4x4 blinking
Discussion in '1st Gen Tundras (2000-2006)' started by Paulb72, Jan 1, 2025.
  1. Jan 1, 2025 at 9:39 AM
    Paulb72
    Paulb72 [OP] New Member
    Paul
    06 Toyota tundra
    None
    Have an 06 tundra 4.7 liter. Changed the front 4x4 actuator and everything works but front not disengaging from drive shaft and checked transfer case actuator and it's working perfectly seems the front new actuator is not disengaging. Any advice?
  2. Jan 1, 2025 at 12:54 PM
    BroHon likes this.
  3. Jan 1, 2025 at 1:33 PM
    seachunk2
    seachunk2 New Member
    2004 Tunda DC V6 4WD SR5 AT
    I have the same issue but unfortunately I haven't figure cause.
    I can go in/out of 4Hi & 2WD with no problem, but it I am in 4Hi and place the transmission in Neutral, engaging 4Lo causes the amber 4Lo light to blink and the front driveshaft gets locked up and won't release. I have to take the transfer case actuator off to get everything freed up. I interpret your issue to be the same as what I am dealing with, correct?
  4. Jan 1, 2025 at 6:27 PM
    Paulb72
    Paul
    06 Toyota tundra
    None
    No my transfer case actuator is working correctly. It's front actuator that's not disengaging.
  5. Jan 1, 2025 at 6:38 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Tried going back and forth on gravel, dirt or snow? Sometime they have issues disengaging due to age and need as much help as necessary before you start regularly exercising 4wd again.
    BroHon likes this.
  6. Jan 2, 2025 at 5:07 AM
    2003DC
    2003DC New Member
    I pressed the button to disengage while driving backward about 5mph. Not a great option but it worked the last time I tried.
    Jack McCarthy likes this.
  7. Jan 2, 2025 at 5:11 AM
    seachunk2
    Same here. My ADD is the problem. The transfer case actuator is working fine.
  8. Jan 2, 2025 at 6:11 AM
    Paulb72
    Paul
    06 Toyota tundra
    None
    Toyota group is saying don't buy after market parts need to be oem.
