4wd usage and Manual instruction
Discussion in 'General Tundra Discussion' started by Jim the Jarhead, Oct 12, 2017.
  1. Oct 12, 2017 at 3:07 PM
    Jim the Jarhead
    Jim the Jarhead [OP] New Member
    2017 SR5 4X4
    Just throw this out there. Do most of us use the 4wd enough to keep parts lubed up. Owner's manual states to operate on semi regular basis. I will during winter, but the suburbs dont offer anything other than cutting across a golf course during rush hour. What say you?
    Wynnded and 4x4_Angel like this.
  2. Oct 12, 2017 at 3:14 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I try to go out 4x4’n at least once per month. Sometimes I don’t make it that often.
    Living in Las Vegas the roads get super slippery right when it first rains (it only rains a few times per year), when this happens I usually will throw it into 4 HI and slide around a little bit just to lube things around. I don’t know if this is bad or not but that’s what I do.
    NewImprovedRon likes this.
  3. Oct 12, 2017 at 3:32 PM
    I try to do 10 miles a month in 4WD and a quick up and down in 4L.
    Just drive straight, throw it in 4WD where/when you can. Do not make turns on dry roads in 4WD. You will bind the drivetrain.
    Y0TA PR0 likes this.
  4. Oct 12, 2017 at 3:38 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Yes, I never drive on dry pavement in 4 wheel so I don’t mess anything up.
  5. Oct 12, 2017 at 3:39 PM
    You can drive on dry pavement, just not turn without binding.
  6. Oct 12, 2017 at 3:41 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Good to know. Thank you.
    Can you also drive in 4LO on pavement as long as you don’t turn your wheels??
  7. Oct 12, 2017 at 3:43 PM
    Yes sir. I do it on my street. Quick / small up and down.
  8. Oct 12, 2017 at 5:18 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I get to do it every month almost everyday 4hi/low, benefits of desert life, or military for that matter I abuse the roads meant for military vehicles
    040Tundra and Y0TA PR0 like this.
  9. Oct 22, 2017 at 6:10 AM
    Mollywood73
    Mollywood73 New Member
    2017 TRD Double cab
    I work at a concrete plant, we have a large stock pile of sand where i can engage 4WD and keep things lubed up.
  10. Oct 22, 2017 at 9:08 AM
    f86sabjf
    f86sabjf New Member
    17 Tundra trd off-road
    Yep a few times a week rolling along in the daily traffic jam for a few miles.
