5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Apr 18, 2023 at 4:24 PM
    #1471
    MuleHead
    MuleHead New Member
    2021 Tundra
    None so far.....
    Ordered the full kit. Can't tell you how frustrating it is finding out this was an issue. I bought my '21 a few weeks ago and occasionally tow my boat and a small equipment trailer. Mostly use it for running to baseball games. Plan to have the truck for a long time though so a necessary investment. Have most of you completed the install yourselves or used a mechanic? I certainly don't want to fk it up.
    Joe333x likes this.
  2. Apr 18, 2023 at 4:36 PM
    #1472
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    I installed myself in a few hours. Theres a couple YouTube videos I used for reference and it was pretty easy. Just make sure you have all the tools and take your time.
    MuleHead[QUOTED] likes this.
  3. Apr 18, 2023 at 5:49 PM
    #1473
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    It is really not that hard to install , did it in my garage and I don’t have a lift , make sure you have a torque wrench, obd2 reader so you can read trans temp , take your time and double check the steps , torque per specs and you should be good to go. Check for leaks for couple days after install to make sure all is good
  4. Apr 18, 2023 at 5:56 PM
    #1474
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I did it myself, my one mistake was I cut one of the rubber hoses just a little too short, it worked just fine but I wasn't happy with how tight it was so I bought another one and did it right.
  5. Apr 18, 2023 at 10:00 PM
    #1475
    MuleHead
    MuleHead New Member
    2021 Tundra
    None so far.....
    I've watched the video a couple of times and it does seem straight forward. I do have a trusted mechanic that has a reasonable rate - waiting to see if he has time but if not I'll probably tackle it myself. Thanks gents for the info - appreciate it greatly!
    Joe333x likes this.
  6. Apr 19, 2023 at 8:01 AM
    #1476
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    ?!?! What was your trick to getting the hardlines routed? Most of the job was easy. But as a whole, I'd say it was maybe a 5 or 6 out of 10. The hardlines were a PIA to both install and uninstall!
  7. Apr 19, 2023 at 5:02 PM
    #1477
    FISHN43
    FISHN43 New Member
    Ohio
    There was really no trick, just patience and a lot twisting them at different angles until they fell into place.
    I honestly felt like installing my cat shields were a way bigger PITA than the trans cooler.
    Johnmatrix, MadMaxCanon and ATV25 like this.
  8. Apr 19, 2023 at 7:24 PM
    #1478
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    The bruises on my hands and forearms would agree lol
    FISHN43[QUOTED] likes this.
  9. Apr 19, 2023 at 9:18 PM
    #1479
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    I’d rank it a 5/10 for difficulty, it’s mostly time consuming. Took me 4-hours, but because I made a couple of mistakes. I struggled with the rubber hose connections on the hardline the most. I got lucky and it only took a couple of minutes for me to route the hard lines. Attaching the hardline on the mounting point near the alternator wasn’t easy as there is barely any room to get up there.
    MuleHead, sask3m and M3Tundra-JK like this.
  10. May 5, 2023 at 8:32 AM
    #1480
    rdbonds
    rdbonds New Member
    2021 SR5 4x4
    I finally gave in and ordered my kit from Genuine Cooling Systems this morning. I've spent the past 7 months since I bought my new-to-me 2021 going back and forth between installing the kit or not. I no longer tow as much as I did back when I had either of my 1-ton diesels (nor as heavily, of course), but I do tend to keep my trucks a while (7-8 years for each of the 1 tons), so I suspect it will be worth it to me for peace of mind.
    A few weeks ago, I input the PIDs for trans temp into my OBDLink and monitored them on my commute home from work, for giggles. The weather was about 65 degF, and it got to 230+ at times just driving the 24 miles home on the pan temp in mixed highway and stop and go. I get it that WS fluid doesn't mind temps like others, but it bothers me.
    My Ram 3500 with Aisin Trans hovered at 158-160, and only got to 175-180 dragging my 13,000lb 5th wheel in the dead of summer. Yes, different beast with different transmission...but I'm a creature of habit I guess, and get a nervous tick knowing the temps are at 230+ when not towing. :)
    Joe333x, sd172 and ATV25 like this.
  11. May 5, 2023 at 8:43 AM
    #1481
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Should've ordered the full kit when it was on sale for $899 for the full 20-row. Ashamed at myself :rolleyes:
    Lemuel1, rdbonds, Ginsterkev and 2 others like this.
  12. May 5, 2023 at 8:45 AM
    #1482
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATV25 and KNABORES like this.
  13. May 5, 2023 at 2:02 PM
    #1483
    Ginsterkev
    Ginsterkev Lessons not learned in blood are soon forgotten
    Kevin
    Pennsylvania
    2019 tundra Trd pro supercharged
    Tvs1900 magnuson blower Team rxp catch can Wescott designs collar lift on fox factory suspension Front and rear TRD sway bars
    Literally just finished the install 10 min ago and I'm just waiting on a buddy to come over to monitor the temp so I can crack the drain open and get the level right but my god my knuckles and arms are busted the fuck up, very easy install but just no room for us guys with some neat hooks on us
  14. May 5, 2023 at 2:10 PM
    #1484
    MadMaxCanon
    I jumped on a kit a while back that had ugly welds for a discount. I was stoked. Might be worth asking him if he has ugly weld kits
    OHwendTrd[QUOTED] likes this.
  15. May 5, 2023 at 4:56 PM
    #1485
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I don’t think the Tundras.com member discount works anymore either.
  16. May 5, 2023 at 6:03 PM
    #1486
    Ginsterkev
    Kevin
    Pennsylvania
    I remember when they were that price 899 or so and I was like hmmm let me see if they go on sale and I belive there was a tundras discount to and here I am, and I just paid 1200 or what ever it was, oh well
    OHwendTrd likes this.
  17. May 13, 2023 at 3:51 AM
    #1487
    bflooks
    bflooks New Member
    Metrowest MA
    I just wanted to close the loop on my issue should anyone have similar problems.
    I have been watching my temps since my last post and it started becoming 200+ daily commute, with the cooler. Figured I'd check fluid, etc. I couldn't execute the check correctly which led me to question a blockage in the system.
    I ordered a new tstat online (about $100 cheaper than in store despite being a walk-in online purchase) and I did 2 things to try and figure this out. Not sure where the issue was, but it's now resolved and I can watch the thermostat open and immediately impact pan, torque converter and coolant temps. My test run has the transmission opening at 187, closing at 183.
    First: I used compressed air to test flow through the pinned open tstat after it was disconnected. Confirmed all ports were open.
    Second: purged the cooler part of the system with compressed air. After fluid was purged I was able to confirm no obstructions.
    Installed new tstat and left return line disconnected, ran the truck and purged/primed the system and confirmed I had fluid all the way to the return port on the tstat.
    After refilling, I was able to set the level without issue. Confirmed to be fixed.
    I don't know if there was simple a blockage somewhere that the air cleared or if it was the tstat, but it is resolved. I have the old part of someone thinks there is a better test than air through it.
    tundra_20, M3Tundra-JK and Ginsterkev like this.
  18. May 15, 2023 at 6:45 AM
    #1488
    rdbonds
    rdbonds New Member
    2021 SR5 4x4
    Installed my trans cooler Saturday, along with an oil change, front/rear diff fluid change, transfer case oil change (with what is apparently unicorn tears at $90/qt) and a transmission drain/fill. I was pleasantly surprised to see that the transmission fluid I drained out for the change (at 30K) looked really really good. This gives me confidence that with the cooler now, the trans will be even more happy. :)
    Today driving to work, temps held at 185, with occasional 188 spikes. Looks like it's working well! Thanks to everyone here for sharing your thoughts, and helping me to arrive at (for me) the right call to install one.
    Joe333x, sd172, EDDO and 2 others like this.
  19. May 15, 2023 at 6:59 AM
    #1489
    Jtundra81
    Joe
    Yeah , feels better to not have to constantly worry about your temp especially when towing
    Joe333x and FISHN43 like this.
  20. Jun 3, 2023 at 12:48 PM
    #1490
    Genuine Cooling Systems [OP] New Member Vendor
    We have full kits back in stock!
    15 Row - 2019 – 2021 5.7L Toyota Tundra
    10 Row - 2011 – 2018 5.7L Toyota Tundra
    15 Row - 2008 – 2022 5.7L Toyota Sequoia
    The next 20 orders that use coupon code freepeak will get FREE shipping and a FREE Veepeak OBDCheck BLE Bluetooth adapter.
    Coupon code freepeak expires 6/30/23.
    bulldog93, coldcanuk, Joe333x and 3 others like this.
  21. Jun 3, 2023 at 1:48 PM
    #1491
    bflooks
    bflooks New Member
    Metrowest MA
    Lemuel1 likes this.
  22. Jun 3, 2023 at 1:50 PM
    #1492
    I may release the 20 row kits later this year.
    Lemuel1, Joe333x, OHwendTrd and 2 others like this.
  23. Jun 3, 2023 at 2:41 PM
    #1493
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    :thumbsup:
  24. Jun 4, 2023 at 5:42 PM
    #1494
    *** Free 15 Row Full Kit, Veepeak OBDCheck BLE Bluetooth Adapter, and Shipping to lower 48 states. ***
    UPS destroyed one of our customers boxes during shipping recently. The contents survived just fine but the cooler box did get a little dirty and they lost some of the OEM hose bags. Nothing that you wouldn't have thrown in the trash anyways. I cant sell it as new so I have decided to have an "open box" giveaway to one of the lucky members here.
    To enter you need to go to our and give us a follow and also like this message. I will pick the winner on Monday June 12th. Good luck to you all! *New Customers Only*
    bulldog93, Kung, Js18tundra and 9 others like this.
  25. Jun 4, 2023 at 5:48 PM
    #1495
    @OHwendTrd Check out our latest post, try your luck at a 15 Row Kit!
  26. Jun 5, 2023 at 11:45 AM
    #1496
    Dowloader
    Dowloader New Member
    Done...fingers crossed. Really need it and funds are short right now.
  27. Jun 5, 2023 at 11:52 AM
    #1497
    M3Tundra-JK
    Scott
    2005 GX470
    It's possible I'll have a 20-Row kit to sell soon. It was only on the truck for a few thousand mile before truck got wrecked. I've already removed it, just haven't decided if I'm keeping it for the next project or not
  28. Jun 5, 2023 at 2:02 PM
    #1498
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
  29. Jun 5, 2023 at 2:19 PM
    #1499
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    How much are you gonna sell it for?
  30. Jun 5, 2023 at 2:25 PM
    #1500
    M3Tundra-JK
    Scott
    2005 GX470
    Looks like the costs of the kits have gone up since I bought mine. That and considering the 20-row isn't available atm, I'd like to get what I paid for out of it. Especially with the low mile usage of it. So $1100 shipped.
