5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. May 2, 2021 at 3:07 PM
    #631
    timsp8
    NY
    The transmission wants to be around 190. That’s where it stays on 07-18s with the factory cooler. Toyota planned on it being there with having the warmer attached to the transmission. 185-197 is perfectly fine. The cooler is there to dissipate the heat, but it still has to wait for the thermostat to open.
    bflooks[QUOTED] likes this.
  2. May 2, 2021 at 7:08 PM
    #632
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    If you think you don’t need the cooler, you may want to think again. Gathering some pre-cooler data, I saw 228 degrees on the pan temp today just running to town and back. I wasn’t towing anything and had a light load (6 bags of mulch). 80 degrees ambient today in SE Ohio. I’m planning to haul a load of bricks to Oklahoma next month. No doubt I will finish up the cooler kit installation before then.
    Kung, Wallygator, rebmo and 4 others like this.
  3. May 2, 2021 at 7:28 PM
    #633
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    80 degrees and 65 mph...I was running 217 with no payload. Gotta find a grand I guess and buy the cooler...
    Wallygator and IndianaGeologist like this.
  4. May 2, 2021 at 7:56 PM
    #634
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Reading those PID'S seem pretty confusing when you look at the yellow and red zones respectively. Coolant temp. is absolutely normal, but is at about 3/4 into the red zone. Pan and convertor are in the lower red and yellow zone, but this is somehow abnormal? Can someone explain to me how this is a problem? :notsure:
  5. May 2, 2021 at 8:09 PM
    #635
    a522467
    Michelle
    Ohio
    Colors are arbitrarily set by whoever makes the dashboard. They can be easily adjusted.
    IndianaGeologist and JohnLakeman like this.
  6. May 2, 2021 at 8:12 PM
    #636
    TILLY
    Massachusetts
    So you the owner can set the colors, or its set when you download it?
  7. May 2, 2021 at 8:18 PM
    #637
    a522467
    Michelle
    Ohio
    It’s easy to change it in OBD Fusion. I just moved up the limits on coolant temp, since they were set too low.
    IndianaGeologist likes this.
  8. May 2, 2021 at 8:28 PM
    #638
    TILLY
    Massachusetts
    Doesn't that defeat the purpose of having the PID'S? I would think that the settings should be based on what Toyota has determined to be the average/optimal readings that are normal.
  9. May 3, 2021 at 6:07 AM
    #639
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The PIDs simply allow you to read the output to pins in a calibrated digital format.
    The dashboard has to be set up by the user to display that digital output using the options, typically analog/digital, starting/ending scale value, background color, overlay colors, etc available.
    Some of the numbers reported here raise questions in my mind about the PID used. Compared to the coolant temp, they look suspect to me. Good idea for dashboards to also show the coolant temperature as a reality check.
  10. May 3, 2021 at 4:09 PM
    #640
    a522467
    Michelle
    Ohio
    Curious what looks “suspect” to you? The fact that they’re hotter than you expected? I learned from another post that A/T Oil Temperature 1 is the pan and A/T Oil Temperature 2 is the torque converter. I simply picked them from the drop down menu. Thought it was pretty hard to mess that up, but maybe I did (?). What am I missing? Thanks
  11. May 3, 2021 at 5:08 PM
    #641
    JohnLakeman
    My comments not directed at your data specifically, Michelle. I'm not sure if you've missed anything, but for some, maybe worth a double-check. In fact, not sure where I read it, but the temps I read looked low compared to coolant temp, but run-time may not have been considered. In a cooler installation setup, coolant temperature is going to be a very strong influence. It is not the final arbiter.
    On a very cool day, I would expect ATF temps to be below coolant temperature ONLY short-term. Once the engine coolant temp is stabilized on a long drive, I would expect ATF temperatures to be slightly above coolant temperature and variable within a set range according to load. That's just the way Toyota has set up the opening temperature on the transmission thermostat.
  12. May 3, 2021 at 5:27 PM
    #642
    Vizsla
    Vizsla 2 = 2.5
    Her temps are without a thermostat, does not have a cooler installed. So probably reading fine imo..
  13. May 5, 2021 at 6:43 PM
    #643
    SShooterZ
    SShooterZ New Member
    Hauling my 5,000 lbs boat in 70 degree weather. Never got above 195*.
  14. May 16, 2021 at 4:57 PM
    #644
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Need some quick help. Just did the level check but found a washer in the pan I drained into. The check level plug did slip out of my hand when trying to out it back in. Does the transmission check plug have a crush washer?
    If so, is there a correct side up?
  15. May 16, 2021 at 4:59 PM
    #645
    Dsptundra
    Austin TX Area
    This is the washer.
  16. May 16, 2021 at 5:47 PM
    #646
    co2owen
    co2owen New Member
    VA
    2020 Cement Limited CM TRD Off-Road
    Trans Cooler. 5100's up front at mid-setting. ESP Plastic Storage.
    It does have a crush washer. I found my crush washer in the bottom of my drain pan after the level check procedure was done. Put it back in. I lost maybe an ounce or two of fluid when I pulled the plug and put it back in. I then added fluid when cold and reperformed the level check. Come to find out, I probably didn’t lose enough to add and check level again. Slip that crush washer on quickly abc thread it and you’ll be like me and only lose an ounce or two.
    Dsptundra[QUOTED] likes this.
  17. May 16, 2021 at 5:49 PM
    #647
    co2owen
    co2owen New Member
    VA
    I just put it back in and it doesn’t leak. It also didn’t leak when it was in the drain pan.
  18. May 16, 2021 at 5:49 PM
    #648
    Dsptundra
    Austin TX Area
    Yes, went ahead an pulled the plug and put it back in. Probably an ounce or two lost but not enough that concerns me.
    co2owen[QUOTED] likes this.
  19. May 16, 2021 at 6:23 PM
    #649
    Genuine Cooling Systems [OP] New Member Vendor
    Glad you got to figured out. A couple ounces is nothing to worry about.
  20. May 17, 2021 at 8:58 AM
    #650
    Dsptundra
    Austin TX Area
    Just curious if others have found their transmission shifts better after adding the cooler?
    Ever since I purchased the truck, when cold, the transmission is slow to shift and generally lagging until the temp gets up (5 mins or so). This morning with similar ambient temps (55 degrees) the shifting was much smoother and consistent right way like when it was warm. Maybe is it purely in my head but curious if anyone else has experienced this.
  21. May 17, 2021 at 9:24 AM
    #651
    G10dra
    G10dra Not a New Member
    @a522467 Michelle, you make a very good point about the cooler, but I have a question with utmost respect what in god's green earth kinda bricks are you hauling from SE Ohio to all the way Oklahoma, that can't be found in Oklahoma. That is THE Question
    :monocle:
    Kung likes this.
  22. May 17, 2021 at 9:37 AM
    #652
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    No difference and has been smooth since new, don't notice any sluggishness in the winter that I recall.
  23. May 17, 2021 at 10:56 AM
    #653
    a522467
    Michelle
    Ohio
    Sounds crazy, but one of my many hobbies is brick collecting. When I’m not working on vehicles or building houses, I like to collect bricks.
    I attended a brick swap in Texas last year.
    To TX:
    From TX:
  24. May 17, 2021 at 11:21 AM
    #654
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    That's new to me. I'd be hauling bricks of 22LR :rolleyes:
    Fearthisbeard, Bammer and GODZILLA like this.
  25. May 17, 2021 at 11:54 AM
    #655
    G10dra
    I've heard of bicycle collecting, Matchbox toys, stamps, Watches, Jewellery, Gold Coins, Paintings, Silver, Antiques, Asian Art, Sports Memorabilia but I have never heard of a brick collecting hobby
    Please educate me
  26. May 17, 2021 at 12:29 PM
    #656
    bflooks
    bflooks New Member
    Metrowest MA
    What's this now? Who collects what?
    I also need to hear more. Do you display them? Is there a market and appraisal guide? Is everyone chasing the same ones, like a baseball card?
    Not poking, legit never heard of this.
  27. May 17, 2021 at 4:47 PM
    #657
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I'd say your rather ambitious, I do like what you've done. I can say that I've never saw a sidewalk like that before.
    Nice job!
    mech_engineer09 and a522467 like this.
  28. May 17, 2021 at 8:14 PM
    #658
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Now that's one of the coolest things I've seen in a long time!
    a522467[QUOTED] likes this.
  29. May 19, 2021 at 12:28 PM
    #659
    G10dra
    Thanks, @a522467 That's very interesting. I've been to India and have seen brick making for miles and this is why I love this forum it has a little bit of every aspect of life. :)
  30. May 20, 2021 at 10:04 AM
    #660
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Hmmm... am I in the wrong thread here?
    SShooterZ likes this.
