5.7l engine air filter?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tacogrande, Mar 24, 2018.
  1. Mar 26, 2018 at 6:43 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    how is that working for you?
  2. Mar 26, 2018 at 6:52 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 Trd Sport
    is there a part # for the air flow accelerator?
  3. Mar 26, 2018 at 7:00 PM
    15whtrd
    15whtrd Mr. Blonde
  4. Mar 26, 2018 at 7:04 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 Trd Sport
  5. Mar 26, 2018 at 7:04 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
  6. Mar 26, 2018 at 7:06 PM
    15whtrd
    15whtrd Mr. Blonde
    I think it should fit.
    Calling @Roman
    Roman likes this.
  7. Mar 26, 2018 at 7:10 PM
    Boxer13
    Boxer13 New Member
    2016 Crewmax Trd
    3/1 lift with add leaf pack 275/70/18 BFG kO2 K & N filter Rock sliders Hawk brake pads Hula girl on dash
    Been using K&N filters for years....no complaints here
  8. Mar 26, 2018 at 7:10 PM
    Rngr188
    Chad
    Harrison AR
    Pretty sure there's no difference between 2017 and 2018 intake system.
    15whtrd and hi_rawb like this.
  9. Mar 26, 2018 at 7:14 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 Trd Sport
    kool thanks guys! im about to purchase the , trd air filter and the air flow accelerator..is that all ineed for this mod?
  10. Mar 26, 2018 at 7:20 PM
    Rngr188
    Chad
    Harrison AR
    That is all I did, can' say I gained anything but certainly didn't loose anything. People spend $300+ on a CAI and will tell you it's a waste so why not spend $13 on an AFA and a good filter. Besides the AFA is the first piece in a CAI system so for $13 why not. An engine is an air pump so if you can get better air in go for it.
    15whtrd and hi_rawb[QUOTED] like this.
  11. Mar 26, 2018 at 7:22 PM
    l3LUEFALCON
    l3LUEFALCON RIG MECHANIC
    Josh
    North Houston Area
    2014 5.7 FFV MGM CM SR5 4WD TSS-OR AKA: MILDRED
    (DIY) CB Radio, Tool Box, ESP Under seat storage, Husky front/ Weather tech rear floor mats, (DIY) Console Safe (Bio-metric), 275/60/R20 Conti Terrain Contact, Magnaflow Exhaust, Katskin leather seat covers, LRA 46 gallon replacement fuel tank, TRD Pro shocks Front/Rear.
  12. Mar 26, 2018 at 7:25 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 Trd Sport
    Black Wolf likes this.
  13. Mar 27, 2018 at 3:50 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I agree with you that larger pleats/larger filter is better. I never visually compared the OEM filter to a Wix, what I do know is that the Wix filter I put in my last F-150 appeared to be far superior to the OEM version (it had way deeper pleats and a better gasket).
    15whtrd[QUOTED] likes this.
  14. Mar 27, 2018 at 4:07 AM
    I've never had issues with MAFS getting gummed up. Oil gets sucked through if there is TOO MUCH applied. A thin coat only. THIN.. If property applied the oil can't get sucked through the filter membrane. If over applied the oil saturates the filter membrane and can cause MAFS to get fouled. As a general rule I check my MAFS once a year depending on my driving no matter what filter type I may have. Only takes a few minutes to clean up a MAFS. Even excessive dust can foul a MAFS. There are good reasons why many filter manufacturers offer both wet and dry filters. K&N is one of the first to come out with wet. For Decades...I think what gets lost on some folks is the difference between wet and dry. There is no law that says you have to use oil on the K&N for example. A perfectly fine reusable filter as is. The oil...properly applied...acts like a spider web across the filter membrane collecting smaller dust particles that dry filters pass through. It's all about preference.
    NewImprovedRon and 15whtrd like this.
  15. Mar 27, 2018 at 7:40 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    It fits. :)
  16. Mar 27, 2018 at 8:18 AM
    15whtrd
    15whtrd Mr. Blonde
    @hi_rawb
    hi_rawb and Black Wolf like this.
  17. Mar 27, 2018 at 8:35 AM
    Tundra11Racing
    Tundra11Racing New Member
    Justin
    VA
    2017 Black Tundra SR5 TRD OffRoad
    Katzkin Leather Seats TRD Pro Grille TRD Pro Wheel Caps Color Matched Front End Caps Extang Encore Tonneau Cover
    In my 2009 I had the K&N and it definitely whistled which was a little annoying. But otherwise a very good product. What are problems have people had with the K&N? Thinking about getting one on my 2017.
  18. Mar 27, 2018 at 8:42 AM
    Are you talking about the CAI kit or drop in? The whistling sound can occur in aftermarket CAIs. Usually the new intake tube is redesigned to minimize the whistling. Any extraneous air getting in can cause it too.
    15whtrd likes this.
  19. Mar 27, 2018 at 8:54 AM
    #49
    15whtrd
    15whtrd Mr. Blonde
    I think the mods need to somehow make it if you put CAI, or air filter, into a thread title, it automatically reroutes them to all of these threads before they can post it LOL.
    I will say when I’ve ran K&N air filters it was my own fault for the maf failing. Never had a problem until then. And it may not even of been that, other than I tried to clean it when I cleaned the air filter so it could’ve been the MAF cleaner I used.
    After that I switched to aerosol oil. I was always looking to get it as red as possible without being too much. The trick is to add a small amount, let it soak in before looking for any white spots. If you oil it and immediately install it you have more of a possibility of issues. Definitely let them sit and coagulate. The oil gets stickier as it sits.
  20. Mar 27, 2018 at 9:06 AM
    #50
  21. Mar 27, 2018 at 5:00 PM
    #51
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    If you change out your cabin filter. Reach down in the fan and check for debris. Mine had dog food and leaves in it. Peace. D
  22. Apr 5, 2018 at 1:38 PM
    #52
    Sandbox
    Sandbox New Member
    Canada
    2017 White TRD Pro Crewmax
    What AFE air filter are you guys using?? the Pro 5R, regular or the higher density more restrictive one?
  23. Apr 5, 2018 at 1:44 PM
    #53
    15whtrd
    15whtrd Mr. Blonde
    There’s only two types that I’m aware of. The oiled version and the dry pro S. I’m using the dry pro. Quite a few are using the oiled version or the similar k&n or TRD filter. In my opinion they all filter about the same some with a little more efficiency. From the Afe website it states that the dry filters better. Imo if you’re looking for good filter efficiency check out s&b or stick with stock.
  24. Apr 24, 2018 at 5:19 AM
    #54
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    Does anyone have a picture of how the air accelerator mounts? IMO it doesn't fit in my 18 correctly. There is a lip after the inlet that seals to the fender, but then you can't install the air box in the correct location because it is too long. You have to push that lip thru the fender and the inlet is supported. IDK if it is a big deal or if you loss any benefit by it not mounting correctly?
  25. Apr 24, 2018 at 5:26 AM
    #55
    15whtrd
    15whtrd Mr. Blonde
    You need to shove that lip inside the fender hole. I installed my accelerator into the fender without the box in place you have to fold it to get it in there. Then snap it on to the box as you place it.
    hi_rawb and Skippy like this.
  26. Apr 24, 2018 at 6:14 AM
    #56
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 Trd Sport
    yeah i put my accelerator on first ..then snap the box on. that should fix the problem
    15whtrd likes this.
  27. Apr 24, 2018 at 6:42 AM
    #57
    SnrDisregardo
    Wade
    IL
    I did that, but I’m talking about you have the “trumpet” that goes into the fender, then there is a lip that would seal it to the hole. I have it installed but for it to sit in the correct position, it would have to be like 1/2” shorter. It’s hard to explain without having the accelerator out.
  28. Apr 24, 2018 at 6:43 AM
    #58
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Skippy and 15whtrd like this.
  29. Apr 24, 2018 at 7:12 AM
    #59
    15whtrd
    15whtrd Mr. Blonde
    If you’re hoping that the trumpet pulls back into place in seals from the inside of that fender hole, you would be wrong LOL. There is a small gap around the hole and it just kind of is what it is. Sorry to use that phrase. That is the way that it mounts. As long as you stuffed the trumpet through the hole, then it’s snapped correctly onto the box and the box is in its home, it is mounted correctly.
    SnrDisregardo[QUOTED] likes this.
  30. Apr 24, 2018 at 7:36 AM
    #60
    SnrDisregardo
    Wade
    IL
    Ok. Thanks. I figured as much, but it snapped so nicely into the hole that it threw me off.
