5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Jan 3, 2021 at 6:57 AM
    #331
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Pin in allows the fluid to circulate through the cooler to obtain the correct level during the check. Pull the pin when your done allows the thermostat to work as intended.
    Wallygator and rebmo like this.
  2. Jan 3, 2021 at 7:00 AM
    #332
    Genuine Cooling Systems [OP] New Member Vendor
    My instructions specifically state to have the pin in during the level check and to check for leaks. You only remove it after you are complete with the install.
  3. Jan 3, 2021 at 9:50 AM
    #333
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    yep.
    Cool. I never saw any instructions with my kit. I guess I was supposed to refer to the website? Whoops
  4. Jan 3, 2021 at 10:25 AM
    #334
    Correct. The .pdf instructions as well as the video instructions are located there.
  5. Jan 3, 2021 at 5:53 PM
    #335
    Setrab CAD file almost complete. Attached is a picture of the MHX 514 and the Setrab Series-9 15 row next to each other.
    Wallygator, KC.Tundra and JRock like this.
  6. Jan 3, 2021 at 6:10 PM
    #336
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Pardon my ignorance, but whats the difference between these and the Hayden cooler?
  7. Jan 3, 2021 at 6:19 PM
    #337
    Setrab will fit 2011-2021 Tundra's and work in conjunction with the factory transmission cooling system for the 2011-2018.
    MHX will fit 2019+ only, bigger unit, more cooling capacity, better quality over the Hayden.
    ShawnTRD, tundra_20 and KC.Tundra like this.
  8. Jan 3, 2021 at 6:21 PM
    #338
    FISHN43
    FISHN43 New Member
    Ohio
    Thanks!
  9. Jan 5, 2021 at 1:27 PM
    #339
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Have all the Toyota parts....
  10. Jan 7, 2021 at 4:05 AM
    #340
    MHX-514 kit.
    AN fittings are included that will run behind the cooler to connect the hoses. No hose clamps required.
    Jmn, Wallygator, KC.Tundra and 5 others like this.
  11. Jan 7, 2021 at 10:22 PM
    #341
    G10dra
    G10dra Not a New Member
    Do you think you can mount the cooler flipped with connectors facing the left side?
  12. Jan 8, 2021 at 3:44 AM
    #342
    I didn't add notches on the other side. If you drill holes in your wind deflector and run the hoses to that side the hoses would kink because they would need to bend at a 90° sharp angle to reach the ports on the cooler. With that said, if you have the Stillen intake with their wind deflector, the hoses would not kink on the other side but 99% of people don't have a Stillen intake so I left out the notches to add additional strength in the bracket.
    KC.Tundra likes this.
  13. Jan 8, 2021 at 4:22 AM
    #343
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Do you have some shots with the grill on?
  14. Jan 8, 2021 at 4:29 AM
    #344
    I don't unfortunately as I have my full front end of my truck taken apart however, it will fit center directly behind the grill opening for maximum airflow just like the Hayden did.
  15. Jan 8, 2021 at 4:31 AM
    #345
    Are you installing this newer cooler or the Hayden from the original kit?
  16. Jan 8, 2021 at 4:33 AM
    #346
    Here is an example where the MHX will be placed behind the grill. This is a Hayden cooler but it is in the same location as the MHX.
    Wallygator likes this.
  17. Jan 8, 2021 at 4:35 AM
    #347
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Would this cooler setup allow for the use of pre 2018 grill?
  18. Jan 8, 2021 at 4:40 AM
    #348
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    I keep toggling between the MHX 514 and the Setrab Series-9...I think I like the Setrab more due to the compactness.
  19. Jan 8, 2021 at 4:46 AM
    #349
    Yes, that was a limitation for the Hayden bracket but the mhx and setrab brackets will fit the earlier model grills now.
  20. Jan 8, 2021 at 4:48 AM
    #350
    Gotcha. Was just curious. @2020Platinum has an excellent installation video of the original Hayden kit on his channel. Put the inlet and outlet hoses on the thermostat before you install it. The hoses do go on a certain way as well. I also figured out that when installing the hard lines above the cross member, rotate them on a 360 degree roll as you go and they will go right in. You learn trick like this working on jet engines. :thumbsup:
  21. Jan 8, 2021 at 4:49 AM
    #351
    I would have to measure the total surface area for each design but the MHX and Setrab will be very similar in "compactness".
  22. Jan 8, 2021 at 4:56 AM
    #352
    Forgot to mention....the VeePeak Bluetooth adapter is what most of us use for the temp monitoring. Some guys bought different ones and they didn't work that well. Even the Hayden cooler is nice. I just pulled a 4000 lb camper, gear for 4, 4 people, and 2 full coolers. Outside temp was 65 and my average temp was 191. :thumbsup:
  23. Jan 8, 2021 at 5:30 AM
    #353
    Bradleybb
    Bradleybb New Member
    Georgia
    2021 CM TRD OR
    Transmission cooler TRD REAR SWAY RCI front skid
    This average temp of 191 pulling your camper, therm pin or unpinned ?
    Thanks
  24. Jan 8, 2021 at 5:48 AM
    #354
    Unpinned. The pin is removed after the install and fluid servicing. @chasenicholas93 can confirm this.
    2020Platinum likes this.
  25. Jan 8, 2021 at 6:26 AM
    #355
    Correct, I recommend you remove the pin after install is complete. You can always pin your thermostat if you'd want constant flow to the cooler but I'd only do that if your towing.
  26. Jan 9, 2021 at 6:58 AM
    #356
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Thanks George, much appreciated!...if I can help anyone out feel free to shoot me a message!
  27. Jan 16, 2021 at 6:47 AM
    #357
    Has anyone installed their MHX-514 cooler kit yet?
  28. Jan 16, 2021 at 3:15 PM
    #358
    Complete kits for the MHX and Setrab coolers will be available in February. The kits will include all the parts needed (including Toyota parts) to complete the install.
    Jmn, 2020Platinum, FISHN43 and 2 others like this.
  29. Jan 16, 2021 at 3:39 PM
    #359
    Fearthisbeard
    Fearthisbeard New Member
    Gilbert AZ
    2019 - 1794 TRD Offroad
    :spending::spending:
  30. Jan 16, 2021 at 3:58 PM
    #360
    JEHTUNDRA
    JEHTUNDRA New Member
    2021 Crewmax SR5 4x4
    Nice!
    Why did you start offering full kits again?
