5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Aug 2, 2023 at 3:05 AM
    #1531
    TundraKirby
    TundraKirby New Member
    2000 Tundra & 2021 Tundra
    None
    New to forum and have owned 2000 Tundra SR5 TRD for 13 years. Picking up 2021 SR5 TRD Off Road this Friday. I do some towing of about 2500 lbs. and hope to get camper in future that would weight up to 60007000 lbs. I would like to get added protection of transmission cooler but GCS website says out of stock for now. Did sign up for updates. Taking a trip in September and towing several hundred miles and would like to have one installed before then. Any idea when kits for 2021 will be available or are there any other options? Thanks.
  2. Aug 2, 2023 at 4:29 AM
    #1532
    bflooks
    bflooks New Member
    Metrowest MA
    This is your answer assuming it is still available. Paging @M3Tundra-JK
    Oh!! And welcome!
  3. Aug 2, 2023 at 7:17 AM
    #1533
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I do still have it!
    Edit: it's been sold
  4. Aug 21, 2023 at 2:39 AM
    #1534
    TundraKirby
    None
    This weekend I took 2021 Tundra to mechanic friend who has a lift and we installed Genuine Cooling Systems 15 row transmission cooler kit and Talons Garage catalytic converter shields. With outside temperature around 90 degrees transmission pan temperature was around 203 during highway and city driving and about same conditions next day after install temperature was around 187. I will feel a lot more comfortable when towing now. Thanks to GCS for the cooler kit and Talons Garage for their aluminum transmission and transfer case shield.
    TXBrit, yakeng, Mttrekker and 2 others like this.
  5. Aug 26, 2023 at 8:01 AM
    #1535
    Genuine Cooling Systems [OP] New Member Vendor
  6. Sep 4, 2023 at 8:50 PM
    #1536
    DadsGetDubs
    DadsGetDubs New Member
    Will this work on 2021 sequoia?
  7. Sep 5, 2023 at 4:42 AM
    #1537
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Works well on mine.
  8. Sep 5, 2023 at 7:00 AM
    #1538
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    I need to get off my ass and install mine !!!
  9. Sep 7, 2023 at 9:51 AM
    #1539
    DadsGetDubs
    Did you follow the video? Anything different I should know about on our 21 nightshades vs the video? Also, did you check the temps before and after?
  10. Sep 7, 2023 at 1:00 PM
    #1540
    sd172
    sd172 New Member
    South Dakota
    I actually had mine installed by the dealership, and they just followed the instructions provided with the kit.
    As far as temperatures, I routinely hit over 200+ wile just driving in town, and now rarely see anything above 190 on a hot summer day.
  11. Sep 7, 2023 at 1:32 PM
    #1541
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    My 2014 Sequoia without a cooler stays around 200-215F in traffic. No towing or anything. I’ll probably add a cooler since my thermal degradation meter is maxed out.
    sd172 likes this.
  12. Sep 10, 2023 at 12:27 AM
    #1542
    DadsGetDubs
    That's crazy, my dealer told me they wouldn't install an aftermarket cooler.
  13. Sep 10, 2023 at 3:19 AM
    #1543
    sd172
    sd172 New Member
    South Dakota
    I guess the “W” word was never said out loud during my entire interaction history with them, and I was totally fine with that. YMMV..
  14. Sep 13, 2023 at 6:21 PM
    #1544
    icodeintx
    icodeintx New Member
    Scott
    Palacios, Texas
    2021 Cement Gray Tundra SR5 CrewMax
    LED Headlights, LED Fog Lights, LED Interior lights
    I'm getting ready to install a transmission cooler this weekend. The question I have is: Do I pull the thermostat pin after the install is complete? I've heard some say leave it open and some say pull the pin. Advice??
  15. Sep 13, 2023 at 6:28 PM
    #1545
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    Most likely will need it in place to let transmission get up to temps quicker. If too cold weather, torque converter wont lock up until warmed up.
    ATV25 and icodeintx like this.
  16. Sep 13, 2023 at 6:29 PM
    #1546
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    If I remember correctly, I pulled the pin after everything was installed and refill procedure was finished. So basically the very last step.
    ATV25 likes this.
  17. Sep 13, 2023 at 6:31 PM
    #1547
    icodeintx
    Scott
    Palacios, Texas
    Thanks, I guess I saw it on a YouTube video where someone said to leave the pin in. However, it just didn't make sense to me because the pin is meant to be pulled out for a reason.
    sask3m and ATV25 like this.
  18. Sep 20, 2023 at 11:59 PM
    #1548
    DadsGetDubs
    I know exactly what video you're talking about. That guy lives in Northern California where it doesn't get super cold and he drives long uphills to work. He stated he pulls the pin out to always keep it running and it never goes under 190 if I recall.
  19. Sep 21, 2023 at 3:52 AM
    #1549
    icodeintx
    Scott
    Palacios, Texas
    Yes that is the video. I live in Southern Texas where it rarely gets cold at all and coastal region so the roads are super flat. He says the thermostat is set to 250 degrees, if that is true won't my trans always get up to 250? Maybe I shouldn't worry about it. I only pull a big load about once a year.
  20. Sep 21, 2023 at 8:12 AM
    #1550
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Can't be 250. It starts to open probably around 175-180 degrees.
  21. Sep 21, 2023 at 6:00 PM
    #1551
    icodeintx
    Scott
    Palacios, Texas
    I hope so. It just didn't make sense if the thermostat was set for 250, what's the point then?
  22. Sep 22, 2023 at 5:02 AM
    #1552
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I bought and installed the kit on my 2020 Tundra, I belive in June of 2020. After install went for a drive around town before reinstalling the grill and watching the temp from the OBD reader. When the temp was showing like 185 degrees I stopped went out front and touched the lines to the cooler, the input line was notably quite warm while the return line was still cool.
    ATV25 likes this.
  23. Sep 24, 2023 at 8:00 PM
    #1553
    Matt56258
    Matt56258 New Member
    Matthew
    Savannah GA
    2021 Tundra Platinum MGM
    TRD grille, TRD dual exhaust
    Sorry for the double post - I forgot there was a thread for the trans coolers.
    How tight do the push lock fittings and the M22 to 6AM adapters need to be? And how do you get them tight but pointing in the right direction?
    I started off snug but keep getting a small leak. Tweaked it a few times got faster leaks.
    I’ve now tightened them to about as tight as I can get them with the push locks pointing in the right direction. I may need to top off the transmission fluid before another check run.
    Story
    I wanted to be cool (pun intended) like many others so I purchased a trans cooler kit from Genuine Cooling Systems. It’s been a while since I ordered but it’s been stupid hot here in SE GA until the last couple weekend.
    The install has gone pretty smoothly up until now. I can’t seem to get these fittings sealed. Any help would be much appreciated. I’m afraid of over torquing and stripping something out or yanking the hose loose from the other end.
  24. Nov 14, 2023 at 8:58 PM
    #1554
    Sully6
    Sully6 New Member
    Ken
    2020 cement trd off ry
    Anyone install this that has the TSS relocation kit from ajt? Does everything still fix properly
  25. Nov 14, 2023 at 11:09 PM
    #1555
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I dont have an AJT but looking at the pictures on their site, it mounts to the same hole that you relocate the horn to so you would have to either remove the horn or relocate it else where. First pic is from AJTs site and second pic is my trucks cooler, its the 20 row that they offered while the 15s where out of stock, so its a bit wider than the ones currently for sale.
    tundra_20 and Blue Thunder like this.
  26. Nov 15, 2023 at 7:19 AM
    #1556
    Sully6
    Sully6 New Member
    Ken
    Wow thanks for looking into that I'm sure I can move horn somewhere else I guess I'm more concerned about it interfering with sensor functionality the sensor already doesn't work that great there's gotta be someone out there that has installed both cooler and sensor relocation bracket
  27. Nov 20, 2023 at 11:20 AM
    #1557
    Black Friday starts NOW! Enjoy 10% off your kit when you use coupon code gobble at check out.
    The best 2019-2021 Toyota Tundra bolt on transmission cooler kit. Everything you need to to install a transmission cooler on your Toyota Tundra in a single box.
    Visit our site at https://genuinecoolingsystems.com to purchase your kit.
    404280715_363295772826253_19605738968657_db0fcdadbec0d731e2082fa3d7b06fbedadbee39.jpg
    Joe333x, tundra_20 and ATV25 like this.
  28. Nov 20, 2023 at 1:17 PM
    #1558
    Blue Thunder
    Washington
  29. Nov 20, 2023 at 1:22 PM
    #1559
    Please give it a try again. It should work this time. Thank you!
  30. Nov 20, 2023 at 1:48 PM
    #1560
    Blue Thunder
    Washington
    Green Thunder IT Services…
