4x4 not working
Discussion in 'General Tundra Discussion' started by Ianstundra, Jul 12, 2021.
  1. Jul 22, 2021 at 7:38 PM
    Ianstundra
    Ianstundra [OP] New Member
    Ian
    Unless I did something wrong… yes.
  2. Jul 22, 2021 at 8:40 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    If it works fine when the actuator is off the TC then I doubt that the micro switch is the issue.
    I am curious to hear what Cruzer’s paint trick showed. Did it hit the trigger?
  3. Jul 22, 2021 at 9:53 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    So that just proves that the actuator is not working properly when it’s installed on the TC. If there are no marks on the switch then it was not able to rotate far enough, although it is able to do so off the the TC.
    So there’s only 3 possible outcomes:
    1: actuator is not installed correctly
    2: something in the TC is not positioned correctly
    3: actuator is bad and needs to be replaced
    I know you’ve tried addressing #1 & #2, so that leaves #3 to try.
  4. Jul 29, 2021 at 12:28 PM
    Ianstundra
    Ian
    I guess that’s what it has come to. Where can I buy only the 4hi actuator, without the rest of the assembly.
  5. Jul 29, 2021 at 6:17 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    I tried looking online but haven’t found one yet. Best bet is to go to your local dealership and ask them. Make sure to bring the part. If it’s expensive, just get the part number and continue the search online. Could probably find one at a wrecker for cheap.
    Ianstundra[OP] likes this.
  6. Jul 30, 2021 at 6:13 AM
    huntertn
    huntertn New Member
    Tennessee
    You can get the whole actuator from rockauto but it is around $475. I did not look around to see if anyone sold the 4hi and 4lo separately.
  7. Nov 5, 2021 at 6:04 AM
    Ianstundra
    Ian
    UPDATE: I bought the actuator, installed the 4hi actuator, the problem remained the same. Currently looking for a mechanic that is going to do more tests than just to replace the whole actuator assembly.
  8. Sep 18, 2022 at 1:06 PM
    Littlejer
    Littlejer New Member
    Jeremy
    07 Toyota Tundra
    6 inch lift
    Hello. I know this was last year but I’m wondering if you ever figured out the issue my 07 tundra is doing the exact same thing and I have a brand new front add actuator installed.
