2:11 PM
    lbcdan
    Daniel
    Long Beach, CA
    I got the driver. BFH it is. I was afraid to hit too hard and break something. I ended up using a 2x4 and finally got it free. Thanks for the help!
  6. Mar 10, 2018 at 2:16 PM
    15whtrd
    15whtrd Mr. Blonde
    rons23 and Black Wolf like this.
  7. Mar 10, 2018 at 2:31 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Get a harbor freight 20% coupon and get this I rented a similar tool from autozone, but theirs was too small. The harbor freight one was perfect.
    aperezsh and 15whtrd like this.
  8. Mar 10, 2018 at 2:37 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Why are you removing the tre? I just did mine last week and didn’t remove the tie rod end, just the two 22mm on the bottom
    equin and ColoradoTJ like this.
  9. Mar 10, 2018 at 10:57 PM
    lbcdan
    Daniel
    Long Beach, CA
    Thanks everybody for the quick responses.
    Unfortunately, I could not get the install instructions downloaded off Toytec's website. I went to Youtube and all the forum vendors but not all of the instructions were identical. Some had you remove the TRE some did not. Some had you drop the LCA, some did not. I panicked lol
  10. Mar 10, 2018 at 11:00 PM
    Js18tundra
    Just loosen the alignment cam bolts, and take out the two large bolts next to the lower Ball joint, then take off the four top hat bolts, and viola! Strut comes out
    rv740, equin and ColoradoTJ like this.
  11. Mar 10, 2018 at 11:08 PM
    lbcdan
    Daniel
    Long Beach, CA
    Thats exactly what I did on the passenger side. Not too sure if that was in the instructions because it gives EXTRA space to pull the strut out? But I learned my lesson.
  12. Mar 10, 2018 at 11:09 PM
    LML 3500HD
    I was thinking the same damn thing.
    Dan is all that is man. Dive right in without instructions. Been there before.........everytime..LOL!
    NewImprovedRon likes this.
  13. Mar 10, 2018 at 11:09 PM
    Js18tundra
    Did you use a compressor? Or did you use the floor jack on the lca method?
  14. Mar 10, 2018 at 11:10 PM
    lbcdan
    Daniel
    Long Beach, CA
    Floorjack on LCA. Seemed to go in with little struggle. I ended up installing 5100s with Toytec 1/4 spacer on top. Approx 2" which means it didnt take much to get everything to fall in place.
    Black Wolf likes this.
