5.7L Tundra Models and Trim Options Question
Discussion in 'General Tundra Discussion' started by Sgt_Gump74, Jul 25, 2022.
  1. Jul 25, 2022 at 6:51 PM
    Sgt_Gump74
    Sgt_Gump74 [OP] New Member
    Sgt Gump
    Which model/trim has the shifter on the steering column?
    Which model/trim has the 4.30 axle ratio?
    Thanks for any info!
  2. Jul 25, 2022 at 6:54 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Front bench seats have the column shifter and all 5.7s have 4.30 gears is my understanding
  3. Jul 25, 2022 at 7:48 PM
    mountaingroan
    mountaingroan New Member
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    Most SR models have the column shift/bench seat combo. Some SR5s do ( I have one in rare Voodoo Blue) and there were also a few rare TRD Off Road models without the "SR5 Upgrade package" (which includes the center console shift/captains chairs.) These rarer models have the bench/column shift.
    All upper level trims have the center console shift.
    Taco-Spike likes this.
  4. Jul 26, 2022 at 6:02 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    There is a year cut off somewhere but used to back in 07-13 ish you only got a 4.30 rear end with the tow package. The other option was a 4.10.
    I think now the newer 5.7 ones are all 4.30
    Most SR “work truck” and a few SR5s trims do not have a center console. The center console is more common. All high trim, anything above SR5 level trucks for sure have it
  5. Jul 26, 2022 at 2:01 PM
    Sgt_Gump74
    Sgt Gump
    Thank you!
    mountaingroan likes this.
