5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Jan 22, 2023 at 8:30 AM
    #1441
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    20-row installed alongside giant s/c intercooler. I had to remove the upper left bracket for the AC Condenser (still stable), then move the trans cooler to the backside of the mounting bracket, and flip all the bolt orientation. But it fits!
  2. Jan 28, 2023 at 9:05 PM
    #1442
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Holy cow, is there any air left for the engine radiator?lol
    M3Tundra-JK[QUOTED] likes this.
  3. Jan 29, 2023 at 9:21 AM
    #1443
    M3Tundra-JK
    Scott
    2005 GX470
    Should be fine. I'm not running the TRD s/c intercooler, which blocks more of the radiator than this intercooler does. Time will tell!
    Saltyhero13 likes this.
  4. Jan 30, 2023 at 7:43 AM
    #1444
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
  5. Feb 14, 2023 at 2:08 PM
    #1445
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    @Genuine Cooling Systems
    Quick question, when checking the transmission level, does the trucks FRAME or the TRANSMISSION, need to be perfectly level?
    I’ve got a magnetized level and wasn’t sure if it’s the frame or trans that I’m checking when doing the fluid level check?
    I noticed that if the trans is level, the frame is not, and vice versa obviously
  6. Feb 14, 2023 at 2:29 PM
    #1446
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    When the truck is on a lift being serviced, the frame would be level. I bet either is good enough.
    MadMaxCanon and Spyker[QUOTED] like this.
  7. Feb 14, 2023 at 3:11 PM
    #1447
    Spyker
    that’s a great point about the service lift
    MadMaxCanon likes this.
  8. Feb 14, 2023 at 3:17 PM
    #1448
    Joe333x
    Joe333x Member
    Boston
    I just put the level on the pan myself.
    I believe he was asking about the kit that could add a second cooler to a truck that came with the one seeing as he has a 2016. It was an option on his old site but it seems he re-did things and hasnt been active on the forum much lately. I'm sure he still could seeing as that kit actually didnt use any Toyota parts, just the cooler, bracket and lines to the existing one.
  9. Feb 14, 2023 at 5:16 PM
    #1449
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    The frame of the truck was level when I did mine
    Spyker[QUOTED] likes this.
  10. Feb 14, 2023 at 5:39 PM
    #1450
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    @Spyker if I recall correctly, the first time I did the transmission fluid check, I checked level on the bottom of the frame rail near the transmission and the pan itself, finding they were both about the same. I check right-left level on the pan. When I did the fluid drain and fill service, I just checked the pan.
    Spyker likes this.
  11. Feb 14, 2023 at 5:58 PM
    #1451
    Spyker
    In regards to the two different transmissions, AB60F and A760F, are they both to be checked between 99 - 111°F?
    I read in a few threads the temp ranges are different?
  12. Feb 14, 2023 at 6:13 PM
    #1452
    Spyker
    Did some more digging on the forum and found the following info;
    Transmission type for the 5.7L is AB60E/F (E=2WD, F=4WD), and fluid level check temperature range is 99-111 degrees F.
    Transmission type for the 4.6L is A760E/F, and fluid level check temperature range is 127-138 degrees F.
    M3Tundra-JK and Joe333x like this.
  13. Mar 21, 2023 at 9:43 AM
    #1453
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I contacted them via email about a product; you may give their email address a try: genuinecoolingsystems@gmail.com
    Reply that I received didn't come from Nick, so it could be that he is no longer involved or there are multiple parties. Either way, they were friendly and I will give them business in the very near future. The latest bracket and cooler that GCS offers is the best one that I have seen for the 2019-21 Tundra/Sequoia platform.
    ATV25, Rodbolt and M3Tundra-JK like this.
  14. Apr 7, 2023 at 8:29 PM
    #1454
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    I just finished installing a 15-row kit from Genuine Cooling Systems. Some observations:
    • High quality kit and well setup. I ordered the partial kit as the hardline was back ordered. However, I searched eBay for a couple of weeks and found a seller with a new one.
    • Don’t be dumb like me, when you open the ATF fluid to use it to lube the lines, put the cap back on. When I was shuffling under the truck I accidentally knocked over the bottle and lost about a half quart. Ended up with just enough.
    • My previous truck (F-150) was lifted and I’m used to not having to lift my trucks to work on them. My 2020 Platinum is stock height. I didn’t bother lifting it up as it was perfectly level in the garage, that was a mistake and made it much more difficult to install.
    • By far the hardest part was installing the tubing on the front hard line. I couldn’t get much leverage and despite lubing the tube, it was extremely hard to get on.
    • At 45K miles, the transmission fluid looked absolutely scorched when it was draining out of the warmer puck. I’m glad I installed this, but will be changing out the fluid again soon.
    • I struggled a bit with getting the grill off. What helped me was to lift the top of the grill to clear the white tabs first, then start on the left side and put a bit of downward pressure and pulling back to help the clip at the bottom clear. Moved to the right side and repeated.
    • I hate stock Toyota skid plates.
    ATV25, bulldog93 and MadMaxCanon like this.
  15. Apr 8, 2023 at 4:03 AM
    #1455
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Had you ever gotten the tranny temp light before since you said the fluid was toast?
    Retired...finally likes this.
  16. Apr 8, 2023 at 5:24 AM
    #1456
    Jtundra81
    Joe
    It was already tested by someone on here , the color means nothing , ws will change color but that doesn’t mean it is bad.
    MadMaxCanon[QUOTED] likes this.
  17. Apr 8, 2023 at 5:58 AM
    #1457
    yakeng
    I haven’t ever had the light come on.
  18. Apr 8, 2023 at 6:00 AM
    #1458
    yakeng
    That’s good to hear. I’m still going to replace mine. I’d like to sample and test the ATF once I replace it.
  19. Apr 8, 2023 at 2:13 PM
    #1459
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    The liquid itself probably would not care if the temperatures were around 200 C, but the plastic parts and rubber seals do not hold up above 100 C for very long. This is beyond my comprehension why Toyota decided to change the tried and true design.
  20. Apr 8, 2023 at 2:53 PM
    #1460
    Jtundra81
    Joe
    Save money , that is the only explanation since they changed the refrigerant, I added mine when truck had 12k miles and wasn’t towing heavy , will still service at 30k
  21. Apr 9, 2023 at 7:15 PM
    #1461
    Ginsterkev
    Ginsterkev Lessons not learned in blood are soon forgotten
    Kevin
    Pennsylvania
    2019 tundra Trd pro supercharged
    Tvs1900 magnuson blower Team rxp catch can Wescott designs collar lift on fox factory suspension Front and rear TRD sway bars
    Looking forward to installing this kit since it just came back into stock I just ordered it 5 min ago from genuine cooling systems
    ATV25, yakeng and MadMaxCanon like this.
  22. Apr 9, 2023 at 9:05 PM
    #1462
    engineer
    engineer Drive it 4ever
    Seattle, WA
    '21 Limited Double Cab
    A little off topic, but here's an informative discussion from the Car Care Nut about changing transmission fluid:
    Link to youtube
    Tundrastruck91, yakeng and Joe333x like this.
  23. Apr 10, 2023 at 4:45 PM
    #1463
    bflooks
    bflooks New Member
    Metrowest MA
    I haven't been able to find an answer to this question: does anyone know at what temp the thermostat is fully opened at?
    I'm not knocking this kit. I have it and I'm debating paying for a bracket so I can upgrade to a 20 row because I've seen up to 219/220 when towing. I've read that it's possible the thermostat doesn't actually open until 225 but I've not gotten that high to confirm. I'm going to pin it to see if there is a difference, but figured I'd ask here.
  24. Apr 10, 2023 at 5:01 PM
    #1464
    Joe333x
    Joe333x Member
    Boston
    You could have definitely found that answer in here if you search just this thread but to answer the question it opens around 185°. I have the 20-row and not towing the temps stay right around 185°-190°. You can try pinning open the thermostat but wouldn't recommend it, I tried it with mine and temps would be around 160°.
    bulldog93 likes this.
  25. Apr 10, 2023 at 5:03 PM
    #1465
    Jtundra81
    Joe
    It totally open around 195 , after installed the cooler , I never went above 195 on pan even when towing
    M3Tundra-JK likes this.
  26. Apr 10, 2023 at 5:28 PM
    #1466
    bflooks
    bflooks New Member
    Metrowest MA
    Yeah, so this is why I asked.
    I've seen the 185 number for years and is why I bought the kit. 195 is common for me around town with 30+ minutes, normal suburban commute. Not uncommon to see 205 at highway speed. Neither are terribly concerning to me until towing at highway.
    More research suggests the thermostat actually opens closer to 225.
    I have not been able to find something authoritative from Toyota. With the part now being good through 21 models, I'm not sure if the operating temps have been adjusted, too.
    Ginsterkev likes this.
  27. Apr 10, 2023 at 5:39 PM
    #1467
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Could be that your thermostat is faulty.
  28. Apr 10, 2023 at 5:40 PM
    #1468
    Joe333x
    Joe333x Member
    Boston
    It definitely does not open at 225°. Before adding my cooler I regularly seen 225°+ with normal driving, after adding the cooler rarely goes above 200° so the thermostat definitely opens somewhere in the 185-195 range.
  29. Apr 10, 2023 at 6:15 PM
    #1469
    bflooks
    bflooks New Member
    Metrowest MA
    Not something I was thinking. I'll pin and see what the result is. Certainly wouldn't be the worst repair. Thx for the reply!
  30. Apr 11, 2023 at 7:17 AM
    #1470
    yakeng
    I’ve only had my 15-row installed four days now, but have taken in on a few 50mi+ trips and in stop/go traffic. The temps get to around 185-189 but are not breaching 190 now. I don’t have the pin installed and I think it’s activating around 185F. When I got home, the tubes were warm and so was the cooler.
    For reference, I was pushing 210F in my daily commute before install, so pretty happy with the results.
    DZ_, Joe333x and MadMaxCanon like this.
