5.7 oil capacity!?
Discussion in '2.5 Gen Tundras (2014-2021)' started by DMB4x4, Mar 14, 2019.
  1. Mar 15, 2019 at 11:46 AM
    15whtrd
    15whtrd Mr. Blonde
    The OP has a 14 so your manual is most likely different than his.
  2. Mar 15, 2019 at 11:52 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    True, but it is the same engine.
  3. Mar 15, 2019 at 11:55 AM
    sundance
    sundance New Member
    They do change them slightly from year to year. Maybe not in this regard but they do change the ECM, program and components. Which is one of the reasons you can't get a SC with the 18 and 19 yet.
    Ronin73[QUOTED] likes this.
  4. Mar 15, 2019 at 12:10 PM
    15whtrd
    15whtrd Mr. Blonde
    I put in exactly 8 it’s at the full mark. I’m just going to stick with that.
    BigdaddyII and (deleted member) like this.
  5. Mar 15, 2019 at 12:20 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Mlm
    The manual changed over the years, my '14 had 7.9 and my '18 has 8.5 both 5.7.
    15whtrd[QUOTED] likes this.
  6. Mar 18, 2019 at 7:57 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    You definitely don't want to over fill your engine with oil. It's always best to put in the amount the owner's manual says, then drive it around for a few days, then check the oil again and see what the dipstick says. If you need to top it off, then ok, but that shouldn't be more that half a court I'd think, at most.
    Watt maker likes this.
  7. Mar 18, 2019 at 8:02 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    I changed my oil and filter not to long ago on 19' 5.7 and it took every bit of 8.5 quarts to get to full and that is what manual states also.
    TWJLee and Watt maker like this.
  8. Mar 18, 2019 at 9:58 PM
    DMB4x4
    DMB4x4 [OP] New Member
    2014 Tundra SR5 CM 4x4
    OK so little update and I believe I found what was going on. I have driven a lot since that oil change ( supposedly 9.5 quarts) and have been checking oil religiously on that time. After I got that oil change I went home and park my truck, when I came back out (few hours later) I looked under the truck and boy was I pissed. There was oil all over my drive way, skid plate, literally blasted from engine to rear diff. The techs who changed my oil spilled AT LEAST half a quart refilling the engine. I belive the truck is at 8.5 quarts, but had to charge me the extra quart on paper to not have a loss on there oil change!? So far almost 1k miles down no more leaks after I wiped the undercarriage clean and dip stick/ oil pressure is reading within specs/normal
  9. Mar 18, 2019 at 10:43 PM
    Twinky
    07 double cab work horse
    And they charged you for the extra oil....
    Ah man, thats just sad.
    Good to hear you got it figured out at least.
  10. Mar 18, 2019 at 10:45 PM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    did close to 8.5 in mine and just use the recommended Toyota oil
  11. Aug 7, 2019 at 4:37 PM
    cornwall325
    cornwall325 Work in Progress
    2018 Tundra TRD Offroad Limited Crewmax
    Are you guys that are putting in 8 showing it coming in just a tad above the full dot? Just a teeny bit above full dot is what mine is showing. I haven’t driven it down the road just warmed it up in the driveway since I’ve changed it if that makes any difference. Gonna have the wife drive it to work tomorrow and see what it levels out at.
    I put 8 in mine and that’s how mine is showing.
  12. Aug 23, 2019 at 4:38 PM
    cornwall325
    Also I’m just curious of the reasoning to check oil after it’s at the operating temperature rather than cold? I guess the checking it cold is an old school thing.
    15whtrd likes this.
  13. Aug 23, 2019 at 8:09 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah it seems silly to me too. You would think after sitting overnight it would be the most accurate. I can only assume that the oil may expand a bit when it comes to temperature as well as being distributed through the oiling system. Like filling up the oil canister etc. But it still doesn’t make sense to me because you would think that would be inconsistent.
  14. Aug 24, 2019 at 7:05 AM
    cornwall325
    Can any of you who have had the 5K service done tell me what it says in the description on your paperwork or in the Toyota owners app? Just had the rotation done and the wording is kinda misleading. I specified for them not to change the oil since I had done that myself.
  15. Aug 24, 2019 at 9:59 AM
    Cheesy1
    Cheesy1 New Member
    2020 CrewMax TSS
    A half quart more or less isn’t going to make a bit of difference.
    I only put in 7.9345 qts. The remaining I use for lubrication on my guns....
    panicman likes this.
  16. Aug 24, 2019 at 10:05 AM
    15whtrd
    15whtrd Mr. Blonde
    Hahahahaha nice
  17. Aug 24, 2019 at 10:33 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    2020?!
    You shouldn’t need to change your oil until... The Future.
    Sumo91 and hagrid like this.
  18. Aug 24, 2019 at 10:40 AM
    Cheesy1
    Cheesy1 New Member
    2020 CrewMax TSS
    New to this forum. Really need a sarcasm button. :)
    500 miles on it. Oil change time will be....a long time from now.
  19. Aug 24, 2019 at 10:45 AM
    #49
    panicman
    Eric
    I was onto your jest...
    I think you’re the first 2020 poster that I’ve seen/responded to, so I had to play with the fact you posses a future model year in 2019.
  20. Aug 24, 2019 at 11:03 AM
    #50
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    I do 8 with filter and it's right in the middle of the dots on the dipstick
    Coloradonative75 likes this.
  21. Aug 24, 2019 at 12:25 PM
    #51
    Nm6300'asl
    2022 DC SR5 4x4
    Pic is from the '18 owners manual. I am sure the owners manual from my old '14 was 7.9.
  22. Aug 7, 2020 at 7:55 AM
    #52
    duerrs
    duerrs Semper Fi!
    2008 Tundra TRD Off Road & 2020 Tundra TRD Pro
    Thought I'd add to this. I have a 2020 and 8 quarts with filter change puts it right at the top mark on the stick. Really confused by what the manual recommends (8.5 quarts) and all the owners that have varying amounts...7.5, 8, 8.5?? I'm going by the stick level. Could these cam seal leaks be caused by overfilling?
  23. Aug 7, 2020 at 7:57 PM
    #53
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    Are you running the engine immediately after the oil change, then checking the dipstick again, or are you changing the oil and filter, putting 8 qts in and looking at the dipstick? Perhaps if you run the engine for a little while, immediately after the putting in the 8 quarts and new filter, the dipstick will show that the oil is a little low?
  24. Aug 9, 2020 at 6:43 AM
    #54
    duerrs
    duerrs Semper Fi!
    Of course I’m running the truck after changing the oil and filter before checking. In fact, I currently have 7600 miles since the last oil change (8 quarts of Amsoil) and the level is maybe 1/16” off the full mark. I also use the TRD Performance Oil filter’s, but doubt that would make a difference.
    For me, it will be 8 quarts every time as I will go by the stick, not the manual.
  25. Aug 9, 2020 at 1:07 PM
    #55
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    Not trying to stir the pot ( okay, maybe a little ). But couldn't the way the oil is changed affect how much you put back in. When I do mine at home I pull up on a set of ramp, so the fumoto valve is lower so more oil has a change to be drained. I also start draining and let it go until NOTHING more comes out. ( usually about a beer ). At a jiffy lube type place, you pull in over a pit so vehicle is level and I am sure they drain till most is out and then button it back up. They don't have time to get every last oz of oil out. As long as it is filled back up to the full line, does it matter exactly how much is put back.
  26. Aug 9, 2020 at 2:05 PM
    #56
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Oil cooler maybe?
  27. Aug 9, 2020 at 4:05 PM
    #57
    15whtrd
    15whtrd Mr. Blonde
    I’m not aware that Toyota added anything like that.
  28. Mar 12, 2021 at 5:57 AM
    #58
    Marco
    Marco New Member
  29. Jun 1, 2023 at 7:51 PM
    #59
    81FUBAR
    81FUBAR New Member
    2017 Tundra CrewMax SR5 TRD 4x4 5.7 Magnetic Grey.
    Weather Tech floor mats. Modified Browning Shifter Knob. LED interior lights. Kings Camo Seat Covers Leer Topper Fuel Vapor Wheels 18 x9 +20 Bilstein Shocks top setting 6112 up front,5160 rear 295 18 70 Falken WildPeak AT3W Tires. Rough Country side Steps. Soon to install a BAmuffler 8” system.
    I have a 2017 Tundra 5.7 BA model. In changing the Oil and Filter I went with 8.5 quarts. Tip: In drainage mode towards the end, I Run “compressor air” though the Oil stick tube, real easy like. This pushes every last drop of dirty oil out fast and controlled.
    Let the games begin!
  30. Jul 30, 2023 at 7:37 AM
    #60
    skniper
    skniper New Member
    My '16 manual says 7.9 qts w/ oil filter change, did not know the later manuals specify 8.5 quarts, hmmm.
    I dump a 5 qt jug and 3 smaller quarts in it without looking. It reads about a half quart low between the dots on the dipstick, hmmm. Which has always irritated me, lol.
    I'll try 8.5 from now on...which is convenient because I'm about to change the 4Runner oil that requires 6.6 quarts, I have somewhere to dump that extra half quart now! :thumbsup:
