5100 Bilstein Setting
Discussion in 'Suspension' started by swageit, Jul 9, 2018.
  1. Jul 9, 2018 at 3:07 PM
    swageit
    swageit [OP] New Member
    Mark
    I am getting all 4 corners of my Tundra upgraded to the Bilstein 5100's. I'm not installing a block on the rear. What setting should I use for the front? BTW, I'm getting everything done including labor and alignment for $500!
    Mikekoot and Okietundra like this.
  2. Jul 9, 2018 at 3:13 PM
    Professional Hand Model
    Hand Protectors
    A ‘shocking’ good deal!
  3. Jul 9, 2018 at 3:28 PM
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    The front would depend on what look you want. Im going to leave mine at factory height.
  4. Jul 9, 2018 at 3:32 PM
    swageit
    Mark
    Im trying to level it.
  5. Jul 9, 2018 at 3:39 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    If you go to the top setting, there is a LOT of preload on the spring that may make it a little harsh and give you SUPER fast rebound.
    If I still had them, Id do the 2nd to top setting at MOST.
  6. Jul 9, 2018 at 4:56 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    5100s have a minimum lift of .85" iirc
    15whtrd likes this.
  7. Jul 9, 2018 at 9:18 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I installed the front at the middle setting.
  8. Jul 9, 2018 at 9:20 PM
    Rica25
    Ricardo
    Tulare
    I did top setting and 1 inch rear
  9. Jul 9, 2018 at 9:21 PM
    r1-superstar
    DB
    UTAH
    Yes sir. Front 5100 Height adjustable front shocks adjustable with 3 different lift settings- .87″, 1.57″, and 2.28″
    heavyhank35 likes this.
  10. Jul 9, 2018 at 9:35 PM
    Tundra16LTD
    Tundra16LTD New Member
    Wilton Maine
    2016 Toyota Tundra Limited
    Looks good. Im thinking of going the same route on mine.
  11. Jul 10, 2018 at 10:01 AM
    swageit
    Mark
    Did you have this installed in another vehicle? If so, wasthe ride that bad?
  12. Jul 10, 2018 at 10:03 AM
    swageit
    Mark
    Did you notice a big difference in the ride quality?
    Rica25[QUOTED] likes this.
  13. Jul 10, 2018 at 10:09 AM
    Rica25
    Ricardo
    Tulare
    I noticed it is more stable but not bad
  14. Jul 10, 2018 at 10:33 AM
    swageit
    Mark
    Also i've been reading and some people have been installing a .25 shim. What is the reason for that and is it necessary?
  15. Jul 10, 2018 at 11:06 AM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    One thing I have noticed on internet forums... 1 person's "Not bad" is another person's "Sucks Balls" ;)
  16. Jul 10, 2018 at 3:55 PM
    DividedSky
    Jeff
    I had 5100's installed on my 1st Gen. It rode WAY better than the stock susp.
    My '04 was getting a little old, had 210K miles on it and I was itching for something new, so I got an '18. Put ADS on the new truck and it blows away what I had on the 1st gen.
    5100's on my 1st Gen really weren't that bad though. Just not Fox/King/ADS quality.
  17. Jul 10, 2018 at 4:34 PM
    offshore2005
    offshore2005 New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    I am in the same boat. I have the 5100’s and getting them put on with 295/55/20 cooper stt’s factory wheels. I will be going with the middle setting. They are putting all 4 shocks on and alignment for $350. Most places around Houston Texas are $300-450 for the 5100’s installed.
  18. Jul 10, 2018 at 8:19 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    What shop did you get the quote from, I'm in Conroe and just got my 5100's delv by UPS today.
  19. Jul 11, 2018 at 7:43 AM
    offshore2005
    TEXAS
    USA tire and wheel. They gave me a discount since I am getting my tires from the also.
    1603 Farm to Market 1960 Bypass, Humble, TX 77338
  20. Jul 12, 2018 at 12:33 PM
    Okietundra
    Okietundra New Member
    OKC OK
    2025 Lunar Rock Platinum
    I've been looking at the 5100s also. If I already have factory Bilsteins all around (TRD off road package), will the 5100s still give the same lift or would I be wasting my money?
  21. Jul 12, 2018 at 12:50 PM
    Darren509
    Darren
    Dayton NV
    The 5100 rears are not adjustable only the front are.
    Okietundra likes this.
  22. Jul 12, 2018 at 12:51 PM
    Okietundra
    OKC OK
    Ooohhh well that changes things.
  23. Jul 12, 2018 at 1:06 PM
    swageit
    Mark
    All finished! I opted for the middle setting.
  24. Jul 12, 2018 at 1:11 PM
    offshore2005
    TEXAS
    Nice.
    What size tire did you go with?
  25. Jul 12, 2018 at 1:17 PM
    swageit
    Mark
    I purchased the tires when I bought the truck and they are the stock size. Going to research that next and head to Discount Tire.
    offshore2005 likes this.
  26. Jul 12, 2018 at 1:23 PM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Can you do 5100's on the front and leave the rear stock (I had a TRD OffRoad) with no shims, shackles, etc?
    While I love my Tundra and would never go back I do miss the simplicity of the solid axles on my past Jeep Wranglers.
  27. Jul 12, 2018 at 1:31 PM
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    Yes but for an extra ~$150 you can just upgrade all 4 and still leave rear at stock height. Lift comes from springs/shackles/block/spacers, not the shocks.
    Riezen and rustynail11[QUOTED] like this.
  28. Jul 12, 2018 at 1:43 PM
    swageit
    Mark
    If you purchase 4 shocks or struts from 4wheelparts.com they will install them for $50 and not charge any tax if you have a location near you.
  29. Jul 26, 2018 at 5:40 PM
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    2017 CM Limited 4x4, all stock, 20" wheels, 275/55/20s, and would like to get to a taller tire without lifting. Planning to add the TRD sway bar as well.
    If I go with 5100s. can I get to 65s or 75 height tires without cutting or a lift kit.
    Will the 5100s get me there?
  30. Aug 18, 2018 at 1:51 PM
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    Sick truck! I'm thinking of getting 5100's and am wondering... since you have it on the middle setting, do you still have a little bit of rake?
    Mikekoot likes this.
