4wheel drive issue
Discussion in '2nd Gen Tundras (2007-2013)' started by superbond, Jan 19, 2020.
  1. Jan 19, 2020 at 11:07 AM
    superbond
    superbond [OP] New Member
    Hello all
    I am first time poster and just signed up as a member.
    I have a 2010 Tundra Crewmax Platinum. It been a great truck other then a certain leaf spring that keeps braking to which there is no recall.
    Today when I was running around town. I had my truck in 4wheel drive and there was a strange noise that was coming from drivers side front wheel. It started off and then escalated to a very loud noise. I almost thought it was a fighter jet flying over top of us ( wife and I). I was doing about 40 mph. When I realized it was actually coming from my truck I quickly took it out of 4H. The noise went away!
    It drove perfect. When I got home and in my drive way I put it back into 4wheel drive and no noise worked fine. Although I only went up and down the driveway ( 40feet) but no noise and the front end was working fine.
    Any idea what the sound would have been? It was loud and did sound like a fighter jet flying over me at a low altitude. Weird!
  2. Jan 21, 2020 at 12:04 PM
    superbond
    I tried it again and it is a clicking noise coming from the front left front end. Any idea what is would be? Is there a video on how to fix it or a schematic on the break down of the front hud for 4x4’s 2010
  3. Jan 21, 2020 at 12:10 PM
    Aerindel
    Aerindel New Member
    Montana
    CV axle. Classic symptoms. Not hard to replace.
  4. Jan 21, 2020 at 1:35 PM
    superbond
    Do I need anything other then the cv axle when I order parts?
  5. Jan 21, 2020 at 5:52 PM
    Aerindel
    Aerindel New Member
    Montana
    Well, I'm not an expert on 2nd gen tundras so maybe someone else can chime in, but in general, you will need a new axle nut and retainer washer but most axles come with one. You will need to disconnect a ball joint or tie-rod end so if you have any doubt about those it would be a good time to replace them. The same goes for front axle seals, a good time to replace them but not required unless you mess them up taking out the axles.
    You will need a good sized torque wrench and breaker bar to get the nut off and on again if you don't already have one.
  6. Jan 21, 2020 at 6:03 PM
    koditten
    Kirk
    Midland of the Mitten
    I gotta ask. Why were you in 4WD in town? Please tell me the roads were snow covered.
    Running in 4WD on dry roads in town is going to cause a lot of drive line bind. Lots of stress on the CV joints primarily is caused. It's not good for the rest of the 4WD system either.
  7. Jan 21, 2020 at 6:25 PM
    superbond
    I was driving in 4wheel drive because we just had 10”plus inches of snow and their slow on toed plowing.
    koditten likes this.
  8. Jan 21, 2020 at 6:26 PM
    superbond
    Does anyone know what size socket for the cv axle?
  9. Jan 21, 2020 at 6:31 PM
    Aerindel
    Aerindel New Member
    Montana
    Well, again, I don't have a second gen, but it looks the same in pictures, mine was a 30mm.
  10. Jan 21, 2020 at 9:10 PM
    superbond
    I heard it was a 35mm just want to be sure before I buy one
  11. Jan 21, 2020 at 9:19 PM
    Aerindel
    Aerindel New Member
    Montana
    It could be, like I said, different model truck. I'd probably wait until I had the new axle and take the nut to your parts store to make sure.
  12. Jan 23, 2020 at 12:18 PM
    superbond
    It is a 12 point 39mm
  13. Jan 23, 2020 at 12:20 PM
    superbond
    I took my tire off and grabbed the cv axle and tried to shack it around to see play but it was solid like a rock. Starting to wonder if it is the cv axle. Don’t know what else it would be.
  14. Jan 25, 2020 at 5:56 PM
    superbond
    Changed the cv axle today and the noise is still there! No as loud but there. What else could it be?
    I’ve owned 4x4’s most of my life. Back in the day when you wanted to put it in 4wheel drive you had to get out and turn your hubs, now just turn a dial.
    Could it be my left hub is not engaging all the way and if so how do I correct this?
  15. Jul 2, 2020 at 2:36 PM
    superbond
    Forgot to reply back.
    Fixed the issue. There was a metal tag on my drive shaft that was loose and hitting my catilac converter. Took the tag off and alll is great!
    olds350 and Chrslefty like this.
  16. Jul 3, 2020 at 9:36 AM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    Easy fixes are nice!
