4wheel drive question
Discussion in '2.5 Gen Tundras (2014-2021)' started by ErikTRDTUNDRA, Feb 12, 2022.
  1. Feb 12, 2022 at 6:26 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA [OP] New Member
    Erik
    2018 Tundra crewmax 1794
    Alright Tundra community, so I have a head scratcher. I am not new to using 4wheel drive but I have only had this truck a little over a year. That being said I’m a little concerned with what happened today. I took the Tundra out to the beach for a amazing beach day. When I got to the beach I put the truck in 4hi and turned off the traction control as I have done many times. Everything registered on the dash display confirming I had the traction control disabled and I was in 4hi. I proceeded onto the beach and drove about 3 miles down the beach to a spot to park and enjoy the day. When I stopped I noticed smoke coming from the engine compartment on the driver side. Temp gauges all were normal. Smoke stopped fairly quickly. On our way off the beach I did not turn off the traction control and just went with 4hi. Same speed back off the beach if not a little faster and no smoke at all. I’m wondering if anyone else has experienced this issue. Would appreciate any good input.
  2. Feb 12, 2022 at 6:27 PM
    Was there any water by chance on the engine? Any odor of smoke?
  3. Feb 12, 2022 at 6:31 PM
    ErikTRDTUNDRA
    Erik
    No water at all , smoke appeared to be white and kinda smelled rubberish
  4. Feb 12, 2022 at 6:34 PM
    ErikTRDTUNDRA
    Erik
    I felt the wheel and hub and no heat at all , smoke was definitely coming from driver side Lower engine bay
  5. Feb 12, 2022 at 6:39 PM
    Maybe something from the heat shield hit it?
  6. Feb 12, 2022 at 6:48 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Yeah next time, I'd lift the hood at the time of 'smoke' and check it out...
  7. Feb 12, 2022 at 6:52 PM
    ErikTRDTUNDRA
    Erik
    I did lift the hood and the only thing I could narrow it down to was lower side of driver side engine compartment.
  8. Feb 12, 2022 at 6:53 PM
    BigRed20
    BigRed20 New Member
    2020 Barcelona Red TRD
    Why turn off TC in 4H?
  9. Feb 12, 2022 at 6:55 PM
    ErikTRDTUNDRA
    Erik
    I don’t want wheel spin limitations while in the sand
    Tundratoofun likes this.
  10. Feb 12, 2022 at 7:03 PM
    Kanobi13
    Kanobi13 New Member
    I would suggest you go play in the dirt and see how truck respond to different terrain op was correct in doing so.
    hANNAbONE likes this.
  11. Feb 13, 2022 at 7:13 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Sooooooo you see smoke, really didnt see source, somewhere on driver side, how the heck is anyone on the forum that wasn't within 100 miles of the truck supposed to know?
  12. Feb 13, 2022 at 7:31 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Did you try turning ATRAC off before engaging 4WD?
  13. Feb 13, 2022 at 7:51 PM
    ErikTRDTUNDRA
    Erik
    Have you spent much time on the forum? There are many people that have either had the same experience or have great advice. This forum has been a great source of information and knowledge.
    texasrho83 likes this.
  14. Feb 13, 2022 at 7:52 PM
    ErikTRDTUNDRA
    Erik
    There’s always one in the crowd
    Retired...finally likes this.
  15. Feb 14, 2022 at 8:22 AM
    ErikTRDTUNDRA
    Erik
    yes if i remember correctly that was the sequence .
  16. Feb 14, 2022 at 8:26 AM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    That's a tough one.
    Possible culprits:
    Water from AC system.
    Something kicked up from the ground touching something hot under truck.
    Some sort of oil leak hitting something hot on its way to the ground.
    Coolant leak.
    Further investigation required when this occurs next time.
    Let us know.
  17. Feb 14, 2022 at 8:49 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Random idea, but do you think it's possible that the tires kicked
    I was thinking trash in the sand might have kicked up and touched something hot too. Especially if it's a rubber burning smell.
    Seafury[QUOTED] likes this.
  18. Feb 14, 2022 at 10:03 AM
    ErikTRDTUNDRA
    Erik
    all good information and things to look into. I wanted to just ask the question more to see if this was a problem more Tundra owners had experienced. Seems to be specific to my situation so i will monitor it closely next trip out. Appreciate everyone who has replied with good intent.
    Jaypown[QUOTED] likes this.
  19. Feb 14, 2022 at 1:59 PM
    TTund16
    TTund16 New Member
    Also possible that something got a little bit hot. slow drive, low gears and not much air flow ...
    Things can get hot (within design spec) but you could smell it. Also if there is some oil residue somewhere it will burn off when it gets hot.
    See if you can reproduce.
    ErikTRDTUNDRA[OP] likes this.
