5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Aug 21, 2022 at 5:01 AM
    #1381
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    when your done...don't leave the pump in the garage attic, with the top closed tight, above your cars. because the heat will squish out whatever fluid you left in there and drip all over you stuff.
    hypothetically speaking....
    GODZILLA, Giskk, Blue Thunder and 2 others like this.
  2. Aug 21, 2022 at 5:07 AM
    #1382
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I keep mine in a ziploc inside of an oil pan, inside of a plastic bag lol. Also learned my lesson to not try to clean them. Just purge with what ever fluid I'm using next.
  3. Aug 21, 2022 at 5:28 AM
    #1383
    Genuine Cooling Systems [OP] New Member Vendor
    No, sir. We have it listed as a "tool required" to complete the install.
  4. Aug 21, 2022 at 10:03 AM
    #1384
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Late night, I though he meant like a main pump for the car's tranmission lol
  5. Aug 21, 2022 at 10:39 AM
    #1385
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Yeah, as mentioned, separately provided. Not sure why I thought of it last night while I was half asleep.
  6. Aug 21, 2022 at 2:02 PM
    #1386
    M3Tundra-JK
    Scott
    2005 GX470
    What a pia bolt lol. Definitely helps to have various types of 13mm wrenches. Swivel ratcheting wrench did great on the rear. Used like three different types on the front one. Fully tighten it with a short regular 13mm wrench. Couldn't really get anything else to bite
    Roselaker, JDR76 and DZ_ like this.
  7. Aug 21, 2022 at 2:11 PM
    #1387
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Yep. Those two bolts were a bit tricky.
  8. Aug 28, 2022 at 5:02 PM
    #1388
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Got ‘er installed :thumbsup:
    I tow a small 17’ boat, nothing too heavy, planning on keeping this tundra for a very long time, so I’m looking forward to many miles and years of a happy cool transmission :thumbsup:
  9. Aug 28, 2022 at 5:21 PM
    #1389
    M3Tundra-JK
    Scott
    2005 GX470
  10. Aug 28, 2022 at 7:42 PM
    #1390
    Saltyhero13
    Saltyhero13 Throbbing Member
    I have a 2020 with both the Genuine Cooling kit and the Stillen. My original deflector was already cut up to accommodate the S/C intercooler pump and the transmission cooler lines so I just traced the opening for the Stillen duct. I used a rotary tool, tin snips and file to shape the opening.
    M3Tundra-JK[QUOTED] likes this.
  11. Aug 29, 2022 at 2:49 AM
    #1391
    Great question. Stillen provides you with a new shroud with an opening for the hoses. Instead of drilling the two holes for the hoses, both hoses will pass through the one hole in the Stillen shroud. If abrasion is a concern, I can send you some spiral hose protection just in case, just put it in the order notes if you do place an order.
    - Nick
  12. Aug 29, 2022 at 3:28 AM
    #1392
    18" TRD Off Road Wheels
    They'd just pass through this notch, wouldn't they?
  13. Aug 29, 2022 at 3:30 AM
    #1393
    That is correct.
  14. Aug 29, 2022 at 5:28 AM
    #1394
    Saltyhero13
    My original deflector was already modified before installing the Stillen.
    I did look at installing the Stillen deflector but I suspect it would only allow one transcooler hose through without creating a restriction and I would still have to butcher it to allow for the intercooler pump hoses to pass through.
  15. Aug 29, 2022 at 6:04 AM
    #1395
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I think @2020Platinum has a youtube install vid and he had the same intake.
    2020Platinum likes this.
  16. Aug 29, 2022 at 7:14 AM
    #1396
    Saltyhero13
    He drilled holes in the Stillen air deflector:
  17. Aug 29, 2022 at 7:52 AM
    #1397
    M3Tundra-JK
    Scott
    2005 GX470
    Hey, thanks y'all! Awesome replies! I'll post up my experience with it as well after it arrives later this week.
  18. Aug 30, 2022 at 4:48 AM
    #1398
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Thanks for the mentions guys!…Scott if ya need help or have any questions shoot me a message…glad to try to assist if I can, and I do have YouTube videos on installing Nick’s kit as well as installing the Stillen…very easy projects and Nick puts together an awesome kit!
  19. Sep 4, 2022 at 6:13 PM
    #1399
    M3Tundra-JK
    Scott
    2005 GX470
    I didn't want to uninstall the trans cooler hoses so I just cut a hole in the factory shroud for the stillen air inlet. Easy peasy
  20. Sep 7, 2022 at 9:25 AM
    #1400
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
  21. Sep 7, 2022 at 9:28 AM
    #1401
    M3Tundra-JK
    Scott
    2005 GX470
  22. Sep 16, 2022 at 5:56 AM
    #1402
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    85EAF39C-6891-486F-A563-5ECF646D0E13.jpg 351243F8-3013-49A5-9DCC-D93F6D2975D0.jpg Did Toyota lower the high transmission temp alert to 260 degrees for the 2020’s? Everywhere I read I see 302 degrees. But yesterday mine went off at 260.
  23. Sep 16, 2022 at 5:58 AM
    #1403
    That’s interesting… Toyota must have programmed it to set off at 260F in their latest ECU version.
  24. Sep 16, 2022 at 6:24 AM
    #1404
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Was that the pan or torque converter?
  25. Sep 16, 2022 at 6:30 AM
    #1405
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    TBH I’m not sure. That headunit only has one transmission option. I was just assuming it was the pan. I’ll see if I can find out.
    Jtundra81[QUOTED] likes this.
  26. Sep 16, 2022 at 6:32 AM
    #1406
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    Just ordered your kit yesterday though.
    M3Tundra-JK and Jtundra81 like this.
  27. Sep 16, 2022 at 6:32 AM
    #1407
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    If you're using a Maestro iDatalink, that's definitely pan temp.
  28. Sep 16, 2022 at 6:33 AM
    #1408
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    Oh gotcha, ya I’m using maestro.
  29. Sep 16, 2022 at 6:34 AM
    #1409
    Jtundra81
    Joe
    If that is your pan , your torque converter is the one that most likely hit the 302 mark which triggered the alarm , I would look into the option of displaying your tc as well
    HonorNotInner[QUOTED] likes this.
  30. Sep 16, 2022 at 6:37 AM
    #1410
    Jtundra81
    Joe
    Best way to go , you won’t have to worry about temps anymore
    JDR76 and HonorNotInner[QUOTED] like this.
