4WD to be used 10 miles a month?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mad Max, Dec 4, 2020.
  1. Dec 4, 2020 at 7:34 AM
    Mad Max
    Mad Max [OP] New Member
    Max
    2021 Tundra Limited
    Reading the owners manual it appears we are supposed to engage 4WDH for ten miles a month problem is manual also says "
    4H” (high speed position, four-wheel drive)
    Use this for driving only on tracks that permit the tires slide, like off-road, icy or snow-covered roads. This position provides greater traction than two-wheel drive.
    The “4HI” indicator will come on.
    I don't have 10 miles of dirt roads aroud me. what does it hurt driving on concrete?
    thanks
  2. Dec 4, 2020 at 7:37 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    Just don't take sharp corners. The drivetrain will bind up if you're at full crank. If you're on a highway with it on it's golden. Also imo 10 miles is a bit excessive, I would just turn it on for a bit occasionally to make sure everything can actuate fine.
  3. Dec 4, 2020 at 7:49 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood amp & AudioControl LC7i Tech12volts JL Tweeters
    I just activated mine the other day while backing out of the garage.
    I try and do it every couple months
  4. Dec 4, 2020 at 7:52 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    I just wait for rainy days and engage for a few miles. Easy peasy...
  5. Dec 4, 2020 at 7:56 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I can get from my house to work, 13km, using 4HI. I disengage when I get to the parking lot as corners are too sharp.
    Concrete is fine OP
    Cpl_Punishment likes this.
  6. Dec 4, 2020 at 8:08 AM
    Kanobi13
    Kanobi13 New Member
    Travel to some dirt roads nice to get out of the city!!
    Black Wolf and Darkness like this.
  7. Dec 4, 2020 at 8:32 AM
    Wallygator
    I do this religiously every month. Usually wait until it's raining and find a straightish road, drive 5 miles out and back. Or head into the forest and drive dirt for 10 miles. If I have to turn I take it out of 4wd and then reengage when straight. Then back at the driveway I put it in and out of 4 low. Have to keep the drivetrain exercised, lubed, and working.
  8. Dec 4, 2020 at 8:36 AM
    Green Thunder
    Green Thunder Smooth in the Cruise
    Washington
    2020 Burnt Green TRD Pro
    Food crumbs and dog fur
    I've got a couple of gravel parking lots near me. I hit one up every few months and just drive around and do some figure-8's. The 10-miles is stupidly unrealistic for most people.
    BravoDeltaRomeo likes this.
  9. Dec 4, 2020 at 9:26 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Yes, I use it as an excuse to my wife so I can go offroading. Or when I get lazy washing the truck from off-roading I just find a long straight away and engage 4wd just don’t make any turns.
  10. Dec 4, 2020 at 9:49 AM
    Wallygator
    Yeah I can see where you are coming from. I'm guessing Toyota has determined that 10 miles allows the fluid to heat up and expand sufficiently so it gets to where it needs to go and burns off any moisture. But again that is a complete guess.
  11. Dec 4, 2020 at 10:18 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I do the same.
    Tundyfundy likes this.
  12. Dec 4, 2020 at 12:28 PM
    Suprafantx
    Suprafantx New Member
    2020 4X4 White Tundra TSS
    How fast you can drive on 4WDH? I remember something like 55 mph but don't have manual with me. I usual do below 50 mph but want to know what is fast safe speed I can go.
  13. Dec 4, 2020 at 12:39 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    There's no speed limit in 4Hi. Only when you can engage it.
    SC_TRD, NewImprovedRon and GodlessPro like this.
  14. Dec 4, 2020 at 12:45 PM
    Samoan Thor
    Yup, no speed limit for 4hi but you have to be below 65mph before you turn that knob from 2wd.
  15. Dec 4, 2020 at 12:46 PM
    art64
    art64 New Member
    My truck is old 2010 Crewmax 4x4. Bought it used. I regularly actuate the 4 hi and 4-low even on the driveway. Just to actuate it so the mechanism won't get stuck. On the freeway here when there's traffic, I put it on 4-hi. I keep an eye on speed so not to exceed the specified limit or I won't be able to switch to 2wd until the speed gets below 40 mph I believe. 4-lo can be done on huge parking lot. Absolutely no turning.
  16. Dec 4, 2020 at 1:12 PM
    Mad Max
    Max
    2021 Tundra Limited
    Thanks everyone. No doubt in Houston we get the rain. I like the straight rainey road idea the best, that won't be an issue.
  17. Dec 4, 2020 at 1:44 PM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Isn't it limited? Out on the dry lake bed didn't we find out that we couldn't go over 90-ish?
  18. Dec 5, 2020 at 8:16 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    I don't think I engaged 4WD in the year 2020. Hmmmmm. Maybe I should in 2021. Let's see if the spirit invades me.
    War Machine likes this.
  19. Dec 8, 2020 at 7:15 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    I engage it when I need it, which outside of winter isn't much. 10 miles per month always struck me as unnecessary and unrealistic.
  20. Dec 8, 2020 at 7:22 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Haha. I haven’t even driven 10 miles in my truck in the last 6 months. Zero of that in 4wd.
    deptrai, GodlessPro and Saltyhero13 like this.
  21. Dec 15, 2020 at 9:43 PM
    MeetJoe
    MeetJoe New Member
    Maryland
    2021 CrewMax SX
    OEM TRD Pro Led Headlights OEM LED Fog lights iHacker Harness OEM Tube Step OEM trifold hard tonneau OEM Driverside Grab Handle and Pillar OEM Exhaust tip Wireless CarPlay CarLinkit 3.0 Snack Crumbs
    kudos to you for reading the owners manual! Just bought a 21 CM 4x4 SX last month.. would you recommend cracking open that manual and browsing?
    Any other notable facts?
  22. Dec 16, 2020 at 1:22 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  23. Dec 16, 2020 at 4:21 AM
    Vizsla
    Vizsla ☠️☠️☠️
    The only limit I found for 4hi/2wd is the speed limiter, not sure if that is what we hit on the dry lake. I have 2 choices for speed limiter, both coincide with a tire speed rating, assume one is for the 18”, other for 20” oem tires. Fixed mine, but there isn’t much power left to make a noticeable difference in 4hi on dirt.
  24. Dec 16, 2020 at 5:19 AM
    War Machine
    War Machine SSEM # 5 3MW
    I’ve activated mine maybe three times in 3 1/2 years.
  25. Dec 16, 2020 at 9:49 AM
    mcm0455
    mcm0455 New Member
    2020 Tundra Platinum
    i'm probably at around 100 miles in 4wd out of the 8500 miles I've put on the pickup since I bought it back in March of this year. Feels pretty solid with the Coopers in the snow. Still not a true dedicated winter tire, but plenty of grip.
  26. Dec 16, 2020 at 9:58 AM
    PA452
    PA452 New Member
    Which Coopers?
  27. Dec 16, 2020 at 1:10 PM
    mcm0455
    mcm0455 New Member
    Discoverer ATS 4s 255/75/17
  28. Dec 16, 2020 at 1:25 PM
    PA452
    PA452 New Member
    That's good to know. I've been thinking about the Cooper AT3 4S to replace my stock Michelins, 275/65/R18.
  29. Dec 16, 2020 at 1:25 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Haven't had my dirt fix in almost 3 weeks! Fiending for a hit badly :mudding:
