5.7 w/240k...to drain & refill trans fluid or drop pan and change filter and 1/3 fluid ??
Discussion in '2nd Gen Tundras (2007-2013)' started by 10 Bears, Dec 2, 2024.
  1. Dec 5, 2024 at 7:58 PM
    10 Bears
    10 Bears [OP] New Member
    11 CREW 5.7
    None at the moment
    Walmart has Valvoline WS spec 4qt container for 21.99$ been using it a year, shifts fine.
    It probably isn't as good as as the OEM fluid but that's ok by me.
    07 Tundie likes this.
  2. Dec 6, 2024 at 1:43 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    OEM for me...taking good care of it. No public transit in Tejas!
  3. Dec 6, 2024 at 3:54 PM
    texmln
    texmln New Member
    You can buy a 5 quart jug of real live WS fluid made by Idemitsu on Amazon for about $11/qt. Idemitsu is a legit, large Japanese oil company that is an OEM supplier to all the Japanese brands and I used their WS in my 2008 Tundra with no issues.
  4. Dec 6, 2024 at 4:58 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Order from an online dealer like Fred Anderson which is I'm sure what @texasrho83 was referring to.
    Fred Anderson has their sale going on right now for 1 more day so better act fast.
    https://autoparts.fredandersontoyot...standard-automatic-transmission-fl-00289atfws
    texasrho83 and jtwags like this.
  5. Dec 6, 2024 at 6:20 PM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    I have been utilizing the “full send” method on numerous high mileage Toyotas and it seems to work well. Not having to drain and fill numerous times to play catchup is nice too. No way would I drop the pan though.
  6. Dec 7, 2024 at 4:09 AM
    tmac58star
    What's "full send?"
  7. Dec 7, 2024 at 5:11 AM
    kbahus
    kbahus New Member
    MI
    Full fluid exchange, not just a drain and fill.
  8. Dec 7, 2024 at 8:15 AM
    tmac58star
    DIY or at a shop? Considered a fluid exchange all at once using the trans cooler lines, but simple D&F is easier for me given my circumstances. Home fluid exchange worked really well on my little 92 Ranger XLT a decade or two ago.
  9. Dec 7, 2024 at 1:02 PM
    kbahus
    kbahus New Member
    MI
    I use the tranny cooler lines and Aisin WS fluid.
    10 Bears[OP] likes this.
  10. Dec 7, 2024 at 3:26 PM
    tmac58star
    Where are the lines on your '15? 5.7L engine?
  11. Dec 7, 2024 at 6:05 PM
    kbahus
    kbahus New Member
    MI
    The 15' has them in front of the radiator on the passenger side, my 2nd gen 2008 has the tow package with the big trans cooler in the same spot.
  12. Dec 7, 2024 at 8:34 PM
    10 Bears
    11 CREW 5.7
    None at the moment
    How many miles on the truck.
  13. Dec 8, 2024 at 3:58 AM
    kbahus
    kbahus New Member
    MI
    I will use my Sequoia as the example, purchased truck with around 185k on it. I did the full exchange sometime ago, probably around 250k, it now has 335k on it. I had no prior record of having a transmission service. My 2015 had 195k on it when I did the service but it only has another 15k on it, again no prior record of a service.
    10 Bears[OP] and 07 Tundie like this.
  14. Dec 8, 2024 at 4:15 AM
    tmac58star
    That method works well...wish my cooler lines were up front, mine are behind the radiator.
  15. Dec 9, 2024 at 6:08 AM
    minter66
    minter66 2007 TSS CrewMax
    I did a full fluid swap using the transmission lines, but I accessed mine under the truck, passenger side - next to transmission itself. I pumped out all fluid until it was a nice clear red. I then immediately towed my 30 foot travel trailer to Colorado and back (2 mountain passes) with zero issues.
  16. Dec 9, 2024 at 11:27 AM
    tmac58star
    What year/model & engine/tranny combo? I have hard lines from the tranny almost all the way to the tranny cooler.
  17. Dec 10, 2024 at 9:02 PM
    10 Bears
    11 CREW 5.7
    None at the moment
    This is encouraging.
