50statesoverland - 2018 SR5 Cement CM Overland Build
Discussion in '3rd Gen Builds (2014+)' started by itsdchz, Feb 14, 2018.
  1. May 24, 2018 at 4:34 PM
    #61
    GodlessPro
    GodlessPro Former Pro BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
  2. May 29, 2018 at 8:40 AM
    #62
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Yep, if you like the insert you have, ordering the Pro grille is the way to go. If you don't like it, ordering a Sport/Platinum grille and having the surround painted is what you'll need to do.
    itsdchz [OP] likes this.
  3. Jun 13, 2018 at 8:03 AM
    #63
    itsdchz
    itsdchz [OP] 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon Stage 3, UCAs, SCS SR8 Bronze, SSO, VOODOO
    Added the @RCIoffroad Aluminum skids. Waiting for next sale to get gas tank skid! These are truly a work of art!
    Great build, fit, and excellent product!
    Easy install, great directions!
    I am certainly not a rock crawler, so the Aluminum made sense to me. Will be adding Transmission skid next time they have a sale!
    The pics of the crossmember bracket are there for reference, as that was the only questionable "where does this go" item that wasnt in the install pics.
    Install states to mount the bracket to skid first, as there is not enough room to bolt it to the skid after the bracket is on the crossmember. (Drivers side)
    I mounted the bracket, attached the passenger side, and then dropped the bracket mounted to the skid, and tightened the drivers side. I did this so that I was right on with alignment of the skid.
    Watt maker, shawn.roe24 and d0zer like this.
