4x4 HELP PLEASE!!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by cshughes79, Feb 14, 2020.
  1. Feb 14, 2020 at 7:51 AM
    cshughes79
    cshughes79 [OP] New Member
    Chuck
    2015 Tundra 9' lift on 37's
    6' suspension lift with a 3' body lift on moto metals wrapped in toyo open country 37x20x13.50 All memphis speakers in the doors with two 12 subs pushed by to power Rockford amps, LED lights all the way around
    Ok, so i have two issues i need some help. First i have hyper flash on both turn signals but not on hazards. I do have LED's but have the resistors on all four lights, and to verify none are bad i bought r new LED's and resistors and still hyper flash. I bought a new flasher control and issue still is there.
    Then the other day i went to test my 4x4 like i do every couple of months and when going to 4hi its like you can hear it engage or try to but the light just flashes and 4 wheel drive in HI is not there. If i try 4lo it just beeps and beeps and beeps with 4 HI flashing. Please SOMEONE HELP.
    I am so pissed i am almost ready to look at DODGES, GMC's AND even FORDS.
  2. Feb 14, 2020 at 7:56 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
  3. Feb 14, 2020 at 7:58 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Go look at Dodges, GMC and Ford.
    Did it happen after changing the bulbs and adding the resisters?
    What Ohms are the resisters?
    Did it happen after a while of having them in and it just happened?
    You may have a bad ground. I am guessing you will have other issues with one of the big three if you buy and mod one of those trucks too though.
    But again, give one of the others a try
  4. Feb 14, 2020 at 7:58 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    For giggles, try and move forward and reverse slowly while it's trying to engage. May need a new actuator.
    Big lifts and 37s might have prematurely worn a few items..
    Unknown on LED issues.
    Trust me...with the lack of quality the competitors are dishing out, a brand change isnt recommended.
    Cpl_Punishment and ZPMAN like this.
  5. Feb 14, 2020 at 7:58 AM
    ZPMAN
    Minnesota
    Beep!
    hagrid and TXMiamiFan like this.
  6. Feb 14, 2020 at 7:58 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Sounds like either the resistors weren't hooked up properly or aren't providing enough resistance to prevent the hyper flash.
    There are a number of threads regarding the 4WD issue you mentioned if you dig a little. Someone will probably respond again tho.
    Fotnot and 15whtrd like this.
  7. Feb 14, 2020 at 7:59 AM
    15whtrd
    15whtrd Mr. Blonde
    Believe it or not, your 4 x 4 issue is probably due to your hyper flashing of the lights. Figure that out first.
    jeremyd, 1engineer and Sas like this.
  8. Feb 14, 2020 at 8:00 AM
    cshughes79
    Chuck
    I have had the LED's in for awhile and all of sudden a few months ago i heard something in the steering column when turning the turn signal on, and then it started with just one side then the other after a few weeks. before all this started happening i did have a issue where the windows wouldnt roll up and just reseated the connection in the door and they started working.
  9. Feb 14, 2020 at 8:03 AM
    cshughes79
    Chuck
    i tried going forward and back and still wouldnt engage, even rode down the road a lil ways to see if it would go in and nothuing.
  10. Feb 14, 2020 at 8:06 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Did you look to see if anything came apart inside the column?
    You said you heard something. What did you hear?
    A bzzzzzz a click, clunk, a zzzzzzzzzzzzzzzz BANG!
    You may have broke or cooked something.
    I turn mine on and I hear Blink, blink, blink, blink
    15whtrd likes this.
  11. Feb 14, 2020 at 8:08 AM
    cshughes79
    Chuck
    heard like a clunk not sure how to describe the noise
  12. Feb 14, 2020 at 8:09 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Start there
  13. Feb 14, 2020 at 8:15 AM
    cshughes79
    Chuck
    i hope so...... guess it ccould be a switch any idea of what i would be looking for other the burnt wires or something, is there a relay in there? I have gone thru every single fuse in the truck and all are good
  14. Feb 14, 2020 at 8:16 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I would pull your LEDs and resistors and put the factory style bulb back in. See if that solves anything.
    15whtrd and Jaypown like this.
  15. Feb 14, 2020 at 8:18 AM
    cshughes79
    Chuck
    tried that and still hyper flash
  16. Feb 14, 2020 at 8:21 AM
    ZPMAN
    Minnesota
    Are your rear blinkers working?
  17. Feb 14, 2020 at 8:22 AM
    ZPMAN
    Minnesota
    BEEP!
  18. Feb 14, 2020 at 8:22 AM
    cshughes79
    Chuck
    yea the work
  19. Feb 14, 2020 at 8:25 AM
    ZPMAN
    Minnesota
    How old is the battery?
  20. Feb 14, 2020 at 8:33 AM
    cshughes79
    Chuck
    It's about two years old, and it's a deep cell battery
  21. Feb 14, 2020 at 8:35 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    It sounds like something broke
    If you remove the cover I am betting it will be obvious and if not it will soon be when you start wiggling things around in there.
    I dont know why or how it could have happened other than messing around inside.
    I have had cars and trucks for years and never ever had a problem with inside the column unless I got my little fingers in there and did something.
    Always figure out what you did and go back to the beginning and rethink it.
    Start tracing, it isn't Toyotas fault
    It worked great when it rolled out
  22. Feb 14, 2020 at 8:41 AM
    cshughes79
    Chuck
    I've never been in the column before but I'll check
  23. Feb 14, 2020 at 8:58 AM
    15whtrd
    15whtrd Mr. Blonde
    Yeah it sounds like you cooked or popped something. Maybe even the clock spring.Did you check the fuses under the dash?
  24. Feb 14, 2020 at 9:00 AM
    cshughes79
    Chuck
    What does the clock spring look like
  25. Feb 14, 2020 at 9:04 AM
    15whtrd
    15whtrd Mr. Blonde
  26. Feb 15, 2020 at 7:08 AM
    Tierhog
    Tierhog SIG-AHOLIC
    Then I'd suspect a bad actuator. Could potentially be a warranty item. The guys might be onto something regarding your LEDs, I simply dont have any experience in that area .
  27. Mar 8, 2020 at 12:00 PM
    cshughes79
    Chuck
    Ok so got a new clock spring, put it in still hyper flash, ripping the LEDs out and going back to regular bulbs, and 4or still not engaging actuator next purchase.
  28. Mar 8, 2020 at 5:25 PM
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    I went from a 2014 F150 5.0 to a 2020 tundra because I got tired of replacing transfer cases. Just FYI.
    NMG
    Jaypown likes this.
