5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. May 20, 2021 at 12:18 PM
    #661
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Lyndon B Johnson had a brick made of each of his visitors signatures when they visited his Texas ranch. Pretty cool you can see replicas if you tour his ranch. Outside San Antonio
  2. May 20, 2021 at 12:31 PM
    #662
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Ya haul bricks, tranny gets hot. Tranny gets hot, ya install a cooler. What you mean? Lol
    Terndrerrr and a522467 like this.
  3. May 20, 2021 at 12:42 PM
    #663
    Saltyhero13
    Saltyhero13 Throbbing Member
    I $#!+ a brick once. I wonder if anyone ever collected it. :monocle:
    mech_engineer09 and FISHN43 like this.
  4. May 22, 2021 at 5:22 PM
    #664
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    The brick thing is pretty cool. I like the fact that you're preserving history.
    a522467 likes this.
  5. May 25, 2021 at 9:15 PM
    #665
    gomGom
    gomGom New Member
    Los Angeles CA
    2021 Tundra DC SR5 4x4, 2014 FJ Cruiser 4x4
    I installed mine last week, took me about couple hours. Tranny Temp was going over 200 even when the truck was empty, and now it's around 160~170 degree in same condition. I wish it came with black color but still pretty satisfied
      File size:
      110.5 KB
      140
    BR73 and Wallygator like this.
  6. May 26, 2021 at 12:25 AM
    #666
    white rocket
    white rocket New Member
    2021 Tundra CrewMax Platinum 4x4 MGM
    Came here for oil cooler info; now rabbit-holing bricks. Well played:hattip:
  7. May 26, 2021 at 2:00 PM
    #667
    Genuine Cooling Systems [OP] New Member Vendor
    Memorial Day Sale. 10% off transmission cooler kits starting today through 1-June.
    No code necessary.
  8. May 26, 2021 at 2:21 PM
    #668
    Wallygator
    Nice! I also have the original kit. See temps as high as 209-213 towing 3000lbs through mountain passes (pushing it) but usually stays at 187-200 not towing. I can live with that cuz I was seeing 228 or higher unloaded normal highway driving before the kit. Not acceptable.
  9. May 26, 2021 at 5:11 PM
    #669
    bflooks
    bflooks New Member
    Metrowest MA
    Amazing product at a great discount. If you tow, this is a no brainer! Thanks to @chasenicholas93 for developing a solid, complete, as close to factory as possible solution.
    I can attest that it works as advertised.
  10. May 26, 2021 at 7:36 PM
    #670
    rothmigo
    rothmigo New Member
    DFW TX
    2020 Tundra Crewmax Platinum
    7" BDS/Fox, 5.29, 37x13.50 Nitto, 22x12 Hostile Rage,BAM
    I sprayed mine with radiator black (before install), it's a specialized thin paint and finicky about timing of 2nd coat but so far so good. I can still smell the paint cooking now and then lol. Honestly I don't think it jumps out at you on your truck as is..nice lookin rig! And since I see Nick is offering a sale, figured I'd bump the thread!
  11. May 27, 2021 at 5:33 AM
    #671
    co2owen
    co2owen New Member
    VA
    2020 Cement Limited CM TRD Off-Road
    Trans Cooler. 5100's up front at mid-setting. ESP Plastic Storage.
    I can attest it works as advertised too. I installed a few weeks ago and still have not seen pan temps climb above 190. I have not towed yet but will this summer. I have the Setrab kit.
  12. May 28, 2021 at 6:22 AM
    #672
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    Might need to order one of these. Install looks pretty straight forward.
  13. May 28, 2021 at 6:35 AM
    #673
    co2owen
    co2owen New Member
    VA
    Install was a breeze. I worked slow, double checked everything, and it took me and my dad four hours and that included plenty of breaks for beer!
  14. May 28, 2021 at 6:49 AM
    #674
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    4 hours with beer breaks sounds pretty good to me! lol
    BR73 and co2owen[QUOTED] like this.
  15. May 28, 2021 at 1:54 PM
    #675
    was209
    was209 New Member
    Kingfield, Maine
    2020 Tundra TRD Pro, Superwhite
    Trifecta tonneau, tube steps, Setrab transmission cooler
    Installed the Setrab last weekend. I’m seeing temps in the 185 range on a 20 mile commute in the mountains. Just towed my TT, 3600 lbs. in a very hilly area in S4/Tow-Haul on, 50-60 mph, ambient outside temp of about 65 degrees. Temps never went over 188.6 in the pan. Great kit, very happy.
  16. May 28, 2021 at 3:05 PM
    #676
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Wow, that's very good. About the same temp as my wife likes her steaks :rolleyes:
  17. May 28, 2021 at 5:21 PM
    #677
    LennyFL
    LennyFL New Member
    New to me 2007 with 59,600 miles
    Just a simple question. Why wouldn't you prefill the new radiator with AT Fluid? Seems it would help to remove air in the lines.
  18. May 28, 2021 at 6:09 PM
    #678
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I'm no expert but isn't there a breather on the trans?
    Saltyhero13 likes this.
  19. May 29, 2021 at 10:22 AM
    #679
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Just ordered the Setrab kit for my 2021 Sequoia. Any issues with relocating the horn since the Sequoias have the extra front mounted A/C fan?
  20. May 29, 2021 at 5:02 PM
    #680
    You'll mount it to the vertical cross member just as the photo below shows. The wire in the photo won't be required.
    sd172[QUOTED] likes this.
  21. May 29, 2021 at 5:46 PM
    #681
    sd172
    sd172 New Member
    South Dakota
    Thank you. Will post pictures of the install plus temperatures before and after. Not really concerned about towing at this time, but would like to see my pan temperatures stay below 195 when driving on the highway in summer.
  22. Jun 3, 2021 at 6:26 PM
    #682
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    Setrab kit is installed. The kit instructions and nitrofishing’s video and many tips here made it easy. Running around town I can already see a temp difference. Looking forward to towing.
    It is good to have a “genuinely cool” truck. :woot::woot:
  23. Jun 6, 2021 at 11:59 AM
    #683
    bflooks
    bflooks New Member
    Metrowest MA
    For anyone looking for additional feedback. I just got my first tow in since install.
    The Setrab kit netted me 20-50 degrees cooler than last year, with temps right at 200 (highest was 203).
    I was towing 8k lbs in S4 T/H at 65mph in 91 ambient temp with a 20 mph headwind. It was a tough tow that netted me 7.3mpg, if that helps anyone, and I couldn't be happier to see the trans temps no longer being a concern.
  24. Jun 6, 2021 at 12:39 PM
    #684
    xeuxaz
    xeuxaz New Member
    2024 MGM Platinum
    Just ordered the Setrab kit.
  25. Jun 6, 2021 at 5:28 PM
    #685
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Should have used S5 you must been turning 3K rpms
    sask3m likes this.
  26. Jun 6, 2021 at 5:41 PM
    #686
    co2owen
    co2owen New Member
    VA
    This is impressive. I’m pretty much done monitoring temps. There’s just no need with the cooler installed.
    Dallas007 and bflooks[QUOTED] like this.
  27. Jun 6, 2021 at 5:41 PM
    #687
    bflooks
    bflooks New Member
    Metrowest MA
    It was an odd day with the headwind and it would have been scavenging a lot. Sadly this alpears to be the weakness in switching to the 275/70/18 Falkens. The extra weight and size made me consider if a regear is in its future.
    Time will tell, but i couldn't have run a higher gear today. Without wind, probably would have been fine.
  28. Jun 6, 2021 at 8:47 PM
    #688
    TheBear
    TheBear New Member
    Harry
    New Mexico
    2021 Tundra Limited
    You mean there is no transmission cooler on the Tundra?
  29. Jun 6, 2021 at 9:08 PM
    #689
    18" TRD Off Road Wheels
    Removed on 2019+ when the refrigerant for the AC legally had to change. New stuff wouldn't effectively do the job, so Toyota dropped the trans cooler. Read some previous pages in the thread. Lots of discussion.
  30. Jun 6, 2021 at 9:30 PM
    #690
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Manual says to tow in S4 at or under 65mpg.
    The way I understand it, the new refrigerant needed more radiator. So the radiator up front that was half for the AC and half for the trans fluid is now just for the AC. The two systems did not interact in any way. Toyota slapped a plate where the thermostat used to be on the side of the transmission and allegedly changed TC lockup programming to help keep temps down.
    tundra_20 likes this.
