5100 Bilstein install difficulty?
Discussion in 'Suspension' started by MountainMan, Jun 27, 2023.
  1. Jun 27, 2023 at 1:58 AM
    MountainMan
    MountainMan [OP] New Member
    Idaho/Washington border
    2021 1794 Edition
    Bilstein 5100s, 285/70R17s, Tuff Country rear add-a-leaves, Rough Country rear bumper, Rough Country CAI, Dirty Deeds Ind. straight pipe kit, Ironman Raid front bumper, 13k lb. winch, Leer topper, custom rack, Decked bed drawer system, AuxBeam fogs, Midland CB radio.
    Bought a pair of 5100s for a 2021. Wondering how difficult the install is.
    I did my own spacer lift on my 2019 4runner and it was a PITA. I can afford the labor, but was wondering if it is easier or harder than a typical shock/strut replacement.
  2. Jun 27, 2023 at 2:12 AM
    Harder
  3. Jun 27, 2023 at 2:23 AM
    You have to remove the shock assembly, use spring compressors, transfer spring to 5100 with circlip set to desired lift, reassemble new shock, reinstall. The new shock assembly will be longer than the space it’s going into, so you’ll have to cram it in with straps and pry bars. Doable, but more frustrating and challenging than just bolting a spacer on top of a shock assembly.
    MountainMan[OP] likes this.
  4. Jul 3, 2023 at 10:09 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
  5. Jul 3, 2023 at 10:24 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Not very difficult. Did 4600 -> 5100 conversion to take a break and relax after miserable failure in transmission rebuild (for my other vehicle). This spring compressor will do it all on any car/truck, in a safely manner:
    https://www.amazon.com/MOSTPLUS-MacPherson-Compressor-Interchangeable-Extractor/dp/B07CV6L57D
    The truck will ride harsher, I'd recommend the lowest setting and a spacer on top of the strut, as already said. In fact, I'm going mid to low + spacer myself soon.
    Dragracer_Art likes this.
  6. Jul 3, 2023 at 10:59 AM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Eibach +2.5" springs on 5100's at the lowest setting is exactly 3" of lift and still rides like stock.
    A 1/4" thick spacer will be needed on drivers side to even out the 1/2" lean.
    I just did this 2 weeks ago and couldnt be happier.
  7. Jul 3, 2023 at 11:04 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    In MA we mostly drive over allies-bombed German asphalt imported in 1945. Any suspension change will be noticed immediately by even the most modest drivers.
    Hbjeff and Dragracer_Art[QUOTED] like this.
