5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Jan 16, 2021 at 4:05 PM
    #361
    Genuine Cooling Systems [OP] New Member Vendor
    Little easier to get parts now.
    KC.Tundra likes this.
  2. Jan 17, 2021 at 11:25 AM
    #362
    JEHTUNDRA
    JEHTUNDRA New Member
    2021 Crewmax SR5 4x4
    Do you know if the horn relocation will interfere with the AJT TSS relocation bracket? Reason I ask is because I want to change my grill and install a trans cooler. Thanks!
  3. Jan 17, 2021 at 12:27 PM
    #363
    It will fit. You just wouldn't use the horn relocation bracket and I would have to provide you a shorter grounding cable.
    Wallygator likes this.
  4. Jan 17, 2021 at 7:32 PM
    #364
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Good to know, I’ve had a couple viewers ask me why they can’t buy complete kits...I’ll let them know, thanks man!
  5. Jan 17, 2021 at 8:04 PM
    #365
    Trust me I get the same questions. If your willing to edit your current video of the Hayden I will send you the MHX514 kit free of charge. It will be an upgrade to the Hayden.
    tundra_20 likes this.
  6. Jan 17, 2021 at 8:07 PM
    #366
    $1029 for the MHX kit. Setrab will be $929. Prices subject to change.
    Jmn and Saltyhero13 like this.
  7. Jan 17, 2021 at 8:09 PM
    #367
    2020Platinum
    Patrick
    Northeast PA
    Sending ya a pm
  8. Jan 18, 2021 at 8:50 AM
    #368
    Tundra4us
    Tundra4us New Member
    "D"
    Not yet, still deciding if I remove the "factory" rubber lines coming up off the hard lines and run the gates hose all the way to cooler OR if I leave "factory" rubber that are formed to make the 90° bend through the shroud and use 3/8 barbed or AN fittings to splice on the gates hose to connect to the cooler. My concern with running new line all the way is the 90° bend needed to come through the shroud ( possibly making it kink ) and the splice method makes 2 more connections per line for a potential leak....
    Am I over thinking this simple install? o_O
  9. Jan 18, 2021 at 8:59 AM
    #369
    What year is your truck?
  10. Jan 18, 2021 at 9:11 AM
    #370
    Tundra4us
    "D"
    2016 with tow package.
  11. Jan 18, 2021 at 10:54 AM
    #371
    PM me. The MHX-514 bracket only fits 2019+ Tundra's. Did you purchase a MHX kit from me?
  12. Jan 20, 2021 at 4:58 AM
    #372
    Setrab, Series 9, 15 row install photos. I am currently waiting on the back-ordered Setrab 45° fittings before I can ship the few kits I have.
  13. Jan 20, 2021 at 7:13 AM
    #373
    TXBrit
    TXBrit New Member
    Weatherford TX
    2019 MGM Platinum
  14. Jan 20, 2021 at 7:17 AM
    #374
    That's one thing the MHX and Setrab brackets have that most cooler brands, including the Hayden, don't offer.
    tundra_20 and KC.Tundra like this.
  15. Jan 20, 2021 at 7:37 AM
    #375
    TXBrit
    TXBrit New Member
    Weatherford TX
    2019 MGM Platinum
    The only down side to those mounts was that the blind hole is quite shallow only 8mm so I used a drop of 222 Loctite on the screws and M6 nyloc nuts on the studs. Studs to bracket M6 x 10 Socket screws holding cooler
  16. Jan 20, 2021 at 10:12 AM
    #376
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Did you happen to take any pics of your install? I've been thinking of some way to use isolators on the b&m cooler I installed. Thanks.
  17. Jan 20, 2021 at 6:30 PM
    #377
    Anyone out there with a 2011-2018 mind taking a few measurements and testing a horn location? I am trying to dial in the bracket for the 2011-2018 Tundra's however, I am afraid the bracket I have now will be too close to the Toyota hoses going to the condenser. My plan is to shift the bracket as far right as possible to alleviate this. I will need a measurement from the center bolt on the horn to the center cross member (line in red). I also am thinking of placing the horn on the center cross member as well. There is a hole (circled green) that may work but I am unsure if there will be enough slack for the horn cable.
    Thanks everyone!
  18. Jan 21, 2021 at 2:44 AM
    TXBrit
    TXBrit New Member
    Weatherford TX
    2019 MGM Platinum
    No I neglected to take pictures. Sorry
  19. Jan 21, 2021 at 4:24 PM
    #379
    JEHTUNDRA
    I'm ready to order a complete kit.
  20. Jan 21, 2021 at 5:18 PM
    #380
    Complete kits will be available for pre-order this weekend at genuinecoolingsystems.com and will ship on or around 7-10 February. I will only have 10 complete kits available.
    Wallygator and KC.Tundra like this.
  21. Jan 23, 2021 at 10:20 AM
    #381
    betotundra
    betotundra Toyota for Life
    I've read each post of the whole thread since it was created, but I don't remember the reasons why the Hayden Kit was discontinued, anybody mind to share why please? TIA
    sask3m likes this.
  22. Jan 24, 2021 at 8:35 AM
    #382
    JEHTUNDRA
    I’m not seeing the complete kit in the website. Got a link?
  23. Jan 24, 2021 at 8:55 AM
    #383
    Pre-orders will be available this afternoon for the MHX and Setrab complete kits (only 10 available). I'll post a link once they are available on the website.
  24. Jan 24, 2021 at 9:42 AM
    #384
    Wallygator and Jmn like this.
  25. Jan 24, 2021 at 9:59 AM
    #385
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Could someone tell me the distance between the condensor and the cooler bracket, I'd look but to lazy to pull my truck apart.
  26. Jan 24, 2021 at 10:21 AM
    #386
    JEHTUNDRA
    Which is a better cooler that will last longer, or just better built, the MHX or Setrab?
  27. Jan 24, 2021 at 11:08 AM
    #387
    I'd say the MHX is a better quality and higher cooling capability. It is a fully welded design and is backed by a lifetime warranty. Setrab is used all over the world for racing and it a great product as well. You can't go wrong with either.
    JDM FTW and atomheart like this.
  28. Jan 24, 2021 at 11:09 AM
    #388
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Were the haydens having issues?
  29. Jan 24, 2021 at 11:16 AM
    #389
    No issues with the quality but by no means is it the same quality as the mhx or Setrab. I stopped offering their coolers because it is almost impossible to get ahold of their customer service. I am an approved dealer for Setrab and Improced Racing so parts are much easier to get and you can go through me for warranty work (if you ever need it).
    sask3m likes this.
  30. Jan 24, 2021 at 12:29 PM
    #390
    JEHTUNDRA
    Thanks. I just ordered a complete MHX kit. Don’t worry about a smaller ground cable like you mentioned earlier. I think I’m going with the 2020 pro grill or keeping my current one.
    Tundra4us likes this.
