5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Sep 16, 2022 at 3:50 PM
    #1411
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Last wkend we went exploring in the hills. A couple miles of slowly driving up this hill in 4HI had the pan at 220°F. Certainly glad I had the cooler!
  2. Sep 16, 2022 at 4:17 PM
    #1412
    Genuine Cooling Systems [OP] New Member Vendor
    Awesome! you won't be disappointed. We shipped your kit this morning.
    HonorNotInner[QUOTED] likes this.
  3. Sep 16, 2022 at 7:05 PM
    #1413
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Try using 4 low if you're not traveling high speeds, you'll have lower temps. I use 4lo for off road and 4hi for inclement weather on road.
  4. Sep 17, 2022 at 5:13 AM
    #1414
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Yes, aware of 4LO and trans temp.
    Joe333x[QUOTED] and Blue Thunder like this.
  5. Sep 17, 2022 at 10:50 AM
    #1415
    Joe333x
    Joe333x Member
    Boston
    Gutcha, just figured I'd throw it out there since I learned just from reading in this forum after a guy posted a high temp warming driving 4hi on the beach. I always thought 4lo was for real tough off roading but in reality even just driving on sand at low speeds makes sense.
    GODZILLA and DZ_[QUOTED] like this.
  6. Sep 17, 2022 at 12:02 PM
    #1416
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Same, and agree. I never really used 4LO until I drove that 4Runner in the hills out west. Never felt like the power and the torque of 4LO was needed with the V8.
  7. Sep 21, 2022 at 2:40 AM
    #1417
    Setrab 15-row kits are now $100 off! (while supplies last)
    GODZILLA, DZ_, sd172 and 1 other person like this.
  8. Sep 21, 2022 at 6:04 AM
    #1418
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Order placed for a 20 row. I noticed the 5% Tundras.com discount doesn't work anymore. Installing a stage 2 Harrop in the next few weeks.. might as well have them install this too. :cool:
  9. Sep 21, 2022 at 6:11 AM
    #1419
    We’ll get your order out tomorrow morning.
    Blue Thunder and V10Ace[QUOTED] like this.
  10. Sep 21, 2022 at 3:55 PM
    #1420
    t-rey1
    t-rey1 New Member
    Ive never had temp issues
  11. Sep 21, 2022 at 9:19 PM
    #1421
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I hit 102.7 when I came down with Covid a few weeks ago.
    norma30a likes this.
  12. Sep 21, 2022 at 10:22 PM
    #1422
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    I was doing some fairly mild off-road driving, wasn't even in 4wd and my trans pan temperature was 240. Torque converter hit 260. 2020 Tundra
  13. Sep 21, 2022 at 10:26 PM
    #1423
    Joe333x
    Joe333x Member
    Boston
    Decent time to grab a cooler while he's running a sale. I have the 20 row and my temps stay between 185-191 now.
  14. Oct 9, 2022 at 10:18 PM
    #1424
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Roughly how many quarts for a Drain & Fill with the thermostat pinned? I have the 20Row system, thanks.
  15. Oct 10, 2022 at 1:44 AM
    #1425
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    4-ish
    Tsm503[QUOTED] likes this.
  16. Oct 10, 2022 at 1:55 AM
    #1426
    Joe333x
    Joe333x Member
    Boston
    The 20 row has a 0.55 quart capacity and a normal drain and fill is 4 quarts or less. Id be willing to bet it still ends up being about 4 quarts but might as well have 5 on hand just Incase. ATF WS comes in a box 6.
  17. Oct 10, 2022 at 8:07 AM
    #1427
    Tsm503
    2021 DC SR5
    Thanks for the info!
    Joe333x[QUOTED] likes this.
  18. Oct 10, 2022 at 8:17 AM
    #1428
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Does Toyota typically pin the thermostat when doing a drain and fill?
  19. Oct 10, 2022 at 8:22 AM
    #1429
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Yep, it's in the Toyota service procedure.
    sask3m[QUOTED] likes this.
  20. Nov 1, 2022 at 10:09 AM
    #1430
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    Has anyone relocated the trans cooler to a different location? Having it right in front of the s/c heat exchanger has my IAT temps 10+ degrees hotter than they were before. So I need to move it where it’s not directly in front of it.
    M3Tundra-JK likes this.
  21. Nov 1, 2022 at 11:06 AM
    #1431
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Interested in an answer. Are you running the 15 or 20 row setrab? Will be installing s/c in next couple of months
  22. Nov 1, 2022 at 11:08 AM
    #1432
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    I went with 15 because I figured it would block the HX less.
    M3Tundra-JK[QUOTED] likes this.
  23. Nov 1, 2022 at 11:11 AM
    #1433
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Interesting.
    I run the 15 row & Avg ~25 degrees of delta in IAT. (Harrop sensor vs dash)
    are you saying you were running ~15 degrees of delta before the HX?
    that would be remarkable.
  24. Nov 1, 2022 at 11:13 AM
    #1434
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    I was 30-32 degrees above ambient and now I’m atleast 40 degrees above ambient after the trans cooler
  25. Nov 1, 2022 at 11:18 AM
    #1435
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yikes.
    to be fair...I have no idea what I was before the HX.
    make sure your I/C pump is working - my relay was intermittent on & off. all fixed now.
    and - not that this is the culprit - check your I/C fluid. I was 6oz low this weekend - for no damn reason!
  26. Nov 1, 2022 at 11:20 AM
    #1436
    M3Tundra-JK
    Scott
    2005 GX470
    Dang I'm running the 20-row trans cooler. But also ordering the 101 intercooler from frozen boost. I'll have to get all my monitoring sorted out before then
  27. Nov 18, 2022 at 12:12 PM
    #1437
    spyshot
    spyshot 1Cor 15:55-57
    Ohio
    2019 Tundra Platinum
    Platinum pretending to be Pro
    What temp is the thermostat set to open?
  28. Nov 18, 2022 at 12:48 PM
    #1438
    Joe333x
    Joe333x Member
    Boston
    Around 185°
    Johnmatrix and spyshot[QUOTED] like this.
  29. Nov 18, 2022 at 5:32 PM
    #1439
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    About to add one of these TruCool bypass valves to my 01 4Runner whose getting a new reman'd transmission. I run an aux bypass cooler and this will bypass both the aux and the built in radiator cooler to get the trans up to operating temps faster.
    Wonder if it will help with a '15 sequandra, thoughts? Or can the sequandra be pinned instead and use this to throttle the use of the cooler. This thing bypasses until fluid hits 180+.
    https://www.amazon.com/gp/product/B008BTJFJ4?ie=UTF8
  30. Nov 18, 2022 at 5:42 PM
    #1440
    Joe333x
    Joe333x Member
    Boston
    Does your sequoia use the totoya oem thermostat?
