5.29 Diff Gears - Gauging Interest for Revolution Gear & Axle
Discussion in 'Performance and Tuning' started by the_midwesterner, Sep 24, 2018.
Would you be interested in purchasing 5.29 ration Diff gears if they were made available?
  1. Yes
  2. No
  3. Maybe
Results are only viewable after voting.
  1. Oct 12, 2018 at 11:59 AM
    the_midwesterner
    the_midwesterner [OP] New Member
    Luis
    None, yet....
    5.29s om 35s May be a bit steep. Won’t hurt anything but your gas mileage. It will keep the revs up higher, which depending on the weight of your trailer, may not be a completely terrible idea.
  2. Oct 12, 2018 at 3:02 PM
    xtrmoverland
    xtrmoverland New Member
    2016 Tundra 1794 TRD Off Road
    3.5 Lift 35' Tires
    i estimate that the trailer will weigh fully loaded around 1,100 lbs...is that overkill? i am considering the other use for the truck for sure so 4.88 is totally not out of the equation when the 5.29 become available...
  3. Oct 12, 2018 at 6:02 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Ok for us that don't know what would this gear ratio do for me. If someone already answered this my apologies.
  4. Oct 12, 2018 at 6:15 PM
    xtrmoverland
    3.5 Lift 35' Tires
    i think i am in similar situation as you are where i might wait until somebody do it first before i actually put this on to my truck, 'cause i have no idea what this will do to how i use the truck for...i wanted to do overlanding and a little bit of borderline rock crawling just because i leave close to big bear California, which has a lot of good trails to go to on weekend trips, but my passion really is for overlanding expeditions that take on trails for several days...i have a feeling 4.88 with rear lockers will be enough for what i plan to do, but the possibility of putting on 37s even 40s in the future is at the back of my mind...hard to decide until i see application of 5.29
  5. Oct 12, 2018 at 6:18 PM
    4:88's would be nice and 5:29 even better if and when I'm ready to make that leap it will be USA made Nitro's from "Just Diffs". Revolutions do have a nice point compared to Nitro"s.
  6. Oct 12, 2018 at 7:00 PM
    xtrmoverland
    3.5 Lift 35' Tires
    i am all for USA made, hopefully the 3/31/2019 is for real...
    Black Wolf likes this.
  7. Oct 12, 2018 at 7:10 PM
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
  8. Oct 13, 2018 at 4:16 PM
    Part_time
    Oregon
    No one answered my question, why would I do this? I have heard for better gas mileage. But what else
  9. Oct 14, 2018 at 12:00 AM
    ZPMAN
    Minnesota
    I will be installing my 4.88s and auburn LSD in week, the biggest benefit will be the shifting with the 35" tires. 20180924_202104.jpg
    Rica25, 15Yota and Jsena like this.
  10. Oct 14, 2018 at 12:22 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    :popcorn:
    Rica25 likes this.
  11. Oct 14, 2018 at 4:45 PM
    the_midwesterner
    Luis
    None, yet....
    The power train working harder is the issue. It causes more heat, wear, strain, etc, all of which correlates to a decrease in efficiency. Think of diff gears as a 10 spd bicycle. If you pick a specific combination, you may pedal super easy and fast but not get much movement. Conversely, you could pick gears that will give you much movement, but will be REALLY hard to pedal or get started. It’s about finding the sweet spot and generally that’s what the oem shipped the truck with. Sometimes, depending on vehicle application or use, you want to over gear or under gear. For our trucks, 4.88s puts you at near the factory ratio. Meaning the power train would work similarly to as if you hadn’t added the 35s. 5.29s would be too steep for 35s, but are better for 37” tires. With 40s, you want something more.
    To sum it up, changing your diff gears helps utilize mechanical advantage of gear ratios to reduce the overall power output required to be put forth by the truck, meaning you will gain fuel efficiency. The net gain will vary significantly, based on a whole bunch of factors, but efficiency will be had nonetheless. Assuming the driving condition is the same before and after the heat change.
    LifeCycle, Quebec and 4x4_Angel like this.
  12. Oct 14, 2018 at 6:48 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    So I have 34x11x20's with heavy wheels, a topper, truck bed system, aftermarket bumper, etc. etc. I tow mostly for work (40k miles easily a year) with a 5,000k trailer. Would my mileage go up with new gears? any rough idea of what kind of increase I might see?
  13. Oct 15, 2018 at 10:43 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  14. Oct 15, 2018 at 11:28 AM
    ZPMAN
    Minnesota
  15. Oct 15, 2018 at 11:44 AM
    the_midwesterner
    Luis
    None, yet....
    Yes, your mileage will increase. By how much? That’s impossible for me to calculate. It depends on driving pattern, environmental condition, etc, etc. I can tell you for a fact that you will see an increase, simply from the mechanical advantage of your gears, but if you’re driving 40k a year, you would easily make your money back in fuel savings for the cost of regearing plus some. Some guys claim almost stock mileage with 35s and 4.88s, which may be a 40% increase. Even at 25% though, the $2k it costs for gears, will continue to get cheaper and heaped the more miles you drive. Your ROI on driving that many miles in a year can be huge.
  16. Oct 15, 2018 at 11:57 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I just want to get a LSD on my supercharged crewmax. Need to find some place locally in Southern California that I can purchase from and get it installed by.
    Rica25 likes this.
  17. Oct 15, 2018 at 1:58 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    I'm interested in the durability of the 5.29 once they make them for the front dif. We have huge 3rd members (insert childish joke here), but the smaller ring in the front will be subject to a different level of abuse. Most gear breaks that I've heard of have been on 5.29, but usually it was their own fault - in reverse, under high load in 4low. That's a recipe for disaster for any gear set, but seems more common in the 5.29 than in sets with more pinion teeth. I know there are arguments all over about whether pinion tooth number accounts for anything, but I want to see some real world 4x4 testing in high torque situations - that's where shit breaks.
    Sas[QUOTED] likes this.
  18. Oct 15, 2018 at 2:01 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Yea, that's the same reasoning I have for why I'm skeptical but I'm going to keep faith in Nitro and their quality (ie. and their real world testing they do before they release) so I'm holding out until their gears come out next year. My Nitro 4.88s have been great so far and I've only ever heard great things about Nitro for almost the past decade since I've been wheeling.
    KevinK and Sas like this.
  19. Nov 13, 2018 at 5:21 AM
    #49
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    so are these still delayed till March/April 2019? I want a set now lol. Ready to pay
  20. Nov 13, 2018 at 7:19 AM
    #50
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    What's the approx cost for labor on a gear change ? front and back.
  21. Nov 13, 2018 at 7:38 AM
    #51
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    I've heard ranges between 1,000 and 1,500
    Rica25 and jeremyd[QUOTED] like this.
  22. Nov 13, 2018 at 7:53 AM
    #52
    jeremyd
    NV
    2014 SR5 CM 4X4
    Alright, thanks
  23. Nov 17, 2018 at 8:59 AM
    #53
    supermotobobby
    supermotobobby New Member
    Bobby
    2022 Tundra Platinum 4x4
    Having a 2wd CrewMax with 285/65-18 tires wound it be better to go with the 4.88 or 5.29 set for towing my 33' travel trailer.
    Rica25 likes this.
  24. Nov 17, 2018 at 9:03 AM
    #54
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I want these!!
  25. Nov 17, 2018 at 9:06 AM
    #55
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    We have our pre-order in the for the 5.29's and those we will be getting REM polished like our normal stock. Hope to have them in our hands late March and then we will be installing a set in our shop truck so that we have some first hand experience. Some people on here know that we don't treat our shop truck nicely when it comes to testing. haha.
  26. Nov 17, 2018 at 9:21 AM
    #56
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    Dammit!! I need these before spring time otherwise I’ll be forced to buy 4.88’s
    Mountun Goat likes this.
  27. Nov 17, 2018 at 7:50 PM
    #57
    KevinK
    Tundras to Sedona
    No idea what you mean about testing the shop truck. Nothing’s ever been tested to its limit while I was in the passenger seat...
    :anonymous:
    :censored:
    Erichudgins and dcsleeper408 like this.
  28. Dec 20, 2018 at 8:20 AM
    #58
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Just saw this post in Facebook for all u waiting on 5.29 gears
    Rica25 likes this.
  29. Dec 20, 2018 at 8:44 AM
    #59
    supermotobobby
    Bobby
    4:88 or 5:29 for towing my 33ft travel trailer? 2010 CM 2wd with one size bigger than stock tire size.
  30. Dec 20, 2018 at 8:51 AM
    #60
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    That's awesome Darren is local to me and that's who I got my two sets of 4:88's from.
    831Tun and fisherman951[QUOTED] like this.
