5.7 V8 3UR-FE repair manuals
Discussion in '2nd Gen Tundras (2007-2013)' started by Ricos, Oct 30, 2021.
  1. Oct 30, 2021 at 1:29 AM
    Ricos
    Ricos [OP] New Member
    Ricardo
    2010 Tundra SR5 White Widow
    Never stopping ...
    Hi all,
    Sadly enough I will have to remove my cilinder heads and get them rebuild, because of a worn valve wich sticks a little bit open and causing misfires wich result in a shaking engine and shaking ride.
    I have been searching the forums and web but not able to find a proper repair workshop manual about the cilinders heads, like torques for the headbolts and camshafts,timing chain adjustment etc.
    Best thing would be a complete manual from start to finish, but as long as I can get the most important information I should be able to get it done.
    Does somebody have the TIS files or links where to find the pdfs ?
  2. Oct 30, 2021 at 6:27 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  3. Oct 30, 2021 at 7:57 AM
    Ricos
    Ricardo
    Never stopping ...
    Thanks for the tip,just ordered it, hope it covers my upcoming repair.
    No I’ve never used it done all the repairs without a manual …
  4. Oct 30, 2021 at 8:14 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Its not TIS but its close eManuals has a 12,000 page PDF for $20. I recommend if you use it, to use Adobe pdf viewer otherwise you won't have search or select sections. (Adobe pdf viewer is free)
    Ricos[OP] and NewImprovedRon like this.
