4x4 not engaging!
Discussion in '1st Gen Tundras (2000-2006)' started by Tundraman05, Jan 13, 2020.
  1. Jan 13, 2020 at 8:10 AM
    Tundraman05
    Tundraman05 [OP] New Member
    Joe
    05 tundra sr5 crew
    4x4 lights flashing, I have cleaned terminals on rear actuator, and plug . Also drove and changed every gear. Nothing is working any advice would help thanks
  2. Jan 13, 2020 at 10:37 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Do you hear anything clunk or try to engage when you push the button? Light starts flashing as soon as you push it? What happens if you drive forward a bit?
  3. Jan 13, 2020 at 11:05 AM
    Tundraman05
    Joe
    05 tundra sr5 crew
    I can hear a humming noise for a sec when I turn ignition.. I have drove it around the block and it does not switch in. Including backing up and forward
  4. Jan 13, 2020 at 11:06 AM
    Tundraman05
    Joe
    05 tundra sr5 crew
    Yes lights start as soon as ignition is turned on.
  5. Jan 14, 2020 at 4:48 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That hum you hear on turning the ignition over is your fuel pump. I was hoping someone a little smarter than me would've answered by now. Lemme use my phone a friend lifeline. @empty_lord
  6. Jan 14, 2020 at 5:12 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Mind being a little more specific....2LO/4HI or 4 LO flashing or are they steady ?
    You feel confident you got actuator back together properly, good electrical connection and vacuum hose for solenoid back in place ?
    Have you unplugged battery for awhile and see if resets ?
    Very valuable troubleshooting by @lsaami
    Solved - 4hi Light blinking, won't "disengage" 4hi and 4low work fine
    lsaami and bmf4069 like this.
  7. Jan 14, 2020 at 5:54 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I had this happen when I first had my truck. It wouldn't engage into 4Hi or 4Lo. I pulled the fuse, listened to this jackass tell me Ram makes a better truck, put the fuse back in and put the truck in neutral. Switched over to 4Hi lights kept blinking and when I pushed the brake it engaged. Since then I haven't had any issues and I use it 4x4 probably 3 times a week.
    MrAristo and 15whtrd like this.
  8. Jan 14, 2020 at 6:14 AM
    15whtrd
    15whtrd Mr. Blonde
    :rofl:Best answer! Because of the Ram comment!
    Lake.Life24[QUOTED] likes this.
  9. Jan 14, 2020 at 10:30 AM
    Tundraman05
    Joe
    05 tundra sr5 crew
    Yes both lights flash at a constant speed. And now I got it to switch into 4hi . I cleaned connectors better . I think the front actuator mite be going out. It worked about 6 times and flashed again after that.
  10. Jan 14, 2020 at 10:46 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    1. get a helper to sit in the cab with you.
    2. Crawl under the truck, instruct your helper to turn the key on.
    3. let it sit for a minute to make sure the fuel pump has primed and cycled off.
    4. have them push the 4hi button. You should hear a whirring come from both the front differential, and the transfer case.
    Report back.
    bmf4069 and BubbaW like this.
  11. Jan 14, 2020 at 10:48 AM
    Tundraman05
    Joe
    05 tundra sr5 crew
    I do hear a slight noise but not engaging
  12. Jan 14, 2020 at 11:03 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Where?
  13. Jan 14, 2020 at 11:05 AM
    Tundraman05
    Joe
    05 tundra sr5 crew
    Hard to tell , need to have someone come by to crawl under truck and turn 4x4 on to really tell. But to me it sounds like the transfer case one.
  14. Jan 14, 2020 at 11:46 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Shoulda tagged you too. I forgot you went through all this recently. My bad.
    lsaami[QUOTED] likes this.
  15. Jan 14, 2020 at 11:47 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Can you kneel down beside the truck and poke the button with a stick? :boink:
  16. Jan 14, 2020 at 6:34 PM
    MrAristo
    MrAristo Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    How about when 4Hi/Lo flashing on dash as well as both lower buttons simultaneously? No engagement. Fuse was missing, I replaced it and then saw this.
  17. Jan 15, 2020 at 6:34 PM
    Lake.Life24
    Shawn
    Upstate, NY
    thats a good question. I haven’t had both flashing before. Sorry I couldn’t be more help
